    Webdialogs: inputbox shows black background (sketchup webkit
    50 Posts 22 Posters 40.6k Views 22 Watching
      @aerilius said:
      UI::WebDialog.open
      You mean UI::WebDialog.show ?
        Aerilius
        fixed it.
          driven
          @aerilius said:
          fixed it.
          hi, I'm getting
          Error: #<SyntaxError: (eval):24: compile error (eval):15: parse error, unexpected '(' alias(:show_orig, :show) ^ (eval):20: both block arg and actual block given> (eval):24
          I'd much rather use a small amount of ruby to 'fix' the input problem
          cheers for your efforts
          • Dan RathbunD
            Dan Rathbun
            @Aerilius
            It's much more complicated than that.
            I have a patch that does similar.. (and more,) but we can't release such a thing without Boulder's blessing.
            We have realized, that it's best not to show how to modify the API modules and classes. Some newbie's just run with it and start hacking away, and worse. (Yes we've all been guilty of openly discussing such things in the past. I'm sure I have. Sometimes we forget the "kids" come along and read what we've written later.)
            Anyway... you don't need the literal block when you pass to the orig method, as the wrapper method has already converted any block argument to a Proc object.
            So instead you do:
            block_given? ? show_orig(&proc) : show_orig()
            But it will not work like that, for the same reasons that the current API show(), show_modal() and set_on_close() block form methods do not work on Mac. (The webpage is never ready when Ruby executes the block.)
            I'm not here much anymore.
              driven
              Improved my 'GreaseKit' UserScript using a file from Dan (cheers)
              with safari Css style on input borders
              // ==UserScript==
              // @name           inputPatch
              // @author	       driven
              // @namespace      http://drivenupthewall
              // @description    fixes webkit input boxes in SketchUp.
              // @include        *
              // ==/UserScript==
              (function() {
              	function main() {
              // ====== DO NOT TOUCH ANYTHING ABOVE =====
              // ===== PLACE CUSTOM CODE UNDER THIS LINE =====
              		function patchStyle(css) {
                 var head, style;
                 head = document.getElementsByTagName('head')[0];
                 if (!head) { return; }
                 style = document.createElement('style');
                 style.type = 'text/css';
                 style.innerHTML = css;
                 head.appendChild(style);
              patchStyle('input;not([type=button]);not([type=file]);not([type=checkbox]);not([type=image]);not([type=radio]);not([type=reset]);not([type=search]);not([type=submit]){background-color; rgb(255, 255, 255); border-bottom-color; rgb(238, 238, 238); border-bottom-style; inset; border-bottom-width; 1px; border-collapse; separate; border-left-color; rgb(238, 238, 238); border-left-style; inset; border-left-width; 1px; border-right-color; rgb(238, 238, 238); border-right-style; inset; border-right-width; 1px; border-top-color; rgb(238, 238, 238); border-top-style; inset; border-top-width; 1px;}');
              // ===== KEEP CUSTOM CODE ABOVE THIS LINE =====
              // ===== DO NOT TOUCH ANYTHING BELOW =====
              	var script = document.createElement('script');
              	script.appendChild(document.createTextNode('('+ main + ') ();'));
              	(document.body || document.head || document.documentElement).appendChild(script);
                driven
                working with Safari 6[dev] as main browser
                I added GreaseKit to SketchUp Menu and wrote a userScript to intercept ALL WebDialogs to add the patch.
                It only affects input[type=text] even when it's not been declared. (e.g. at 3D Warehouse site)
                Here are some instructions and my userScript if anyones interested.
