    Terrain from contours - improve on native 'from contours'?
    99 Posts 18 Posters 29.1k Views 18 Watching
    • fredo6F Offline
      @pbacot said:
      For ideas on terrain mesh results:
      http://www.formz.com/products/bonzai3d/bonzai3dFeatures.php?init=27
      Thanks. That's more or less what was my intention.
      This is why I need to write some extension in C to have enough speed for the preview mode.
      But I am a little bit reluctant to engage in this because I am pretty sure that Trimble will provide a bridge to a Terrain from Contour program in a next release of Sketchup (I guess this is what field engineers need)
      I need to think about if I can make a simple beta release quickly. The version I have currently works on close contours only.
        tald311
        would LOVE this tool. Very needed. amazing as usual Fredo.
        • pbacotP Offline
          With Vali Architects new Instant Terrain plugin.
          Contours at height. Sandbox "from contours". VA InstantTerrain.
          This doesn't really address the OP issue, but it's a way to apply a regular mesh to the terrain. And simplify--if you use a larger spacing.
          Screen shot 2012-11-25 at 12.30.00 PM.pngScreen shot 2012-11-25 at 12.31.39 PM.png
          I know, the contours have parts missing--just the most convenient example to grab at the moment.
          • pbacotP Offline
            Using Brookefox model, two things:
            1. The contours do not have enough points for Sandbox. I added 2-3 times as many vertices per curve in some of the countour model.
            2. A picture of the Sandbox result and some of the model run through Instant Terrain at fine setting. [EDIT: I ran Instant Terrain for whole model at 75' spacing--last image.] Screen shot 2012-11-26 at 2.14.20 AM.pngScreen shot 2012-11-26 at 2.25.38 AM.pngScreen shot 2012-11-26 at 12.31.07 PM.png
            • fredo6F Offline
              I resumed some work on Toposhaper, in particular around the identification of contour zone and interpolation.
              Here is the current state on Brookefox' model, with various resolutions on a quadrangular mesh
              Toposhaper - Test 24 Dec 12.zip
              It still takes many seconds
              One issue I came across is about zones bordered by a single contour, either loop contour, or open to the outside. In the current version, I try to figure out a kind a simulated relief based on the surrounding elevations.
              • pbacotP Offline
                This looks fantastic! I would think it should take more than a few seconds. Did you modify the Brookefox contours beforehand?
                Happy Holidays, Fredo! Thanks for sharing your gift. Peter
                • fredo6F Offline
                  Peter,
                  I took the contours as they are shown on the video, which I think is the original model from Brookefox.
                  If you have some contours model, please send them to me so that I can test the script in various situations.
                  PS: The main issue I see in the utilisation of Toposhaper is that it generates a lot of faces. The good thing with quandrangular meshes is that they can be easily textured, since based on quads. I may have however to find a way to densify and undensify the mesh in function of the resolution really required by the relief.
                  • pbacotP Offline
                    Here's a house site set of contours anyone can experiment with
                    On another layer there is TIN provided by the civil, if useful for comparison
                    I welded the contours with Curvizard. I hope that's helpful.
                    Peter
                    Topo test.skp
                    • fredo6F Offline
                      Here is another contour set, also from pbacot:
                      TopoShaper 3.skp
                      and the previous ones with the current state of the script
                      • fredo6F Offline
                        Peter
                        Peter,
                        Thanks very much for this model, which is very helpful for me to progress on the script.
                        Toposhaper samples the contours on a grid, and therefore it is not necessary to have extra-smoothed contours. On the contrary, when there is less segments in contours, the calculation is much faster.
                        In the attached SKP file, you'll have the resulting terrains
                        • for your original model, with high-definition contours
                        • for the same model after simplification of contours by Curvizard simplify (17 degerees).
                          You can see that the generated terrains are almost identical. The simplified model takes 3 seconds (see video) whereas the original one takes over 30 seconds.
                        TopoShaper pbacot model - 01 Jan 13.skp
                        PS: There is still some work on the algorithms, for calculation of concave hull and extrapolating on the borders, and also some work to package a decent GUI.
                        • pbacotP Offline
                          Fredo,
                          Very good looking models! I suppose one can judge how it follows the contours by how much is buried or floating... and these look quite accurate, especially given that contours themselves are a more or less rough approximation of field conditions from point readings. (a further angle of the tool might be using other data like depth maps).
                          I like that the created model uses all the extent of the contours and doesn't cut corners. The skirt is very nice. Have you got anywhere with adjusting complexity of the grid?
                          All methods have trouble with the drainage ditches (the v-shaped contours). Perhaps these need to handled separately if one is in need of detail there. (this brings up something that I have experimented with a bit--how to "regrade" a portion of the mesh and join it to the original--or join two meshes). At least this tool gives a smooth result, whereas Sandbox can look all creased in the tight spots.
                          I realized the first set of contours was quite fine. Surprising to me. This is from a civil in an old project. So it might be a good example of the definition created by some programs (the segments were tiny, a few inches long). I think your result is much more detailed than the TIN that came with the file.
                          Happy New Year and THANKS for the fine contributions!
                          Peter
                            mac1
                            IMHO there is a lesson to be learned.
                            One cannot grab data and try to use without first understanding its quality.
                            The OP info ,as I previously noted, was drastically under sampled in some areas. The sample interval( Both x , y and z) must be related to the gradients in that area
                            As an experiment I used a xy plane with a small grid( one dimensional), set that at each level of the contours and intersected to get additional points( just at the several elevation levels). The results look very similar to Pabcots. Would not want to do this in a production sense. It is too labor intensive and prone to errors.
