    V-ray rendering problem
    renderpluginsextensions
    42 Posts 10 Posters 10.7k Views 10 Watching
    • eidam655E Offline
      eidam655
      @blackmastah said:
      I would like to see what's happening with couple of the copied IES lights, couple of the rectangular lights and couple of the emissive lights. Try also to copy the spotlight object. (not only the lights and the emissive layer).
      hey, i'm not sure i'm following your instructions correctly, so it would be awesomely helpful, if you recorded your process (with CamStudio for example), put it on youtube and i/we could see, where it crashes for you. try as i may, i'm still not able to reproduce your bug πŸ˜•
      I'm using SketchUp 2017, V-Ray 3.4
        BlackMastah
        Hi.
        I just recorded a short clip that you can see part of my problem. The flick i'm talking about and the lack of rendering. I'm uploading it now. When it's ready i'll post here the link from youtube, so you can all see and try the things.
        If it's not clear again.. I can make more clips so you can see the problem from different angles.
          The flickering is coming from V-Ray being done processing the scene and SketchUp window becomes responsive again - where it updates the window. The rendering not starting after it's done processing the scene is probably some bug. I bet if you open the Ruby Console before you hit render you will see error messages appearing.
          • eidam655E Offline
            eidam655
            BlackMastah, so far i'm experiencing the same things as you, but the Task Manager is showing 100% CPU activity, so although the window doesn't redraw, the light cache is being built at this stage (and it always takes the more time the more lights you have in the scene), so i wouldn't say something is wrong. it just takes time.
              The problem appear, from the video, that V-Ray doesn't start rendering after the processing.
              • eidam655E Offline
                eidam655
                that's yet to be confirmed by looking at the task manager / cpu usage. my framebuffer isn't redrawn either.
                  BlackMastah
                  Okay. I can see there's some bug. That's nice that you confirmed that. Maybe i'm dumm, but... What now?!
                    BlackMastah
                    Are we stuck? πŸ˜•
                    • eidam655E Offline
                      eidam655
                      did you check the ruby console output? did you check your cpu usage with task manager?
                        Yes, please check both there. Particularly the Ruby Console.
                          BlackMastah
                          Guys, i don't understand HOW to menage with the problem and are you talking to me? WHERE is the problem? In the file or.. In the program? I can't figure that out. And with the CPU, it's obvious that there is some bug, but that's not enough and that wasn't my question. The quesion is HOW to deal with that so i can finish with the file? To put the IES lights, to finish everything else and to RENDER...
                          • eidam655E Offline
                            eidam655
                            to know where the problem is, it would be useful to check the ruby console output, so we could be more helpful and accurate πŸ˜„
                            try creating a new file, with a big box and copy the lights from the original file to the new one and see if this problem persists. or try to purge your original file and do a test render with the room and lights only.
                            i was curious about the cpu usage because sometimes it happens that the rendering continues, but the window is not redrawn, so i thought maybe this was the case.
                            other than that we (or at least i) have no idea how to solve this, that's why those pieces of extra info from you could be useful.
                              Open the Ruby Console before you start to render and watch for error messages that might appear. They will probably give us a clue to why your render fails.
                                ccs1987
                                I ma having the same problem. i found out mine it's with the retengular lighting that i have with is small square and arrayed 12 x 15 lights for the whole building. after i delete the light it starts to render.but if i am with the light it dont render..what's the problem..is it grouping layering for retengular lights are making bugs for vray?
                                Sketchup 8 pro
                                Vray
                                Intel Xeon W3520 2.67Ghz
                                12Gb Ram
                                Nvdia Quadro FX 1800
                                • dkendigD Offline
                                  dkendig
                                  If you convert the light group to a component, it will prevent the scene from rendering. We see that happen a lot, people want to have instances of the same light so they just convert the group, thinking everything will be fine. In order to have that functionality though, you need to place the light group inside of a component, rather than converting the group to a component.
                                  Devin Kendig
                                  Developer
                                    Feature request for the nexy Version? It is an intuitive thing to convert to Component.
                                      ccs1987
                                      wow. i did that mistake no wonder it wont render. making component perhaps alter the data of the light..thx man for waking me up
                                      Sketchup 8 pro
                                      Vray
                                      12Gb Ram
                                      • andybotA Offline
                                        andybot
                                        That's odd, I find I've never run into that problem. I usually have some kind of light fixture model and I make my vray light part of that component. I could see this option being useful for an area light (but I usually draw a line with my area light to tell me which direction it's shining...) Hmm, I wonder why changing to a component messes it up.
                                        • dkendigD Offline
                                          dkendig
                                          we didn't want our lights to clutter up the component definitions, so we use groups. When we go to look for lights in the scene, we don't check any components, we only check groups. You can put the light group in the component, that's fine. You can not convert it to a component directly though, or we will not know what to do with it.
                                          Devin Kendig
                                          Developer
                                            cuttingedge
                                            Yes, directly converting vray light to component will cause problem, I often just create a tiny line or a point (often the center point) with the vray light before i make them component. Once an instance then it can be grouped and converted to other components. Often, I experience a crash or not being able to start a render if I use maps larger than 1 MB, be it diffuse, reflection, opacity or most especially displacement maps. Other days, there are just problematic geometry that will cause the problem.Detecting which one is a pain especially for a large model. Most likely its from imported blocks.
                                            • 2 / 3
