    Webdialogs: inputbox shows black background (sketchup webkit
    50 Posts 22 Posters 39.8k Views 22 Watching
      driven
      I'm using the developer release of Safari 6 and the problem remains in SU.
      Safari's User Agent Style Sheet, handles the input border correctly but SU doesn't use that, so it's a WebCore update that's needed. i'm looking for a patch at the moment.
        mwm5053
        Thanks John I'd like to stay updated on this as I like to stay updated on all software.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          gohch
          Thanks guys!
          I managed to get all the dialog boxes of 1001bit fixed following the suggestions on the css;
          patch in html file to fix the black textbox
          It's a lot of work to edit all the html files, but at least the problem is solved. 😄
          Cheers!
          • RichMorinR Offline
            RichMorin
            I grabbed a copy of Pacifist, but I can't find a copy of Safari 5.1.5 to install.
            For example, the page http://support.apple.com/kb/DL1070
            has a Download button that leads to http://www.apple.com/safari/download/.
            However, this page only supports downloading of Safari 5.1.7.
            Help?
              troypiggo
              I found it here:
              http://mac.oldapps.com/safari.php?old_safari=813
              This is not my signature. I type it at the end of every message for quality control.
                driven
                update to my investigation.
                WebView uses a different version of Webkit than Safari (and not just in SU) and I can't find a way to change the userAgent from within SU, so been trying another approach.
                dlg.execute_script %(function addGlobalStyle(css) {
                   var head, style;
                   head = document.getElementsByTagName('head')[0];
                   if (!head) { return; }
                   style = document.createElement('style');
                   style.type = 'text/css';
                   style.innerHTML = css;
                   head.appendChild(style);
                addGlobalStyle('input {border; 1px solid gray;}'))
                This works if you know the name of the dialog, but how can I get that with ruby to apply a global patch. Is it possible to get a new dialog name in ruby.
                Using WebInspector to add the JS I can also exclude type with
                addGlobalStyle('input, input;not[type="submit"];not[type="button"];not[type="file"];not[type="search"]{border; 1px solid gray;}'))
                , but that returns true and fails in RubyConsole
                  @aerilius said:
                  UI::WebDialog.open
                  You mean UI::WebDialog.show ?
                    Aerilius
                    fixed it.
                      driven
                      @aerilius said:
                      fixed it.
                      hi, I'm getting
                      Error: #<SyntaxError: (eval):24: compile error (eval):15: parse error, unexpected '(' alias(:show_orig, :show) ^ (eval):20: both block arg and actual block given> (eval):24
                      I'd much rather use a small amount of ruby to 'fix' the input problem
                      cheers for your efforts
                      • Dan RathbunD Offline
                        Dan Rathbun
                        @Aerilius
                        It's much more complicated than that.
                        I have a patch that does similar.. (and more,) but we can't release such a thing without Boulder's blessing.
                        We have realized, that it's best not to show how to modify the API modules and classes. Some newbie's just run with it and start hacking away, and worse. (Yes we've all been guilty of openly discussing such things in the past. I'm sure I have. Sometimes we forget the "kids" come along and read what we've written later.)
                        Anyway... you don't need the literal block when you pass to the orig method, as the wrapper method has already converted any block argument to a Proc object.
                        So instead you do:
                        block_given? ? show_orig(&proc) : show_orig()
                        But it will not work like that, for the same reasons that the current API show(), show_modal() and set_on_close() block form methods do not work on Mac. (The webpage is never ready when Ruby executes the block.)
                        I'm not here much anymore.
                          driven
                          Improved my 'GreaseKit' UserScript using a file from Dan (cheers)
                          with safari Css style on input borders
                          // ==UserScript==
                          // @name           inputPatch
                          // @author	       driven
                          // @namespace      http://drivenupthewall
                          // @description    fixes webkit input boxes in SketchUp.
