    [Plugin] Selection Toys
    593 Posts 120 Posters 357.6k Views 120 Watching
      @the.pjt said:
      hi Thomas ...
      is it possible to update these codes to run with your TTlib2instead of TTlib ?!? ... now should install 2 main directories . one of this nice and must-have selection plugin and one for everything else ...
      I know that you are so busy .. plus you are doing another projects ( like NUBS plugin ) ... these projects are more important for us and for you ... πŸ˜„ ... and we know that current version of selection toys works well with TTlib.. but we love to have a cleaned up plugins folder πŸ˜„ and faster SU start up
      thanks thomthom ....
      Yes, I also want to get rid of the old TT_Lib - but the 900 lines long Selection Toys has quite a few references and TT_Lib2 is not backward compatible in any way with TT_Lib. I would rather rewrite the whole of Selection Toys so it scales better with all the features it got through-up the years. And create a better interface.
      I also understand the performance concerns, though TT_Lib should not be of much performance impact. I've been profiling the performance of my own plugins and the others installed and it seem to be that toolbars is one of the biggest performance impacts. SelectionToys only loads the parts of TT_Lib it needs, which is a couple of modules and they load in a tiny fraction of a second. Which is why it hasn't been put higher up on my list of priorities.
      Lemme sort out Vertex Tools 1.1 and Bezier Surface first.
      • irwanwrI Offline
        irwanwr
        my HDD crashed and need to be recovered and reinstalled.
        but when i installed Selection Toys, something that never happened before appeared.
        error message
          Looks like you installed it incorrectly.
          • Dan RathbunD Offline
            Dan Rathbun
            Invalid character errors like this, that happen for line 1, occur because Ruby cannot understand the encoding of the source file.
            I'm not here much anymore.
              All of this suggests that it is not a valid Ruby file ?
              Oddly encoded?
              Opened in a word-processor??
              Incorrectly unzipped???
              Who knows...
                Looks like corrupted download, or corrupted unzipping. What's the content ofvthe .rb file when you open it in a text editor - a plain text editor like Notepad?
                I've never ever seen such error.
                • irwanwrI Offline
                  irwanwr
                  i've downloaded both again twice. TTLib and Selection Toys.
                  either 7zip or winrar seems to work just fine.
                  i'll try to unzip them with 7zip then.
                  [Edit]
                  Problem solved. Old corrupted files sometimes need to be erased first
                  and not just overwrite it. Both works fine now. Checked with Notepad++.
                  Thank you all. πŸ‘
                    Does exist a selection of segments of an explosed curve 1/x ? (Maybe I have missed that in the list)
                    So
                    for 1/2 ( 1,3,5,7...
                    for 1/3 (1,4,7,10...
                    for 1/4 (1,5,9,13...
                    etc...
                      what..? 😲 πŸ˜• ❓
                        Like this for select all segments of a curve by 1 / x
                        Here x = 2 or x = 3
                          I was thinking of something like that for V3 - and QuadFace Tools.
                            Cool! 😎
                            • I Offline
                              ivreich
                              Select edges by length(?)
                              Hi thomthom,
                              Any chance we could have a feature to select edges by length? For examples, select edges <X, =X, >X, where X is the length of a pre-selected edge?
                              I'm doing some work involving mapping of components to edges, and this could be a pretty handy tool to have.
                              Cheers
                              Joel
                                Right now I'm very busy with Vertex Tools - getting it ready to ship.
                                • cottyC Offline
                                  cotty
                                  Hi thomthom,
                                  Cheers
                                  Joel
                                  Maybe this can help you: http://forums.sketchucation.com/viewtopic.php?t=16915#p134106 ?
                                  my SketchUp gallery
                                  • E Offline
                                    Ecuadorian
                                    Just wanted to thank Thomthom again. I'm currently working on a project that has a lot of junk in a certain layer, and found no other way to do the job but to use his plugin.
                                    Thanks! πŸ‘
                                    -Miguel Lescano
                                      Dollmaker
                                      Select loop does not work for me on sketchup 8.. it only select edges but there is no loop selected on faces..
                                        Screenshots? Sample model?
                                        • F Offline
                                          fullyfledgeded
                                          Hi, great tool. Works on my google su 8 but not my trimble version. Any thoughts? the plugins are installed, but when you context click nothing happens
                                            I have the latest Trimble version, used every one f them. Always worked.
                                            Can you be more specific to "when you context click nothing happens"?
                                            What are you clicking on?
                                            Surely there is a menu appearing? Missing menu items?
                                            Any errors? (If you keep the Ruby Console open?)
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 27 / 30
