    SU 9 Wishlist
    436 Posts 99 Posters 85.8k Views 99 Watching
      marcuus
      I do not know if you post here is still valid or whether the terms have already expired, but I read just now and, among my greatest desires for a great leap of scketch up there would be a chance to make it compatible
      with the cam system, such as the Tebis for example, or others that can recognize,
      as the 3D modeling is not born just to take pictures or static images
      but is just a coin ☀
        lapx
        Rotation input in the material dialogue box please.
          kwistenbiebel
          good suggestion
            mpowell1234567890
            I have a few wishes for Sketchup 9 "free":
            1. The follow-me tool that can go over crossed lines.
            2. Push-pull on curved objects.
            • john2J Offline
              john2
              I have a long wishlist 😉
              1. Multiple windows of files interface, so that new SU doesn’t have to be opened every time.
              2. Thumbnail support in folder containing SketchUp files for 64 bit windows 7 operating system
              3. Better 2d export facility with layers support. This will help in efficient post processing in AutoCAD.
              4. Ability to export PDFs (in layout as well as SU) with shadows as a vector and not a raster.
              5. Feature to control lineweight for different layers or selected objects within SketchUp itself.
              6. Solid cut through – will give users an option the moment they put a door on a wall, it cuts a hole throughout and not on a face particularly. The following options can be there.
              7. Collision detection (that can be turned on or off) so that furniture don’t punch themselves through a surface
              8. Customized snap options like AutoCAD.
              Midpoint
              Nearest
              Perpendicular
              Endpioint
              Tangent
              Center
              Node , etc.
              Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                As a V-Ray user you do not want this. MDI would make multiple models share the same host process - and also memory.
                @john2 said:
                1. Thumbnail support in folder containing SketchUp files for 64 bit windows 7 operating system
                +1!!!!
                  ArCAD-UK
                  @john2 said:
                  1. Feature to control lineweight for different layers or selected objects within SketchUp itself.
                    Some good suggestions but please don't burden SU simple efficiency with unnecessary Aut*CAD wannabe features like this.
                    jhauswirth
                    +1!!!![/quote]
                    It WAS really nice having thumbnails in 64-bit Windows.....
                      Was? ❓
                      • john2J Offline
                        john2
                        Adding to my list :
                        Feature for Hatching with vector patterns like brickwork, cement, etc. with this one would be able to create richer sectional view of details like planter, window, door frame, fountain,etc. one thing id like to ask. is posting ideas like this on forum effective [i.,e. more likely to get your wish fulfilled] or posting on google ideas ?
                        • utilerU Offline
                          utiler
                          That is something that I think all of us would like John. The more we make noise about it the more likely it will happen!!!
                          Just Curious...
                            rv1974
                            Bisection tracking!
                            • john2J Offline
                              john2
                              @rv1974 said:
                              Bisection tracking!
                              you mean angle bisection ?that would be awesome 👍
                                @john2 said:
                                @rv1974 said:
                                Bisection tracking!
                                You can do this already since v4?...
                                Make a guideline through one edge.
                                Select it and use Rotate+Ctrl to copy the guideline around the 'apex' by the full angle you'd like to subdivide...
                                Then immediately type /2
                                This will add a bisector guideline.
                                Note: To divide the angle into 3 equal parts use /3 etc...
                                  rv1974
                                  this is tedious workaround, not the tracking 'on the fly'
                                    Tell me how many clicks or key strokes your new "wonder-tool" would need - I suspect not many fewer than what I suggested...
                                    You would somehow still need to define the apex, start angle, end angles and the subdivisions...
                                      rv1974
                                      very similar to square drawing in the present version.
                                      (o.k. 0.5: just 2 keybord free hover moves over bisection forming edges)
                                      BTW user defined angle snapping (with on\off mode) would be nice too.
                                          It you had a face with two edges at the vertex it could 'bisect' the angle [you'd still need keyboard input to say do 1/3's]... BUT if the vertex shares more than one face how is Sketchup to know which pair of edges it's to use and the associated face plane for the 'bisection' - you'd still need to pick to select the two edges in question [2 clicks], right-click for context-menu[?] and then enter the divisor numeral [e.g. '2'+enter] >>> 2+1+1+1=5 - whereas so using a guideline = shortcut-key + click/drag [2], then shortcut-key to Rotate +Ctrl to copy, click start, click end [4] plus the divisor numeral [e.g. '2'+enter] >>> 2+4+2=8 - so it could be done in less, but never 0 !
                                          It is easy to code, but I'm not sure it's that useful 😕
                                          PS: It's a new context-menu tool available here http://forums.sketchucation.com/viewtopic.php?p=419335#p419335
                                            rv1974
                                            @thomthom said:
                                            [attachment=0:1oukterl]<!-- ia0 -->AngleSnapping.png<!-- ia0 -->[/attachment:1oukterl]
                                            I meant angle tracking, mea culpa. Similar to Acad one.
                                            • 21
                                            • 22
                                            • 8 / 22
