    Webdialogs: inputbox shows black background (sketchup webkit
    50 Posts 22 Posters 36.7k Views 22 Watching
      mwm5053
      I saw that and thanks for pointing that out but still seeing black fields. Jeff's solution did allow me to change width dimension ultimately. I don't think this a SU thing however I believe it was an update to the Safai browser for Macs after the Flashback incident. From what I've read it not only effected SU but other programs that use webdialog boxes on Mac. Emptying the cache hasn't proved to be useful either.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        rdeath
        OK, purged cache in Safari and still no luck...!! anything else i can try..??? this is VERY frustrating..!!
          petersaal
          Move "font-size: 12px;" down to its own line. I had that on the same line as background-color and that's an error on my part.
          If that doesn't do the trick, the only difference might be the OS X version. I'm still on 10.6 and I don't have a way to test 10.7.
          Just to be clear: this fix is only for dynamic components. It will not fix the 3D Warehouse search box or any other affected software on the mac.
            lwerner
            Thanks for posting this workaround! It worked perfectly for me. (On OSX 10.7.4 Lion, Sketchup 8.0.14345 Pro)
            Laura
              mwm5053
              @ Petersall
              I followed your suggestion and didn't seem to make any differance 😞
              Did I do it right?
              Edit Went back and corrected a few errors and fine now.
              2011 iMac
              V2 Twilight
              • JuantxoJ Offline
                Juantxo
                When I updated to Safari to 5.1.7 in Mac Leopard webdialogs boxes turn black in Sketchup.
                I've installed an older version of safari with pacifist and now it works again.
                http://www.charlessoft.com/ (pacifist software)
                http://mac.oldapps.com/safari.php (Safari 5.1.1 (Snow Leopard))
                • jeff hammondJ Offline
                  Laura
                  ditto.. works fine for me too..
                  thanks peter.
                    TeamSDA
                    Hi All,
                    The fix Peter provided worked for the fields in my DC options window. But when I open my custom attributes window and look at the "Display Label" it is black as well. I couldn't find the style in the css style sheet that changed this input field. Does anyone know the style I need to change.
                    Custom Attributes
                    (On OSX 10.6.8 Snow Leopard, Sketchup 8.0.14345 Pro)
                    Regards,
                    Christian
                      mwm5053
                      Update If you find more black dialoge boxes blacked out like in profile builder or at 3d warehose this solution of Juantxo will work for all blacked
                      out dialoge boxes follow instructions on this page to revert Safari back to 5.1.1 even though it's for a earlier ver.
                      (appletoolbox.com)
                      2011 iMac
                      V2 Twilight
                        fwiw, i did the DC fix a while ago and yes, it works but as mentioned in this thread, it only works with the DC dialog.. skindigo was also exhibiting this blacked out behavior so i eventually downgraded safari using the method mentioned by Juantxo a few posts back.. pacifist with an older version of safari..
                        and that fixes everything in sketchup instead of just the DC dialog.
                          mwm5053
                          I wonder if this has been reported to apple so the next Safari update will resolve this? BTW Still love my MAC
                          2011 iMac
                          V2 Twilight
                            driven
                            I'm using the developer release of Safari 6 and the problem remains in SU.
                            Safari's User Agent Style Sheet, handles the input border correctly but SU doesn't use that, so it's a WebCore update that's needed. i'm looking for a patch at the moment.
                              mwm5053
                              Thanks John I'd like to stay updated on this as I like to stay updated on all software.
                              2011 iMac
                              V2 Twilight
                                gohch
                                Thanks guys!
                                I managed to get all the dialog boxes of 1001bit fixed following the suggestions on the css;
                                patch in html file to fix the black textbox
                                It's a lot of work to edit all the html files, but at least the problem is solved. 😄
                                Cheers!
                                • RichMorinR Offline
                                  RichMorin
                                  I grabbed a copy of Pacifist, but I can't find a copy of Safari 5.1.5 to install.
                                  For example, the page http://support.apple.com/kb/DL1070
                                  has a Download button that leads to http://www.apple.com/safari/download/.
                                  However, this page only supports downloading of Safari 5.1.7.
                                  Help?
                                    troypiggo
                                    I found it here:
                                    http://mac.oldapps.com/safari.php?old_safari=813
                                    This is not my signature. I type it at the end of every message for quality control.
                                      driven
                                      update to my investigation.
                                      WebView uses a different version of Webkit than Safari (and not just in SU) and I can't find a way to change the userAgent from within SU, so been trying another approach.
                                      dlg.execute_script %(function addGlobalStyle(css) {
                                         var head, style;
                                         head = document.getElementsByTagName('head')[0];
                                         if (!head) { return; }
                                         style = document.createElement('style');
                                         style.type = 'text/css';
                                         style.innerHTML = css;
                                         head.appendChild(style);
                                      addGlobalStyle('input {border; 1px solid gray;}'))
                                      This works if you know the name of the dialog, but how can I get that with ruby to apply a global patch. Is it possible to get a new dialog name in ruby.
                                      Using WebInspector to add the JS I can also exclude type with
                                      addGlobalStyle('input, input;not[type="submit"];not[type="button"];not[type="file"];not[type="search"]{border; 1px solid gray;}'))
                                      , but that returns true and fails in RubyConsole
                                        @aerilius said:
                                        UI::WebDialog.open
                                        You mean UI::WebDialog.show ?
                                          Aerilius
                                          fixed it.
                                            driven
                                            @aerilius said:
                                            fixed it.
                                            hi, I'm getting
                                            Error: #<SyntaxError: (eval):24: compile error (eval):15: parse error, unexpected '(' alias(:show_orig, :show) ^ (eval):20: both block arg and actual block given> (eval):24
                                            I'd much rather use a small amount of ruby to 'fix' the input problem
                                            cheers for your efforts
                                            • 2 / 3
