    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Components to Grid
    22 Posts 7 Posters 23.9k Views 7 Watching
    • CadFatherC Offline
      CadFather
      TIG, you do it on purpose! ๐Ÿ˜†
        CadFather
        while i'm at it i might ask another question (for which there surely there isn't an old easy answer..)
        any way to distribute ALL the components present in the component browser 'in model' - to an imaginary grid in model space?
        • TIGT Online
          I already recently did something like this in another thread, where the OP wanted to import SKPs and then show the components laid out.
          What you could do with a model's components in code is to iterate the list of definition names 'ns' [as all set/got in my earlier example] and then place an instance of each on a special layer [it makes later deletions easier], thus:
          m=Sketchup.active_model;m.start_operation("ALL!");ds=m.definitions;ns=[];ds.to_a.find_all{|d|next if d.group?||d.image?;ns<<d.name};ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom;;Point3d.new(0,0,0);x=1.m;y=1.m;r=(Math.sqrt(ns.length)+0.5).to_i;c=0; ns.length.times{|i|puts ns[i]; tr=Geom;;Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l;c+=1;if c>=r;p.x=0;p.y+=y;c=0;else;p.x+=x;end};puts"\nDone.";m.commit_operation
          The x/y set for a 1m 'square' grid starting from [0,0,0] - with any odd ones on the final row - so adjust this as desired; these new instances are put onto a layer name 'ALL!'; this one-liner is one-step undoable...
            CadFather
            wow...thank you TIG - just tried it and it's fab! ๐Ÿ˜„ ๐Ÿ‘
            tried to make it into a command but no success and yet i'm sure i wrapped it up properly (just in case others find it useful)
            compogrid.rb
            • TIGT Online
              You miss called the module/method... try it this way
              require 'sketchup.rb'
              module CADfather
                unless file_loaded?(File.basename(__FILE__))
                  UI.menu('Tools').add_item('Components to Grid'){self.compogrid()}
                file_loaded(File.basename(__FILE__))
                def self.compogrid()
                  m=Sketchup.active_model;m.start_operation("ALL!");ds=m.definitions;ns=[]; ds.to_a.find_all{|d|next if d.group?||d.image?;ns<<d.name};ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom;;Point3d.new(0,0,0);x=2.m;y=2.m;r=(Math.sqrt(ns.length)+0.5).to_i;c=0; ns.length.times{|i|puts ns[i]; tr=Geom;;Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l;c+=1;if c>=r;p.x=0;p.y+=y;c=0;else;p.x+=x;end};puts"\nDone.";m.commit_operation
                end #def
              end #module
              ... OR something similar ... ๐Ÿ˜‰
              EDIT: typo fixed !
                CadFather
                thanks TIG - works great.
                i think there's a small typo here:
                %(#008000)[def self.compogrid()
                m=Sketchup.active_model;m.start_operation("ALL!");ds=m.definitions;ns=[];]s.to_a.find_all{|d|next if d.group?||
                should read ds
                what's interesting is how fast it is even with lots of components ๐Ÿ‘ ๐Ÿ‘
                • TIGT Online
                  You are right - I have now changed the original to ' ds'...
                    CadFather
                    Hi TIG - is it possible to have all the components placed along the red axis? i tried modifying the script but i always get the components on top of each other.. ๐Ÿ˜’
                    • TIGT Online
                      This [simpler] version spaces the component-instances 2m apart along the red/x axis [no stacking into a 'square']
                      module CADfather
                              m=Sketchup.active_model;m.start_operation("ALL!"); ds=m.definitions; ns=[]; ds.to_a.find_all{|d|next if d.group?||d.image?; ns<<d.name}; ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom;;Point3d.new(0,0,0); x=2.m; ns.length.times{|i|puts ns[i]; tr=Geom;;Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l; p.x+=x};puts"\nDone.";m.commit_operation
                            end #def
                      end #module
                      If the Ruby Console is open it reports what it's doing...
                      Change the x=2.m for a different spacing in red/x if desired...
                        CadFather
                        Thanks TIG - much appreciated - i'll try integrating it into the grid plugin.. ๐Ÿ‘ ๐Ÿ˜„
                        • gullfoG Offline
                          gullfo
                          TIG script examples - an interesting side effect - if you have a component made of other components it pulls it apart and distributes them... in this example i have a DC component of an acoustic window which has frames and seals as sub-components. in a way, this could be handy for creating a "how to assemble" guide because it pulls it apart in order of nesting...
                          otoh this may not be a desired effect for the script in the end...
                          Glenn
                          http://www.runnel.com
                          • TIGT Online
                            The OP asked for all components to be displayed on a grid.
                            The code is very adaptable.
                            It ignores Groups and Images although it could as easily display those as well, or instead.
                            This version displays just components that have instances that are either in the model's entities or inside a non-component-entities context [i.e. inside a group that is not itself inside a component definition]
                                module CADfather
                                        UI.menu('Tools').add_item('Components to Grid'){self.compogrid_used()}
                                      def self.compogrid_used()
                                        ds=m.definitions
                                        ns=[]
                                        def self.recurse_parent(c)
                                          begin
                                            return c.parent
                                          rescue
                                            return nil
                                          next unless d.instances[0]
                                          next if d.group?