                          // @include        *
                          // ==/UserScript==
                          (function() {
                          	function main() {
                          // ====== DO NOT TOUCH ANYTHING ABOVE =====
                          // ===== PLACE CUSTOM CODE UNDER THIS LINE =====
                          		function patchStyle(css) {
                             var head, style;
                          patchStyle('input;not([type=button]);not([type=file]);not([type=checkbox]);not([type=image]);not([type=radio]);not([type=reset]);not([type=search]);not([type=submit]){background-color; rgb(255, 255, 255); border-bottom-color; rgb(238, 238, 238); border-bottom-style; inset; border-bottom-width; 1px; border-collapse; separate; border-left-color; rgb(238, 238, 238); border-left-style; inset; border-left-width; 1px; border-right-color; rgb(238, 238, 238); border-right-style; inset; border-right-width; 1px; border-top-color; rgb(238, 238, 238); border-top-style; inset; border-top-width; 1px;}');
                          // ===== KEEP CUSTOM CODE ABOVE THIS LINE =====
                          // ===== DO NOT TOUCH ANYTHING BELOW =====
                          	var script = document.createElement('script');
                          	script.appendChild(document.createTextNode('('+ main + ') ();'));
                          	(document.body || document.head || document.documentElement).appendChild(script);
                            driven
                            working with Safari 6[dev] as main browser
                            I added GreaseKit to SketchUp Menu and wrote a userScript to intercept ALL WebDialogs to add the patch.
                            It only affects input[type=text] even when it's not been declared. (e.g. at 3D Warehouse site)
                            Here are some instructions and my userScript if anyones interested.
                            You need to instal SIMBL and GreaseKit in these locations
                            /Library/Application\ Support/SIMBL
                            %(#4040BF)[/Library/Application\ Support/SIMBL/Plugins/GreaseKit.bundle
                            ~/Library/Application Support/GreaseKit/apps.plist
                            ~/Library/Application Support/GreaseKit/config.xml]
                            ~/Library/Application\ Support/GreaseKit/inputPatch.user.js
                            Edit:SCRIPT REMOVED -better version below
                            add SketchUp to greaseKit from Safari Menu, then in SU Reload All UserScripts and Select 'InputPatch'
                            that's it
                              Aerilius
                              You could carefully "alias" the WebDialog class in SketchUp, that means you add a script that is loaded first where you redefine the UI::WebDialog.open method so that it injects your JavaScript after the WebDialog has opened. Maybe like (untested):
                              class UI;;WebDialog
                                # this gives a new name to the method "show"
                                alias ;show_orig ;show
                                private ;show_orig
                                def show(&proc)
                                  # this calls the original "show" method
                                  show_orig(&proc){ proc.call }
                                  execute_script(" /*your script*/ ")
                              However re-defining base classes is something that no published plugin should do.
                              • troyhomeT Offline
                                troyhome
                                @petersaal said:
                                I found the same problem last week. The source of the problem is the Safari update that Apple pushed out last week (5.1.7). Here's a work-around for dynamic components: make the following edits in red to the manager.css and configurator.css files. (located in Library/Application Support/Google SketchUp 8/SketchUp/Tools/Dynamic Components/css)
                                In Manager.css:
                                .edit-field {
                                position: absolute;
                                border-top: 2px solid #3063C9;
                                border-left: 2px solid #3063C9;
                                border-right: 2px solid #A5C4FF;
                                border-bottom: 2px solid #A5C4FF;
                                background-color: white; font-size: 12px;
                                font-family: sans-serif;
                                width: 100%;
                                height: 100%;
                                overflow: hidden;
                                padding-left: 2px;
                                padding-top: 1px;
                                border: 1px solid #000000;
                                In Configurator.css:
                                .config-field {
                                width: 100%;
                                font-size: 11px;
                                font-family: tahoma, sans-serif;
                                height: 22px;
                                .config-field-readonly {
                                width: 100%;
                                font-size: 11px;
                                height: 22px;
                                background-color: threedface;
                                Thank you!! this worked for me!!!
                                IOviz.com
                                SU Pro 2024 PC
                                • troyhomeT Offline
                                  troyhome
                                  Thanks guys!
                                  [attachment=0:1pgsvrh4]<!-- ia0 -->black_textbox_patch.jpg<!-- ia0 -->[/attachment:1pgsvrh4]
                                  Cheers!