                            The question I keep asking myself is: If it looks better is it?
                            I could not find anything in the quick net search to answer that โ“
                            • fredo6F Offline
                              @pbacot and mac1
                              Grid refinement (both densify and undensify) is possible, though complex to handle, but with a quad mesh structure, it means that it will break the regularity of cells, i.e. one cell will be split into 4 smaller quads, or 4 quads will be replaced by one bigger quad.
                              At this stage, I am trying to obtain a decent geometry with a regular grid in an acceptable time.
                              pbacot: thanks for the model. If you have others, they will be welcome to perform further tests and validation.
                              • simon le bonS Offline
                                simon le bon
                                (From first page)
                                http://sketchucation.com/forums/viewtopic.php?f=15&t=44282#p400386
                                You probably need to use some external software (I have seen one some time ago, but I don't remember the name. It has export capability to Sketchup, can handle crests and is fully specialized on this problem of terrain shaping)./...
                                Hi Fredo ๐Ÿ˜„
                                your Toposhaper looks very promizing ๐Ÿ‘ ๐Ÿ‘ โ˜€
                                You were probably talking about Terragen
                                ( Terragen 2.4 Free Version Now Available)
                                Here a model made by Google Guy (G.G.):
                                http://sketchup.google.com/3dwarehouse/details?mid=f4350227d1c9debd6623100010a93a06
                                some really nice models by TaffGoch:
                                http://sketchup.google.com/3dwarehouse/search?tags=Terragen
                                http://i.snag.gy/NSHXP.jpg
                                Here from [url=http://wetbanana.deviantart.com/:6upgx29j]Wetbanana terragen gallery[/url:6upgx29j]
                                http://th05.deviantart.net/fs71/PRE/f/2012/347/d/e/rocky_cliffs_2_by_wetbanana-d5nxfwx.png
                                picked up into Terragen forums:
                                [url=http://www.planetside.co.uk/forums/index.php?topic=5763.msg59956#msg59956:6upgx29j]Re: Terrains For Google SketchUp?[/url:6upgx29j]
                                For minimal effort your best bet would be to forget all about generating your own terrains and import real world elevation data instead. If I recall correctly you can directly import .dem files into sketchup. Try downloading some files from here and see if they work out for you.
                                [url:6upgx29j]http://seamless.usgs.gov[/url:6upgx29j]
                                The link appears to don't work ๐Ÿ˜•
                                but this one is ok (free topo download in pdf)
                                Illustrates available US Topos
                                [url:6upgx29j]http://viewer.nationalmap.gov/viewer/[/url:6upgx29j]
                                Historical Topographic Map Collection
                                http://nationalmap.gov/historical/
                                etc..
                                ++simon.
                                • fredo6F Offline
                                  Simon,
                                  That was not Terragen. I really need to find this software.
                                  • PixeroP Offline
                                    Pixero
                                    Was it this one: http://www.geocontrol2.com/e_index.htm
                                    Or maybe one of these: http://vterrain.org/Packages/Artificial/
                                    Or Leveller here: http://www.daylongraphics.com/
                                    Or Grome: http://www.quadsoftware.com/index.php?m=section&sec=product&subsec=editor
                                      Does this program was a "free" program ?
                                      A plug or a complet program ? (MojoWorld, World Machine, Bryce 7...)
                                      here maybe some little things? (in French and not aespecially for MAC! ๐Ÿ˜‰
                                      http://www.igeomac.fr/igeomac/Applications_Mac.html
                                      Scroll and see LandSerf ? Maybe not direct SU export but...
                                      • fredo6F Offline
                                        I think I found it, this is SimuTerra by COMPUneering.
                                        See link there: http://www.compuneering.com/simuterra.php;
                                        It costs 200$ in Pro version and 100$ for an entry-level version.
                                        It has some capability to export / import with Sketchup.
                                        Fred
                                        PS: there are interesting [url=http://www.compuneering.com/simuterraMovies.php:3g8iku5m]videos[/url:3g8iku5m] showing the capabilities of the software, including to draw roads and other landscaping decorations
                                          mac1
                                          Fredo:
                                          Excellent as usual ๐Ÿ‘
                                          Looks like a great program. ๐Ÿ‘ I Wonder how it compares to others like Arcgis. Would take a lots of testing to find out.
                                          I also like their emphasis on model preprocessing. Think that is where novices like myself get in big trouble trying to use questionable data. Ran into this in some searching;
                                          • Contours should always point upstream in valleys
                                            Contours should always point downridge along ridges
                                            Adjacent contours should always be sequential or equivalent
                                            Contours should never split into two
                                            Contours should never cross or loop
                                            Contours should never spiral
                                            Contours should never stop in the middle of a map
                                            Liking to hit my finger with a hammer I tried this;
                                            Used you ploy segmenter to get more consistent points on the contour lines, ignored some info ref above. In most cases used 80 segs , but during process kept eye on entity info and for some short segs keep count down close to orginal. Needs to be redone to remove warts but looks more reasonable to me vs like orginal.
                                          contours simplified-post._mac1skp.skp
                                          • pbacotP Offline
                                            Thank you Fred et al.
                                            Here is another set of contours for testing from a civil engineer's file. I had to set the heights in my CAD drawing. I think I got it all right. In some of the twisted minor contours, I had to use what logic I have at my disposal...
                                            I have not recurved these, and again they are higly segmented--and this seems to be a norm one would need to account for. So simplify (I can do this if there is a problem) and recurve as desired.
                                            Sandbox creates over 42,000 faces.
                                            Peter
                                            DN house contours.skp
                                            • 2 / 5
