    V-ray rendering problem
    renderpluginsextensions
    42 Posts 10 Posters 10.1k Views 10 Watching
    • eidam655E Offline
      eidam655
      BlackMastah, so far i'm experiencing the same things as you, but the Task Manager is showing 100% CPU activity, so although the window doesn't redraw, the light cache is being built at this stage (and it always takes the more time the more lights you have in the scene), so i wouldn't say something is wrong. it just takes time.
      I'm using SketchUp 2017, V-Ray 3.4
        The problem appear, from the video, that V-Ray doesn't start rendering after the processing.
        • eidam655E Offline
          eidam655
          that's yet to be confirmed by looking at the task manager / cpu usage. my framebuffer isn't redrawn either.
            BlackMastah
            Okay. I can see there's some bug. That's nice that you confirmed that. Maybe i'm dumm, but... What now?!
              BlackMastah
              Are we stuck? πŸ˜•
              • eidam655E Offline
                eidam655
                did you check the ruby console output? did you check your cpu usage with task manager?
                  Yes, please check both there. Particularly the Ruby Console.
                    BlackMastah
                    Guys, i don't understand HOW to menage with the problem and are you talking to me? WHERE is the problem? In the file or.. In the program? I can't figure that out. And with the CPU, it's obvious that there is some bug, but that's not enough and that wasn't my question. The quesion is HOW to deal with that so i can finish with the file? To put the IES lights, to finish everything else and to RENDER...
                    • eidam655E Offline
                      eidam655
                      to know where the problem is, it would be useful to check the ruby console output, so we could be more helpful and accurate πŸ˜„
                      try creating a new file, with a big box and copy the lights from the original file to the new one and see if this problem persists. or try to purge your original file and do a test render with the room and lights only.
                      i was curious about the cpu usage because sometimes it happens that the rendering continues, but the window is not redrawn, so i thought maybe this was the case.
                      other than that we (or at least i) have no idea how to solve this, that's why those pieces of extra info from you could be useful.
                        Open the Ruby Console before you start to render and watch for error messages that might appear. They will probably give us a clue to why your render fails.
                          ccs1987
                          I ma having the same problem. i found out mine it's with the retengular lighting that i have with is small square and arrayed 12 x 15 lights for the whole building. after i delete the light it starts to render.but if i am with the light it dont render..what's the problem..is it grouping layering for retengular lights are making bugs for vray?
                          Sketchup 8 pro
                          Vray
                          Intel Xeon W3520 2.67Ghz
                          12Gb Ram
                          Nvdia Quadro FX 1800
                          • dkendigD Offline
                            dkendig
                            If you convert the light group to a component, it will prevent the scene from rendering. We see that happen a lot, people want to have instances of the same light so they just convert the group, thinking everything will be fine. In order to have that functionality though, you need to place the light group inside of a component, rather than converting the group to a component.
                            Devin Kendig
                            Developer
                              Feature request for the nexy Version? It is an intuitive thing to convert to Component.
                                ccs1987
                                wow. i did that mistake no wonder it wont render. making component perhaps alter the data of the light..thx man for waking me up
                                Sketchup 8 pro
                                Vray
                                12Gb Ram
                                • andybotA Offline
                                  andybot
                                  That's odd, I find I've never run into that problem. I usually have some kind of light fixture model and I make my vray light part of that component. I could see this option being useful for an area light (but I usually draw a line with my area light to tell me which direction it's shining...) Hmm, I wonder why changing to a component messes it up.
                                  • dkendigD Offline
                                    dkendig
                                    we didn't want our lights to clutter up the component definitions, so we use groups. When we go to look for lights in the scene, we don't check any components, we only check groups. You can put the light group in the component, that's fine. You can not convert it to a component directly though, or we will not know what to do with it.
                                    Devin Kendig
                                    Developer
                                      cuttingedge
                                      Yes, directly converting vray light to component will cause problem, I often just create a tiny line or a point (often the center point) with the vray light before i make them component. Once an instance then it can be grouped and converted to other components. Often, I experience a crash or not being able to start a render if I use maps larger than 1 MB, be it diffuse, reflection, opacity or most especially displacement maps. Other days, there are just problematic geometry that will cause the problem.Detecting which one is a pain especially for a large model. Most likely its from imported blocks.
                                        Kris7
                                        Hello everyone,,,I'm having a strange problem while rendering in sketchup. I m using Vray 1.48.49 and sketchup pro 8. I used .vismat materials for the scenes and vray used to render well(m not a professional but good enough for me) but it doesnt do so anymore. I searched the forum for help and did some techniques like purging unused materails in the editor and turning off .vri in the options. but it ddnt work....if anyone can help
                                        after
                                          rspierenburg
                                          I looks like something odd has been checked in your Frame Buffer that is changing the colors. I can't quite think of exactly which setting it would be. In any case, 1.48.49 is VERY dated and had numerous problems, you should definitely be looking at Vray 2.0
                                          Rob
                                            Kris7
                                            Tnx for the response Rob...but is it really about Vray version or something else i mean materials or any settings in the vray options????
                                            • 2 / 3
