    [Plugin] Selection Toys
    594 Posts 121 Posters 587.6k Views 121 Watching
      Does exist a selection of segments of an explosed curve 1/x ? (Maybe I have missed that in the list)
      So
      for 1/2 ( 1,3,5,7...
      for 1/3 (1,4,7,10...
      for 1/4 (1,5,9,13...
      etc...
        what..? 😲 πŸ˜• ❓
          Like this for select all segments of a curve by 1 / x
          Here x = 2 or x = 3
            I was thinking of something like that for V3 - and QuadFace Tools.
              Cool! 😎
              • I
                ivreich
                Select edges by length(?)
                Hi thomthom,
                Any chance we could have a feature to select edges by length? For examples, select edges <X, =X, >X, where X is the length of a pre-selected edge?
                I'm doing some work involving mapping of components to edges, and this could be a pretty handy tool to have.
                Cheers
                Joel
                  Right now I'm very busy with Vertex Tools - getting it ready to ship.
                  • cottyC
                    cotty
                    Hi thomthom,
                    Cheers
                    Joel
                    Maybe this can help you: http://forums.sketchucation.com/viewtopic.php?t=16915#p134106 ?
                    my SketchUp gallery
                    • E
                      Ecuadorian
                      Just wanted to thank Thomthom again. I'm currently working on a project that has a lot of junk in a certain layer, and found no other way to do the job but to use his plugin.
                      Thanks! πŸ‘
                      -Miguel Lescano
                        Dollmaker
                        Select loop does not work for me on sketchup 8.. it only select edges but there is no loop selected on faces..
                          Screenshots? Sample model?
                          • F
                            fullyfledgeded
                            Hi, great tool. Works on my google su 8 but not my trimble version. Any thoughts? the plugins are installed, but when you context click nothing happens
                              I have the latest Trimble version, used every one f them. Always worked.
                              Can you be more specific to "when you context click nothing happens"?
                              What are you clicking on?
                              Surely there is a menu appearing? Missing menu items?
                              Any errors? (If you keep the Ruby Console open?)
                              • F
                                fullyfledgeded
                                In trimble SU 8 I double click Susan (SU's default component) to enter it for editing. Click her grey shirt so only that is selected. right click it, then click select & then hit "coplanar faces". nothing changes.
                                the exact same process in google SU 8 works how it should.
                                ruby console displays nothing in both cases
                                there are no missing menu items, it appears the same in both su versions.
                                thanks
                                  Works fine on my computer. Might be some other plugin interfering. Try with just Selection Toys installed.
                                    If you click on just her 'gray' shirt then only one face will be selected, there are no edges in the selection to be considered for coplanar-ness...
                                    BUT if you double-click the shirt-face so that its edges also select... then some of those edges can be considered 'coplanar', because they border two same-plane-faces which also have the same 'gray' material...
                                      MadPax
                                      Do the conditions of dependency mean that one cannot have both Quad Tools and the Selection Toys installed simultaneously? (Because of the different TT-Lib versions involved?)
                                      Cheers,
                                      Peter
                                        Select Coplanar in Selection Toys doesn't consider edges at all. Selecting one face is enough. See my previous reply - it's working on my machine and every other I've tried. This appear to be a local issue - which is why I suggested trying with just Selection Toys installed.
                                          Cheers,
                                          Peter
                                          No - none of my plugins conflict with each other. TT_Lib is different from TT_Lib2 and they do not overlap.
                                          I was thinking there could be some other plugins you have installed - not one of mine - that might be conflicting.
                                          • F
                                            fullyfledgeded
                                            thanks, is there any way to find out what the interfering plugins are?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 29
                                            • 30
                                            • 22 / 30
