    Photo texture with transparency push/pull able?
    13 Posts 4 Posters 941 Views 4 Watching
    • V Offline
      vozer
      Hey!
      I have a question to the article "window treatment with transparency" in Catchup 11:
      In fact i am trying to achieve, that the shadings also have some thickness.
      for example i have a solid rectangle, i apply my photo texture with transparence, but i want to sketchup to recognize, that this "transparency-holes" are going thtough the whole solid, so that i cant actually see inside the solid.
      Hope that was a good enough description.
      cheers
      vozer
      • jeff hammondJ Offline
        hmm.. maybe ๐Ÿ˜‰
        are you saying you want to do something like this?
        the item on the left is a transparent .png while the item on the right is the same image with only the picture push/pulled (and the transparent part is ignored.. or, with a little more work, you could reverse that to where only the transparent part is extruded)
        if that's what you want then you should check out TIG's image trimmer plugin:
        http://forums.sketchucation.com/viewtopic.php?t=33445
          Very powerful plug indeed! ๐Ÿ‘
          • V Offline
            vozer
            yes!
            thats it! thx a lot!!
              I have that when I ask Textures
              Does this normal ?
              rvb.skp
                yeah, pilou. that's normal.
                the plugin doesn't convert each color of the png to its own individual texture..
                the texture still remains as one so when you push/pull it, that's what happens. (with my example, I painted all the vertical surface the default material but it looked similar to yours at first)
                  So Tig Must make a little addendum ๐Ÿ˜‰
                  • TIGT Online
                    NO. ๐Ÿ˜ฎ
                    What you do with the flat '2d' cutout after it's made is up to you...
                    You can Color any extruded surfaces as you will - but when extruded with PushPull it will take the top surface's material... BUT it has to assume something ๐Ÿ˜’
                      imagine if the png was a photograph and the plugin converted all the colors to individual materials..
                      there would be hundreds if not thousands of new materials added to the model. ๐Ÿ˜ฒ
                      ๐Ÿ˜‰
                        No just paint vertical faces with a solid color ๐Ÿ˜‰
                        • TIGT Online
                          Thomthom has a bitmap-to-faces tool that makes individual colored squares from an image's pixels... do a search...
                            I can also in view front just make a box selection from right to left for take only vertical faces and colorize them in one click ๐Ÿ˜‰
                            And copy past the top faces to the bottom if i want the same colors ๐Ÿ˜„
                              Easy and another time exploration is endless! โ˜€
