    Webdialogs: inputbox shows black background (sketchup webkit
    50 Posts 22 Posters 38.6k Views 22 Watching
      petersaal
      Just in case I wasn't clear in the previous post, you only need to make the additions/changes in red.
      Here's some background on the issue on StackOverflow:
      Black input backgrounds - Cocoa WebView
      Morning everyone, I've been developing and maintaining a Cocoa app which contains a WebView section. It's built against the 10.5 SDK to maintain PPC compatibility. With the most recent Safari upda...
      Stack Overflow (stackoverflow.com)
        petersaal
        I found the same problem last week. The source of the problem is the Safari update that Apple pushed out last week (5.1.7). Here's a work-around for dynamic components: make the following edits in red to the manager.css and configurator.css files. (located in Library/Application Support/Google SketchUp 8/SketchUp/Tools/Dynamic Components/css)
        In Manager.css:
        .edit-field {
        position: absolute;
        border-top: 2px solid #3063C9;
        border-left: 2px solid #3063C9;
        border-right: 2px solid #A5C4FF;
        border-bottom: 2px solid #A5C4FF;
        background-color: white; font-size: 12px;
        font-family: sans-serif;
        width: 100%;
        height: 100%;
        overflow: hidden;
        padding-left: 2px;
        padding-top: 1px;
        border: 1px solid #000000;
        In Configurator.css:
        .config-field {
        width: 100%;
        font-size: 11px;
        font-family: tahoma, sans-serif;
        height: 22px;
        .config-field-readonly {
        width: 100%;
        font-size: 11px;
        height: 22px;
        background-color: threedface;
          rdeath
          Hi, i have located the manager.css and configurator.css files and opened them. I don't seem to be able to edit them. Can you point me in the right direction. THX for finding the problem it's been driving me nuts. Look forward to your help
            Why not? Open it in a plain text editor (not a word processor) and you can simply copy/paste those lines then save.
              rdeath
              Ok, I have done all that RESTARTED iMAC and things don't seem to have changed.....? Any ideas..?
              • Dan RathbunD Offline
                Dan Rathbun
                Clear your browser cache (or temporary internet files directory.)
                I'm not here much anymore.
                  mwm5053
                  Still no luck
                  2011 iMac
                  SU 2015 Pro, 2017 Make
                  V2 Twilight
                  macOS Sierra 10.12.5
                  • jeff hammondJ Offline
                    @mwm5053 said:
                    Well by the subject you can tell my problem. It seems to be native to my computer. Mac OSX 10.7 using SU 8 Pro the same DC comp. on my WIN laptop are correctly displayed. The peculiar thing is the DC comp. from Google are able to change dim.
                    that's odd.. (i'm seeing the same behavior..)
                    the items are still editable, it's just that the black is the same color as the text so you can see it.. if you triple click an entry, the field will highlight in blue so you can see it.. (when blue, push delete then enter your new numbers ..albeit blindly)
                    heres a shot after focusing the component options dialog then selectAll-- 😕 😕
                      Aerilius
                      Your image shows a website (that is loaded from the internet and can't use these css hacks). Does it at least work for components options?
                      @mwm5053 said:
                      Still no luck
                      Can you check again that all the css properties are separated with a semi-colon? I think you forgot one in %(#000000)[.config_field].
                      Another idea, would a WebView also accept a user stylesheet (that would override the default background in all websites+webdialogs in SketchUp)?
                        mwm5053
                        I saw that and thanks for pointing that out but still seeing black fields. Jeff's solution did allow me to change width dimension ultimately. I don't think this a SU thing however I believe it was an update to the Safai browser for Macs after the Flashback incident. From what I've read it not only effected SU but other programs that use webdialog boxes on Mac. Emptying the cache hasn't proved to be useful either.
                        2011 iMac
                        V2 Twilight
                          rdeath
                          OK, purged cache in Safari and still no luck...!! anything else i can try..??? this is VERY frustrating..!!
                            petersaal
                            Move "font-size: 12px;" down to its own line. I had that on the same line as background-color and that's an error on my part.
                            If that doesn't do the trick, the only difference might be the OS X version. I'm still on 10.6 and I don't have a way to test 10.7.
                            Just to be clear: this fix is only for dynamic components. It will not fix the 3D Warehouse search box or any other affected software on the mac.
                              lwerner
                              Thanks for posting this workaround! It worked perfectly for me. (On OSX 10.7.4 Lion, Sketchup 8.0.14345 Pro)
                              Laura
                                mwm5053
                                @ Petersall
                                I followed your suggestion and didn't seem to make any differance 😞
                                Did I do it right?
                                Edit Went back and corrected a few errors and fine now.
                                2011 iMac
                                V2 Twilight
                                • JuantxoJ Offline
                                  Juantxo
                                  When I updated to Safari to 5.1.7 in Mac Leopard webdialogs boxes turn black in Sketchup.
                                  I've installed an older version of safari with pacifist and now it works again.
                                  http://www.charlessoft.com/ (pacifist software)
                                  http://mac.oldapps.com/safari.php (Safari 5.1.1 (Snow Leopard))
                                    Laura
                                    ditto.. works fine for me too..
                                    thanks peter.
                                      TeamSDA
                                      Hi All,
                                      The fix Peter provided worked for the fields in my DC options window. But when I open my custom attributes window and look at the "Display Label" it is black as well. I couldn't find the style in the css style sheet that changed this input field. Does anyone know the style I need to change.
                                      Custom Attributes
                                      (On OSX 10.6.8 Snow Leopard, Sketchup 8.0.14345 Pro)
                                      Regards,
                                      Christian
                                        mwm5053
                                        Update If you find more black dialoge boxes blacked out like in profile builder or at 3d warehose this solution of Juantxo will work for all blacked
                                        out dialoge boxes follow instructions on this page to revert Safari back to 5.1.1 even though it's for a earlier ver.
                                        (appletoolbox.com)
                                        2011 iMac
                                        V2 Twilight
                                          fwiw, i did the DC fix a while ago and yes, it works but as mentioned in this thread, it only works with the DC dialog.. skindigo was also exhibiting this blacked out behavior so i eventually downgraded safari using the method mentioned by Juantxo a few posts back.. pacifist with an older version of safari..
                                          and that fixes everything in sketchup instead of just the DC dialog.
                                            mwm5053
                                            I wonder if this has been reported to apple so the next Safari update will resolve this? BTW Still love my MAC
                                            2011 iMac
                                            V2 Twilight
                                            • 1 / 3
