    Photo texture with transparency push/pull able?
    13 Posts 4 Posters 1.2k Views 4 Watching
      Very powerful plug indeed! ๐Ÿ‘
      • V
        vozer
        yes!
        thats it! thx a lot!!
          I have that when I ask Textures
          Does this normal ?
          rvb.skp
          • jeff hammondJ
            yeah, pilou. that's normal.
            the plugin doesn't convert each color of the png to its own individual texture..
            the texture still remains as one so when you push/pull it, that's what happens. (with my example, I painted all the vertical surface the default material but it looked similar to yours at first)
              So Tig Must make a little addendum ๐Ÿ˜‰
                NO. ๐Ÿ˜ฎ
                What you do with the flat '2d' cutout after it's made is up to you...
                You can Color any extruded surfaces as you will - but when extruded with PushPull it will take the top surface's material... BUT it has to assume something ๐Ÿ˜’
                • jeff hammondJ
                  imagine if the png was a photograph and the plugin converted all the colors to individual materials..
                  there would be hundreds if not thousands of new materials added to the model. ๐Ÿ˜ฒ
                  ๐Ÿ˜‰
                    No just paint vertical faces with a solid color ๐Ÿ˜‰
                      Thomthom has a bitmap-to-faces tool that makes individual colored squares from an image's pixels... do a search...
                        I can also in view front just make a box selection from right to left for take only vertical faces and colorize them in one click ๐Ÿ˜‰
                        And copy past the top faces to the bottom if i want the same colors ๐Ÿ˜„
                          Easy and another time exploration is endless! โ˜€
