๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Photo texture with transparency push/pull able?
13 Posts 4 Posters 778 Views 4 Watching
  • V Offline
    vozer
    Hey!
    I have a question to the article "window treatment with transparency" in Catchup 11:
    In fact i am trying to achieve, that the shadings also have some thickness.
    for example i have a solid rectangle, i apply my photo texture with transparence, but i want to sketchup to recognize, that this "transparency-holes" are going thtough the whole solid, so that i cant actually see inside the solid.
    Hope that was a good enough description.
    cheers
    vozer
      hmm.. maybe ๐Ÿ˜‰
      are you saying you want to do something like this?
      the item on the left is a transparent .png while the item on the right is the same image with only the picture push/pulled (and the transparent part is ignored.. or, with a little more work, you could reverse that to where only the transparent part is extruded)
      if that's what you want then you should check out TIG's image trimmer plugin:
      http://forums.sketchucation.com/viewtopic.php?t=33445
        Very powerful plug indeed! ๐Ÿ‘
        • V Offline
          vozer
          yes!
          thats it! thx a lot!!
            I have that when I ask Textures
            Does this normal ?
            rvb.skp
              yeah, pilou. that's normal.
              the plugin doesn't convert each color of the png to its own individual texture..
              the texture still remains as one so when you push/pull it, that's what happens. (with my example, I painted all the vertical surface the default material but it looked similar to yours at first)
                So Tig Must make a little addendum ๐Ÿ˜‰
                  NO. ๐Ÿ˜ฎ
                  What you do with the flat '2d' cutout after it's made is up to you...
                  You can Color any extruded surfaces as you will - but when extruded with PushPull it will take the top surface's material... BUT it has to assume something ๐Ÿ˜’
                    imagine if the png was a photograph and the plugin converted all the colors to individual materials..
                    there would be hundreds if not thousands of new materials added to the model. ๐Ÿ˜ฒ
                    ๐Ÿ˜‰
                      No just paint vertical faces with a solid color ๐Ÿ˜‰
                        Thomthom has a bitmap-to-faces tool that makes individual colored squares from an image's pixels... do a search...
                          I can also in view front just make a box selection from right to left for take only vertical faces and colorize them in one click ๐Ÿ˜‰
                          And copy past the top faces to the bottom if i want the same colors ๐Ÿ˜„
                            Easy and another time exploration is endless! โ˜€