                                          next if d.image?
                                          skip=true
                                          d.instances.each{|i|
                                            if i.parent==m
                                              skip=false
                                              break
                                            elsif i.parent.group?
                                              i.parent.instances.each{|g|
                                                c=g
                                                while c
                                                  c=self.recurse_parent(c)
                                                  if m==c
                                                    skip=false
                                                    c=nil
                                                    break
                                          next if skip
                                          ns<<d.name
                                        ns.sort!;
                                        x=2.m
                                        ns.length.times{|i|
                                          puts ns[i]
                                          n.layer=l
                                          p.x+=x}
                                        puts"\nDone."
                                        m.commit_operation
                                      end #def
                                end #module
                              Amazing Artist
                              TIG Thanks
                              [color=#FF40FF:20ov4k9m]T[/color:20ov4k9m][color=#FF40F9:20ov4k9m]h[/color:20ov4k9m][color=#FF40F2:20ov4k9m]a[/color:20ov4k9m][color=#FF40EC:20ov4k9m]t[/color:20ov4k9m][color=#FF40E5:20ov4k9m]'[/color:20ov4k9m][color=#FF40DF:20ov4k9m]s[/color:20ov4k9m] [color=#FF40D2:20ov4k9m]m[/color:20ov4k9m][color=#FF40CC:20ov4k9m]y[/color:20ov4k9m] [color=#FF40BF:20ov4k9m]s[/color:20ov4k9m][color=#F940B9:20ov4k9m]t[/color:20ov4k9m][color=#F240B2:20ov4k9m]o[/color:20ov4k9m][color=#EC40AC:20ov4k9m]r[/color:20ov4k9m][color=#E540A6:20ov4k9m]y[/color:20ov4k9m][color=#DF40A0:20ov4k9m],[/color:20ov4k9m] [color=#D24093:20ov4k9m]a[/color:20ov4k9m][color=#CC408D:20ov4k9m]n[/color:20ov4k9m][color=#C54086:20ov4k9m]d[/color:20ov4k9m] [color=#C53A7A:20ov4k9m]I[/color:20ov4k9m][color=#CC3373:20ov4k9m]'[/color:20ov4k9m][color=#D22D6D:20ov4k9m]m[/color:20ov4k9m] [color=#DF2060:20ov4k9m]s[/color:20ov4k9m][color=#E51A5A:20ov4k9m]t[/color:20ov4k9m][color=#EC1353:20ov4k9m]i[/color:20ov4k9m][color=#F20D4D:20ov4k9m]c[/color:20ov4k9m][color=#F90646:20ov4k9m]k[/color:20ov4k9m][color=#FF0040:20ov4k9m]i[/color:20ov4k9m][color=#F9004D:20ov4k9m]n[/color:20ov4k9m][color=#F20059:20ov4k9m]g[/color:20ov4k9m] [color=#E50073:20ov4k9m]t[/color:20ov4k9m][color=#DF0080:20ov4k9m]o[/color:20ov4k9m] [color=#D20099:20ov4k9m]i[/color:20ov4k9m][color=#CC00A6:20ov4k9m]t[/color:20ov4k9m][color=#C500B2:20ov4k9m]![/color:20ov4k9m]
                                For SU 2017 Make
                                Incompatible with LightUP! ๐Ÿ˜ฎ
                                Curiously icons of LightUp apear!
                                And LightUp Disconnected
                                don't take a selection but all components on the scene! ๐Ÿ˜ฎ
                                Here must be display only "XTE" Selected : that is not the case! ๐Ÿ˜‰
                                All is recalled! (even the top view text who is not visible at the Plugin call! )
                                • jujuJ Offline
                                  juju
                                  @pilou said:
                                  For SU 2017 Make
                                  [attachment=1:2yvqwupx]<!-- ia1 -->bizarrerie.jpg<!-- ia1 -->[/attachment:2yvqwupx]
                                  [attachment=0:2yvqwupx]<!-- ia0 -->biz4.jpg<!-- ia0 -->[/attachment:2yvqwupx]
                                  Pilou, are you OK? I don't see what this has to do with the thread above? Perhaps start your own thread or look for the thread this is supposed to be in?
                                    It's not the thread about Plugin "Components to Grid"?
                                    What better place to report that it is not compatible (for me in any case) with Light UP ?
                                    And it has curious behavior with the selection Components ? (for me in any case)
                                    Out of that i just reinstall SketchUp and must verify if above is always true!
                                    It will be my first Plugin to reload from a little thousand! ๐Ÿ˜„
                                      Alas not better ! ๐Ÿ˜ข
                                      My SketchUp is absolutly new! Only "Component on Grid" installed! ๐Ÿค“
                                      So no conflict possible! (like Light Up above) ๐Ÿ˜‰
                                      If i add new volumes : the same! that is making snowball ! All is redrawn! ๐Ÿ˜ฎ