                                  what files exactly did you modify?
                                  IOviz.com
                                  SU Pro 2024 PC
                                    phaseOne
                                    To avoid any confusion over installation of the script, I created this guide:
                                    1. Download SIMBL
                                    2. Unzip the file
                                    3. Launch the SIMBL-..*.pkg installer
                                    4. Download GreaseKit
                                    5. Mount the GreaseKit-..dmg image
                                    6. Copy GreaseKit.bundle to /Library/Application Support/SIMBL/Plugins/
                                    7. Launch Safari
                                    8. Select the GreaseKit item in the menubar
                                      http://grab.bovie.me/eUVw
                                    9. Select Manage Applications...
                                      http://grab.bovie.me/eUVy
                                    10. Add Sketchup to the application list
                                      http://grab.bovie.me/eUVI
                                    11. Quit Safari
                                    12. Download inputPatch.user.js created by driven (his original post)
                                    13. Copy inputPatch.user.js to **~/**Library/Application Support/GreaseKit/
                                    14. Launch SketchUp
                                    15. Select inputPatch from the GreaseKit menu
                                      http://grab.bovie.me/eUW4
                                    Your text boxes are now white!
                                      driven
                                      hi Phaseone,
                                      Welcome to SCF and thanks for the guide on how to instal my GreaseKit solution.
                                      It made me revisit the issue and I realise now that there is an even easier way to do this. [i.e. without SIMBL, GreaseKit or js injection]
                                      In an earlier post from Aerilius
                                      Another idea, would a WebView also accept a user stylesheet (that would override the default background in all websites+webdialogs in SketchUp)?
                                      Yes, Safari does it from the preference menu and I now have it working in SU, but what's the simplest way to share the 'how to'.
                                      First you need a css file containing the patch code, in a place SU can find. So copy paste this into Ruby Console and hit return.
                                      directory='/Library/Application Support/Google SketchUp 8/SketchUp/plugins/__InputPatch/'
                                      Dir;;mkdir(directory) unless File.exists?(directory)
                                      filename='inputPatch.css'
                                      File.open(directory + filename, 'w') do |iP|
                                      iP.puts <<PATCH
                                      PATCH
                                      it makes a folder + file in /Library/Application Support/Google SketchUp 8/SketchUp/plugins/
                                      Then if you have Pro8 copy/paste and return this.
                                      `defaults write ~/Library/Preferences/com.google.sketchuppro8.plist WebKitUserStyleSheetEnabledPreferenceKey -bool True`
                                      `defaults write ~/Library/Preferences/com.google.sketchuppro8.plist WebKitUserStyleSheetLocationPreferenceKey '/Library/Application Support/Google SketchUp 8/SketchUp/plugins/__InputPatch/inputPatch.css'`
                                      or for free try
                                      `defaults write ~/Library/Preferences/com.google.sketchupfree8.plist WebKitUserStyleSheetEnabledPreferenceKey -bool True`
                                      `defaults write ~/Library/Preferences/com.google.sketchupfree8.plist WebKitUserStyleSheetLocationPreferenceKey '/Library/Application Support/Google SketchUp 8/SketchUp/plugins/__InputPatch/inputPatch.css'`
                                      Restart SU
                                      You only need to do this once, and all your input boxes in SU will work correctly [without editing any files]
                                      If the problem is resolved in the future you can just bin the __inputPatch Folder
                                        mwm5053
                                        thanks John for this fix. Works great
                                        Walt
                                        2011 iMac
                                        V2 Twilight
                                        • nickN Offline
                                          nick
                                          Thanks John
                                          That's magic; a very elegant solution.
                                          Nick
                                          • mariochaM Offline
                                            mariocha
                                            YEaH !!! 😄 John !
                                            Corrected !
                                            I had to do it twice.
                                            (The cursor jumps at the end of the pasted text, so one does not see at once what has just been pasted in the Ruby console input field.)
                                            %(#008000)[Mario C.
                                            • 2 / 3
