CONCEPT_CAR_LADYBUG_REVISITED
Finally this WIP is comming to an end, ill add this rendered image and will post up a few in the coming week, i must say im not normally a SCI FI modeller but i really enjoyed doing this model, it was a challenge to rig the trusters and landing gear for movement and i dont think it will be my last SCI Fi model either, What i have learnt from this is the beauty of imagination and the freedom to do anything in Sc Fi modelling, there are no set rule, no restrictions, again i will post more in the coming week but heres an image to view of the finished Ladybug concept.
Can I see native SU in Monochrome with hidden geometry on?
There's some weird reflections going on. Is that ShaderLight cranked to the max?
Quility is maxed out
Does it allow the use of HDR images for lighting?
Or background plates?
It allows both Rich, just don't have a good Hdr to suit the theme
Try DeviantArt. There's some nice studio HDR images there
Will do, cheers for the tip
Fun!
Looking good!
This wa my first SCI FI model but iv learnt alot since this and would like to revisit this concept again and start from the beginning, there were a few things i wasnt happy about with the end result and most of the topology was very much bad, so heres a start and hopefully i will update this each day i work on it comparing the topology of the old and new, maybe some others can learn from my previous mistakes
Im sure the image shows how the topology is very bad on the old model, the new 1 is much better and cleaner, but not finished, but you can see the difference already
Nice, and what are the differences in technique that give you the new topology?
A lot more awareness of managing the topology would be the main approach but tools Ill be using would be TTs vertex tools and to smoothen it out ill be using artisans SDS, Ill be making a high detailed and low poly version, I would like to apply the low poly version to a game made in unity to be played on mobile devices, ill also be paying alot more attention to how the thrusters will animate so it looks and works more effectively
It just goes to show you sometimes its better to model from the start rather than trying to fix the original model, huge difference in topology here
Nice concept!
Who knows...Maybe in a few more years we can build this type of machines for the public.
Well there is something similar, don't know if you have ever heard of the mullor skycar, think that's what it's called, if you dig deep enough on YouTube you will find some test flights but height restrictions due to being a prototype, mine is just a further into the future version
Guess we are closer than I thought!
My goal with this is to redo it so it looks like it would work in the real world, for example if you look at the old you will wonder how does it take off, it has no visual evidence that it has VTOL capabilities but it was intended to, so this time around it will have thrusters to allow VTOL and the main engines wings will be getting a complete make over compaired to the rushed older version, once all done ill bring this into unity and create a very basic sim where you can test flight the end result via a webplayer, Once that is complete I will improve so you can have the view inside and fly it from a POV perspective all with animated components to add the realism, it will take a few wks to complete but it's something my son keeps asking, "can I fly it daddy" since it was him who inspired the concept I feel as tho it needs to be complete and give it virtual flight
Re-working how this machines engines will work