                You need to instal SIMBL and GreaseKit in these locations
                /Library/Application\ Support/SIMBL
                %(#4040BF)[/Library/Application\ Support/SIMBL/Plugins/GreaseKit.bundle
                ~/Library/Application Support/GreaseKit/apps.plist
                ~/Library/Application Support/GreaseKit/config.xml]
                ~/Library/Application\ Support/GreaseKit/inputPatch.user.js
                Edit:SCRIPT REMOVED -better version below
                add SketchUp to greaseKit from Safari Menu, then in SU Reload All UserScripts and Select 'InputPatch'
                that's it
                  Aerilius
                  You could carefully "alias" the WebDialog class in SketchUp, that means you add a script that is loaded first where you redefine the UI::WebDialog.open method so that it injects your JavaScript after the WebDialog has opened. Maybe like (untested):
                  class UI;;WebDialog
                    # this gives a new name to the method "show"
                    alias ;show_orig ;show
                    private ;show_orig
                    def show(&proc)
                      # this calls the original "show" method
                      show_orig(&proc){ proc.call }
                      execute_script(" /*your script*/ ")
                  However re-defining base classes is something that no published plugin should do.
                  • troyhomeT
                    troyhome
                    @petersaal said:
                    I found the same problem last week. The source of the problem is the Safari update that Apple pushed out last week (5.1.7). Here's a work-around for dynamic components: make the following edits in red to the manager.css and configurator.css files. (located in Library/Application Support/Google SketchUp 8/SketchUp/Tools/Dynamic Components/css)
                    In Manager.css:
                    .edit-field {
                    position: absolute;
                    border-top: 2px solid #3063C9;
                    border-left: 2px solid #3063C9;
                    border-right: 2px solid #A5C4FF;
                    border-bottom: 2px solid #A5C4FF;
                    background-color: white; font-size: 12px;
                    font-family: sans-serif;
                    width: 100%;
                    height: 100%;
                    overflow: hidden;
                    padding-left: 2px;
                    padding-top: 1px;
                    border: 1px solid #000000;
                    In Configurator.css:
                    .config-field {
                    width: 100%;
                    font-size: 11px;
                    font-family: tahoma, sans-serif;
                    height: 22px;
                    .config-field-readonly {
                    width: 100%;
                    font-size: 11px;
                    height: 22px;
                    background-color: threedface;
                    Thank you!! this worked for me!!!
                    IOviz.com
                    SU Pro 2024 PC
                    • troyhomeT
                      troyhome
                      Thanks guys!
                      I managed to get all the dialog boxes of 1001bit fixed following the suggestions on the css;
                      [attachment=0:1pgsvrh4]<!-- ia0 -->black_textbox_patch.jpg<!-- ia0 -->[/attachment:1pgsvrh4]
                      It's a lot of work to edit all the html files, but at least the problem is solved. 😄
                      Cheers!
                      what files exactly did you modify?
                      IOviz.com
                      SU Pro 2024 PC
                      • P
                        phaseOne
                        To avoid any confusion over installation of the script, I created this guide:
                        1. Download SIMBL
                        2. Unzip the file
                        3. Launch the SIMBL-..*.pkg installer
                        4. Download GreaseKit
                        5. Mount the GreaseKit-..dmg image
                        6. Copy GreaseKit.bundle to /Library/Application Support/SIMBL/Plugins/
                        7. Launch Safari
                        8. Select the GreaseKit item in the menubar
                          http://grab.bovie.me/eUVw
                        9. Select Manage Applications...
                          http://grab.bovie.me/eUVy
                        10. Add Sketchup to the application list
                          http://grab.bovie.me/eUVI
                        11. Quit Safari
                        12. Download inputPatch.user.js created by driven (his original post)
                        13. Copy inputPatch.user.js to **~/**Library/Application Support/GreaseKit/
                        14. Launch SketchUp
                        15. Select inputPatch from the GreaseKit menu
                          http://grab.bovie.me/eUW4
                        Your text boxes are now white!
                          driven
                          hi Phaseone,
                          Welcome to SCF and thanks for the guide on how to instal my GreaseKit solution.
                          It made me revisit the issue and I realise now that there is an even easier way to do this. [i.e. without SIMBL, GreaseKit or js injection]
                          In an earlier post from Aerilius
                          Another idea, would a WebView also accept a user stylesheet (that would override the default background in all websites+webdialogs in SketchUp)?
                          Yes, Safari does it from the preference menu and I now have it working in SU, but what's the simplest way to share the 'how to'.
                          First you need a css file containing the patch code, in a place SU can find. So copy paste this into Ruby Console and hit return.
