    SU 9 Wishlist
    436 Posts 99 Posters 152.1k Views 99 Watching
    • fouronethirtyF Offline
      fouronethirty
      im going to wait for sketchup 9 to come out, hehehe, come on su 9, show us what you got
        gistman
        As I sit here waiting for SU to finish it's current operation, I've had time to think about signing on and posting a wish... I was wishing it would take advantage of 64bit OS... How hard can that be? It's really really difficult to sit here and watch one core bang away while the other 15 just sit there idle... * sigh *
          64bit OS has nothing to do with number of cores used. 64bit is about being able to address more memory. And unless you are using a render that runs within SketchUp's own process that you're unlikely to have any lack of memory while using SketchUp.
          Number of cores - yes, this is in fact a hard thing to do. Very hard. Most processes simply cannot be split into running on multiple cores, the task usualy require that it's done in a linear fashion on a single core. When you see other 3d application boast about multi-core support it's a pretty good bet that the application has a render engine built in and it is that which make use of all the cores. While you model though, they won't be using all your cores.
          • pbacotP Offline
            Isn't view generation (orbiting etc.) a sort of rendering? Is it likely there is anything another core could be handling to take the load off?
              Best thing is not to speculate or demand a specific technical implementation - as they cloak the real request: better performance. Don't get caught up in whether a buzzword can be applied - but trust that they know what they do. They are programmers - they worked on the applications for years. If throwing multiple cores into it had been easy it would have been done. If you do some search on multi-core programming - then you'll find lots of information to why it's not easy.
              • H Offline
                HFM
                Don't know if it has been mentioned yet, but I would love the option where Styles/Profiles is applied to the whole model instead of every component/group. At this point I sometimes explode the entire model, just to get a nice NPR output from Sketchup.
                Also, the option to 'tell' Sketchup which object is on top of the other. This to get rid of Z-fighting and maybe even see through style lines.
                Just my two cents ๐Ÿ˜„
                • N Offline
                  numerobis
                  Yes, maybe it's not easy... but it looks like it will be the only way to get real perfomance improvements in future versions... since this is the way CPUs evolve since a few years. ๐Ÿ˜’
                  And even if it is not possible to use multiple cores for modeling or geometry display, it could be used at least to speed up "closed" operations like rendering images or saving in the background.
                  It's really a joke that you have to open multiple versions of the same file to speed up rendering an animation (i found a limit somewhere at 8 instances...) - why can't this be done internally?!?
                  btw... i would really like to hear the explanation why an autosave takes 10 times lomger than a normal save... really annoying ๐Ÿ˜’
                    ArCAD-UK
                    Please can we have Generate Report CSV linked to the model units or at least give us a basic option of output in inches / centimetres. It's a real pain having to convert everything to metric just to do quick quantity checks.
                      Anton_S
                      Anyways who is working on creating SU9?
                        An infinite number of monkeys in front of keyboard typrewriters.
                          Anton_S
                          ...which, are at Zoo. ๐Ÿ˜’
                            gzotti
                            I would like to see a skybox as parallax-invariant background that is also not trimmed off by the far Z plane. Either from an equirectangular panorama or six cube faces. Transparency to be allowed (so the blue-ish sky comes through, and the sun and shadow algorithms should take the skybox into account. Or maybe even a Preetham-style sky colour skybox with a "sun" with lens flare?
                              marcuus
                              I do not know if you post here is still valid or whether the terms have already expired, but I read just now and, among my greatest desires for a great leap of scketch up there would be a chance to make it compatible
                              with the cam system, such as the Tebis for example, or others that can recognize,
                              as the 3D modeling is not born just to take pictures or static images
                              but is just a coin โ˜€
                                lapx
                                Rotation input in the material dialogue box please.
                                  kwistenbiebel
                                  good suggestion
                                    mpowell1234567890
                                    I have a few wishes for Sketchup 9 "free":
                                    1. The follow-me tool that can go over crossed lines.
                                    2. Push-pull on curved objects.
                                      ๐Ÿ˜„
                                    • john2J Offline
                                      john2
                                      I have a long wishlist ๐Ÿ˜‰
                                      1. Multiple windows of files interface, so that new SU doesnโ€™t have to be opened every time.
                                      2. Thumbnail support in folder containing SketchUp files for 64 bit windows 7 operating system
                                      3. Better 2d export facility with layers support. This will help in efficient post processing in AutoCAD.
                                      4. Ability to export PDFs (in layout as well as SU) with shadows as a vector and not a raster.
                                      5. Feature to control lineweight for different layers or selected objects within SketchUp itself.
                                      6. Solid cut through โ€“ will give users an option the moment they put a door on a wall, it cuts a hole throughout and not on a face particularly. The following options can be there.
                                      7. Collision detection (that can be turned on or off) so that furniture donโ€™t punch themselves through a surface
                                      8. Customized snap options like AutoCAD.
                                      Midpoint
                                      Nearest
                                      Perpendicular
                                      Endpioint
                                      Tangent
                                      Center
                                      Node , etc.
                                      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                        As a V-Ray user you do not want this. MDI would make multiple models share the same host process - and also memory.
                                        @john2 said:
                                        1. Thumbnail support in folder containing SketchUp files for 64 bit windows 7 operating system
                                        +1!!!!
                                          ArCAD-UK
                                          @john2 said:
                                          1. Feature to control lineweight for different layers or selected objects within SketchUp itself.
                                            Some good suggestions but please don't burden SU simple efficiency with unnecessary Aut*CAD wannabe features like this.
                                            jhauswirth
                                            +1!!!![/quote]
                                            It WAS really nice having thumbnails in 64-bit Windows.....
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 21
                                            • 22
                                            • 15 / 22
