    Terrain from contours - improve on native 'from contours'?
    99 Posts 18 Posters 32.7k Views 18 Watching
    • fredo6F
      @brookefox
      I reworked my experimental plugin to adapt to the rectilinear closure of contours.
      Here is the result on a rectangular mesh. I had to fix 2 contours which were not perfectly aligned with other in their rectilinear portion.
      Contours Brookefox - TopoShaper.skp
      It is still slow, and anyway, if I pursue, the methods to improve the generation of terrain will add up calculation time, in particular:
      • Use triangulation instead of rectangular mesh (more exactly something like constrained Delaunay)
      • use a more advanced interpolation technique to get smoother transitions
      PS: I guess that Trimble will soon add this type of functionality as part of Sketchup (or with a bridge to an external program).
      • EarthMoverE
        EarthMover
        Fredo, I don't think that is slow at all for what it is doing. This tool has been something I've wanted from day one using Sketchup. I beg you to tidy it up and release it. In the meantime, I could beta test it for you. πŸ˜‰
        Content Creator at Skapeup
        • fredo6F
          @brookefox and EarthMover,
          Thanks for the feedback. I'll see if I can release something beta in the coming days.
          • brookefoxB
            brookefox
            Fredo, I wish I had something more helpful to say than 'looks great', but that maybe is a good thing. Perhaps the other fellows will stop back by, they seem to have much more experience than I have. As far as interest in and good use for such a plugin, I would say most definitely.
            Are the topmost contours supposed to be rounded in their inside or just left as a plateau?
            To me they are no different from any of the others. Your results to me look fantastic.
            You mention the rectilinear closure of the contours, which was done manually by me to make level faces and which I gather is actually unnecessary and even counter-productive.
            ~ Brooke
            • brookefoxB
              brookefox
              11 + 7 seconds for the slow and fancy one.
              Too simple... Complexify, make inscrutable options so the ignorant can pester you for answers. You know I'll be back.
              ~ Brooke
              • EarthMoverE
                EarthMover
                Hey Fredo,
                Any chance on seeing this beta plugin in the future? Could really use it on a few projects I'm working on. If not, no worries, I know you are busy.
                Thanks.
                • pbacotP
                  That's a valid question. I suppose the plugin has to assume and make some sort of rounding-off based on the lower contours. It's easier for the user to flatten after if needed. Alternately user can add a small contour or point to indicate the peak.
                  This looks great, I was just wanting something like this yesterday. I try other skinning plugins on contours but they don't do so well and for all the trouble I end up back with Sandbox. Wonderful coding!
                  • fredo6F
                    Could you post or PM me your model.
                    The main reason why I don't release it quicker is because I have not worked too much on the validation of input contours and handling of corrections.
                    And of course, I have not really tested on real-life models (actually only the one posted by brookefox).
                    • pbacotP
                      I'd be glad to PM it to you! Will do today. Thanks, Peter
                      • fredo6F
                        @pbacot,
                        By the way, I observe that the native 'From Contours' plugin does a rather good job on your example of terrain.
                        Because TopoShaper uses a more accurate algorithm (to cope with cases of more abrupt changes of relief and also saddles), the analysis of the contours is more tricky and I'll need some time to write a decent code to handle it.
                        PS: and again, I'm pretty sure Trimble will adress the generation of terrain from contour in a next release of Sketchup
                        • pbacotP
                          Yes sir,
                          That existing terrain is not too problematic for Sandbox, but I assume a more regular clean mesh, as I think you are after, would serve better for subsequent "regrading". Thank you.
                          It seems the skinning plugins don't work where ridges twist about as in this case, and SB seems to work that out OK.
                          Peter
                          • P
                            Panga
                            Fredo,
                            I'll Join Earthmover and others to say that what you tried to do with this plugin attempt is my biggest dream in SU !! As a landscape architect, you can't imagine how much time I spent to clean the terrain mesh because of SU native triangulation prevent using the mesh for may things...so...I'll be very gratefull if you can give us even an alpha version of it !! 😍 😍
                            • pbacotP
                              For ideas on terrain mesh results:
                              http://www.formz.com/products/bonzai3d/bonzai3dFeatures.php?init=27
                              • fredo6F
                                Thanks. That's more or less what was my intention.
                                This is why I need to write some extension in C to have enough speed for the preview mode.
                                But I am a little bit reluctant to engage in this because I am pretty sure that Trimble will provide a bridge to a Terrain from Contour program in a next release of Sketchup (I guess this is what field engineers need)
                                I need to think about if I can make a simple beta release quickly. The version I have currently works on close contours only.
                                • T
                                  tald311
                                  would LOVE this tool. Very needed. amazing as usual Fredo.
                                  • pbacotP
                                    With Vali Architects new Instant Terrain plugin.
                                    Contours at height. Sandbox "from contours". VA InstantTerrain.
                                    This doesn't really address the OP issue, but it's a way to apply a regular mesh to the terrain. And simplify--if you use a larger spacing.
                                    Screen shot 2012-11-25 at 12.30.00 PM.pngScreen shot 2012-11-25 at 12.31.39 PM.png
                                    I know, the contours have parts missing--just the most convenient example to grab at the moment.
                                    • pbacotP
                                      Using Brookefox model, two things:
                                      1. The contours do not have enough points for Sandbox. I added 2-3 times as many vertices per curve in some of the countour model.
                                      2. A picture of the Sandbox result and some of the model run through Instant Terrain at fine setting. [EDIT: I ran Instant Terrain for whole model at 75' spacing--last image.] Screen shot 2012-11-26 at 2.14.20 AM.pngScreen shot 2012-11-26 at 2.25.38 AM.pngScreen shot 2012-11-26 at 12.31.07 PM.png
                                      • fredo6F
                                        I resumed some work on Toposhaper, in particular around the identification of contour zone and interpolation.
                                        Here is the current state on Brookefox' model, with various resolutions on a quadrangular mesh
                                        Toposhaper - Test 24 Dec 12.zip
                                        It still takes many seconds
                                        One issue I came across is about zones bordered by a single contour, either loop contour, or open to the outside. In the current version, I try to figure out a kind a simulated relief based on the surrounding elevations.
                                        • pbacotP
                                          This looks fantastic! I would think it should take more than a few seconds. Did you modify the Brookefox contours beforehand?
                                          Happy Holidays, Fredo! Thanks for sharing your gift. Peter
                                          • fredo6F
                                            Peter,
                                            I took the contours as they are shown on the video, which I think is the original model from Brookefox.
                                            If you have some contours model, please send them to me so that I can test the script in various situations.
                                            PS: The main issue I see in the utilisation of Toposhaper is that it generates a lot of faces. The good thing with quandrangular meshes is that they can be easily textured, since based on quads. I may have however to find a way to densify and undensify the mesh in function of the resolution really required by the relief.
                                            • 2 / 5
