    SU 9 Wishlist
    436 Posts 99 Posters 119.0k Views 99 Watching
    • N Offline
      numerobis
      Yes, maybe it's not easy... but it looks like it will be the only way to get real perfomance improvements in future versions... since this is the way CPUs evolve since a few years. πŸ˜’
      And even if it is not possible to use multiple cores for modeling or geometry display, it could be used at least to speed up "closed" operations like rendering images or saving in the background.
      It's really a joke that you have to open multiple versions of the same file to speed up rendering an animation (i found a limit somewhere at 8 instances...) - why can't this be done internally?!?
      btw... i would really like to hear the explanation why an autosave takes 10 times lomger than a normal save... really annoying πŸ˜’
        ArCAD-UK
        Please can we have Generate Report CSV linked to the model units or at least give us a basic option of output in inches / centimetres. It's a real pain having to convert everything to metric just to do quick quantity checks.
          Anton_S
          Anyways who is working on creating SU9?
            An infinite number of monkeys in front of keyboard typrewriters.
              Anton_S
              ...which, are at Zoo. πŸ˜’
                gzotti
                I would like to see a skybox as parallax-invariant background that is also not trimmed off by the far Z plane. Either from an equirectangular panorama or six cube faces. Transparency to be allowed (so the blue-ish sky comes through, and the sun and shadow algorithms should take the skybox into account. Or maybe even a Preetham-style sky colour skybox with a "sun" with lens flare?
                  marcuus
                  I do not know if you post here is still valid or whether the terms have already expired, but I read just now and, among my greatest desires for a great leap of scketch up there would be a chance to make it compatible
                  with the cam system, such as the Tebis for example, or others that can recognize,
                  as the 3D modeling is not born just to take pictures or static images
                  but is just a coin β˜€
                    lapx
                    Rotation input in the material dialogue box please.
                      kwistenbiebel
                      good suggestion
                        mpowell1234567890
                        I have a few wishes for Sketchup 9 "free":
                        1. The follow-me tool that can go over crossed lines.
                        2. Push-pull on curved objects.
                          πŸ˜„
                        • john2J Offline
                          john2
                          I have a long wishlist πŸ˜‰
                          1. Multiple windows of files interface, so that new SU doesn’t have to be opened every time.
                          2. Thumbnail support in folder containing SketchUp files for 64 bit windows 7 operating system
                          3. Better 2d export facility with layers support. This will help in efficient post processing in AutoCAD.
                          4. Ability to export PDFs (in layout as well as SU) with shadows as a vector and not a raster.
                          5. Feature to control lineweight for different layers or selected objects within SketchUp itself.
                          6. Solid cut through – will give users an option the moment they put a door on a wall, it cuts a hole throughout and not on a face particularly. The following options can be there.
                          7. Collision detection (that can be turned on or off) so that furniture don’t punch themselves through a surface
                          8. Customized snap options like AutoCAD.
                          Midpoint
                          Nearest
                          Perpendicular
                          Endpioint
                          Tangent
                          Center
                          Node , etc.
                          Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                            As a V-Ray user you do not want this. MDI would make multiple models share the same host process - and also memory.
                            @john2 said:
                            1. Thumbnail support in folder containing SketchUp files for 64 bit windows 7 operating system
                            +1!!!!
                              ArCAD-UK
                              @john2 said:
                              1. Feature to control lineweight for different layers or selected objects within SketchUp itself.
                                Some good suggestions but please don't burden SU simple efficiency with unnecessary Aut*CAD wannabe features like this.
                                jhauswirth
                                +1!!!![/quote]
                                It WAS really nice having thumbnails in 64-bit Windows.....
                                  Was? ❓
                                  • john2J Offline
                                    john2
                                    Adding to my list :
                                    Feature for Hatching with vector patterns like brickwork, cement, etc. with this one would be able to create richer sectional view of details like planter, window, door frame, fountain,etc. one thing id like to ask. is posting ideas like this on forum effective [i.,e. more likely to get your wish fulfilled] or posting on google ideas ?
                                    • utilerU Offline
                                      utiler
                                      That is something that I think all of us would like John. The more we make noise about it the more likely it will happen!!!
                                      Just Curious...
                                        rv1974
                                        Bisection tracking!
                                        • john2J Offline
                                          john2
                                          @rv1974 said:
                                          Bisection tracking!
                                          you mean angle bisection ?that would be awesome πŸ‘
                                            @john2 said:
                                            @rv1974 said:
                                            Bisection tracking!
                                            You can do this already since v4?...
                                            Make a guideline through one edge.
                                            Select it and use Rotate+Ctrl to copy the guideline around the 'apex' by the full angle you'd like to subdivide...
                                            Then immediately type /2
                                            This will add a bisector guideline.
                                            Note: To divide the angle into 3 equal parts use /3 etc...
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 21
                                            • 22
                                            • 15 / 22