                          directory='/Library/Application Support/Google SketchUp 8/SketchUp/plugins/__InputPatch/'
                          Dir;;mkdir(directory) unless File.exists?(directory)
                          filename='inputPatch.css'
                          File.open(directory + filename, 'w') do |iP|
                          iP.puts <<PATCH
                          PATCH
                          it makes a folder + file in /Library/Application Support/Google SketchUp 8/SketchUp/plugins/
                          Then if you have Pro8 copy/paste and return this.
                          `defaults write ~/Library/Preferences/com.google.sketchuppro8.plist WebKitUserStyleSheetEnabledPreferenceKey -bool True`
                          `defaults write ~/Library/Preferences/com.google.sketchuppro8.plist WebKitUserStyleSheetLocationPreferenceKey '/Library/Application Support/Google SketchUp 8/SketchUp/plugins/__InputPatch/inputPatch.css'`
                          or for free try
                          `defaults write ~/Library/Preferences/com.google.sketchupfree8.plist WebKitUserStyleSheetEnabledPreferenceKey -bool True`
                          `defaults write ~/Library/Preferences/com.google.sketchupfree8.plist WebKitUserStyleSheetLocationPreferenceKey '/Library/Application Support/Google SketchUp 8/SketchUp/plugins/__InputPatch/inputPatch.css'`
                          Restart SU
                          You only need to do this once, and all your input boxes in SU will work correctly [without editing any files]
                          If the problem is resolved in the future you can just bin the __inputPatch Folder
                            mwm5053
                            thanks John for this fix. Works great
                            Walt
                            2011 iMac
                            SU 2015 Pro, 2017 Make
                            V2 Twilight
                            macOS Sierra 10.12.5
                            • nickN
                              nick
                              Thanks John
                              That's magic; a very elegant solution.
                              Nick
                              • mariochaM
                                mariocha
                                YEaH !!! 😄 John !
                                Corrected !
                                I had to do it twice.
                                (The cursor jumps at the end of the pasted text, so one does not see at once what has just been pasted in the Ruby console input field.)
                                %(#008000)[Mario C.
                                • solid-woodS
                                  solid-wood
                                  @driven said:
                                  hi Phaseone,
                                  Restart SU
                                  I have the same problem as a lot of others, I guess. Mac OS 10.6.8 + SU Pro 8.0.15157.
                                  Tried your solution, and it works on DC's, but not on everything...or at least not with Fredo6 Tools, SU Clock etc etc.
                                  I had the problem with 1001Bit plug but with the upgrade it was fixed.
                                  Is it that the maker of the plugin does something wrong when writing the code (miss something)?
                                  After your fix I seem to have no problem with DC's. That helps a lot - THANKS!
                                  Is there something else to do? Tried your fix many times to make sure I did it right. Think I did.
                                  Look at the result (pic). Is that "nil" OK?? ...or am I doing something when pasting?
                                  Do you know if a full upgrade to Mountain Lion helps? Does anyone know?
                                  Thankful for some help.
                                  Cheers
                                    driven
                                    Mountain Lion and SU8 Maintenance release 'M4' appears to have fixed the blackouts here.
                                    I renamed my 'fix' folder to disable it and all I have checked works.
                                    ML is much better IMHO.
                                    • solid-woodS
                                      solid-wood
                                      Hi John,
                                      Thanks! Can You tell me where to find "M4"? When I download from Trimble, it's only the "M3"...?????
                                      When did they release M4, I downloaded today, 20120904, and it is still the same.
                                      Cheers
                                      Jan
                                        http://www.sketchup.com/intl/en/download/index.html should get you v8M4 ?
                                        • Dan RathbunD
                                          Dan Rathbun
                                          It will take the "team" awhile to get the localized language releases ready.
                                          • solid-woodS
                                            solid-wood
                                            I guess Your right. I still get an older version....
                                            Waiting for the ice-cream is something that I always had a hard time for.
                                            Cheers,
                                            JF
                                            BTW You guys are fantastic....T, D, TT, F, ....well You know who I think of.
                                            A BIG BIG hand for all of You!
                                            THANK YOU SO MUCH
                                            • 2 / 3
