    TexSky VS HDRi comparison
    renderpluginsextensions
    12 Posts 5 Posters 5.9k Views 5 Watching
    • eidam655E Offline
      eidam655
      thanks valerostudio, that's exactly the tutorial i followed and the settings are the same πŸ˜„
      the only diference was that i actually did use out-of-the-box hdri image, but had to increase HSph to 100 and Samples to 55 to get rid of the splotches (these numbers are the same in both scenes, but with Sky lighting only i can reduce the numbers to 50/25).
      the advantage is that i can retain using the camera's exposure controls.
      I'm using SketchUp 2017, V-Ray 3.4
        I use HDRI's from time to time - if I have many views in different directions. If it's one or two directions I often just Photoshop. But lately I've been having some nice results from combining Sky and HDRI for GI source - allowing me to get much softer shadows with the nice colours HDRI gives.
        • eidam655E Offline
          eidam655
          thomthom, do you have any examples available?
          when you mention the soft shadows - i actually forgot that my comparison is viable only in the 'sunny day' situations. if the sky was overcast, soft shadows might actually come in handy... hmm. more testing involving real-life photography needed.
            Trying to remember what projects I used the technique with.... πŸ˜•
            • V Offline
              valerostudio
              I hope that Dome Light is in the works for the next release. If you have ever used this feature in Max along with a nice HDRI, like Peter Gunthrie's, the results are fantastic! Well worth the minimal cost. http://3docean.net/user/paguthrie/portfolio
              • V Offline
                valerostudio
                I did try out using higher IR subdiv values with an unblurred HDRI and it does seem to work well. I did test it with a Peter Gunthrie file and it looks really nice. I guess I always was under the impression that you could not do this without getting splotches. It may also depend on the resolution of the HDRI as well.
                • eidam655E Offline
                  eidam655
                  valerostudio, that's exactly what i found out.
                  at first i had a scene set up with vray sky only and then decided to put the hdri into the same scene following familiar Fernando's settings. it turned out to be way too bright, so i had to began messing around with the settings.
                  so first thing i tried was just to create a blurred version - to my surprise, it didn't erase the splotches.
                  then i tried to scale it down - splotches gone, severely underexposed (and i believe this is the reason Fernando suggests to give up vray's physical camera exposure controls, the iso/shutter/f-stop values would not make sense if they had to be set to extremes).
                  while the test images were rendering i was reading the vray documentation and realized how HSph value actually works (determines the lighting half-sphere subdivisions) - so to retain exposure controls (to be able to use the hi-res hdri) and to get rid of splotches (as blurring the image didn't work) i increased those HSph and Samples values.
                  the physics worked. although the rendering time got quite severely prolonged.
                  i'll try 3DSMax's Dome Light, when i'll have time again. sounds like a simplification of matters.
                  PS: i tested it with PGuthrie's "1325" HDRi map, which comes at ~7k px width i think.
                  • V Offline
                    valerostudio
                    I think the reasoning behind the workaround with blurring the HDRI and using it along with VRSky is to save on render times. Increasing those IR map subdiv increase times dramatically. You need to be around 100 in order for the splotches to clean up. If you use a blurred HDRI, you can use lower values like 35 and still get good lighting results. Dome light solves this because the HDRI is mapped to a dome close to your model, when you an HDRI as an environment, its mapped to a giant dome that lives around SU space, and this is why you end up with splotches.
                    • edenuxE Offline
                      edenux
                      I have a problem which is close to this topic. My background is too close to the object. How can I minimize or zoom it out? πŸ˜•
                      Want to see more? Visit my facebook page: https://www.facebook.com/Edvisualisation
                      • panixiaP Offline
                        panixia
                        mmm.. maybe you can try to resize the model.. not sure.. πŸ˜•
