    CONCEPT_CAR_LADYBUG_REVISITED
    48 Posts 7 Posters 8.5k Views 7 Watching
    • iichiversiiI
      iichiversii
      @bryan k said:
      Fun!
      Looking good!
      Cheers Bryan πŸ‘
      Bring on the Rain...
      • iichiversiiI
        iichiversii
        • iichiversiiI
          iichiversii
          This wa my first SCI FI model but iv learnt alot since this and would like to revisit this concept again and start from the beginning, there were a few things i wasnt happy about with the end result and most of the topology was very much bad, so heres a start and hopefully i will update this each day i work on it comparing the topology of the old and new, maybe some others can learn from my previous mistakes πŸ˜„
          Im sure the image shows how the topology is very bad on the old model, the new 1 is much better and cleaner, but not finished, but you can see the difference already πŸ˜„
          • pbacotP
            Nice, and what are the differences in technique that give you the new topology?
            • iichiversiiI
              iichiversii
              A lot more awareness of managing the topology would be the main approach but tools Ill be using would be TTs vertex tools and to smoothen it out ill be using artisans SDS, Ill be making a high detailed and low poly version, I would like to apply the low poly version to a game made in unity to be played on mobile devices, ill also be paying alot more attention to how the thrusters will animate so it looks and works more effectively
              • iichiversiiI
                iichiversii
                It just goes to show you sometimes its better to model from the start rather than trying to fix the original model, huge difference in topology here πŸ˜„
                • renderizaR
                  renderiza
                  Nice concept!
                  Who knows...Maybe in a few more years we can build this type of machines for the public.
                  [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                  • iichiversiiI
                    iichiversii
                    Well there is something similar, don't know if you have ever heard of the mullor skycar, think that's what it's called, if you dig deep enough on YouTube you will find some test flights but height restrictions due to being a prototype, mine is just a further into the future version
                    • renderizaR
                      renderiza
                      Guess we are closer than I thought!
                      • iichiversiiI
                        iichiversii
                        My goal with this is to redo it so it looks like it would work in the real world, for example if you look at the old you will wonder how does it take off, it has no visual evidence that it has VTOL capabilities but it was intended to, so this time around it will have thrusters to allow VTOL and the main engines wings will be getting a complete make over compaired to the rushed older version, once all done ill bring this into unity and create a very basic sim where you can test flight the end result via a webplayer, Once that is complete I will improve so you can have the view inside and fly it from a POV perspective all with animated components to add the realism, it will take a few wks to complete but it's something my son keeps asking, "can I fly it daddy" since it was him who inspired the concept I feel as tho it needs to be complete and give it virtual flight πŸ˜„
                        • iichiversiiI
                          iichiversii
                          • iichiversiiI
                            iichiversii
                            This is the lowpoly version, still a WIP but alot better by far
                            • Bryan KB
                              Looking good but the dark colors make it hard to see the lines/shape.
                              • iichiversiiI
                                iichiversii
                                Apologies, ill update the image later to be more clear
                                • sh00ksS
                                  sh00ks
                                  Great improvement in ordening and minalizing of the faces/lines!
                                  Was your firtst model build by using 'follow me' technique?
                                  • iichiversiiI
                                    iichiversii
                                    No I user curviloft originally which didn't create the best geometry but now I'm creating it manually using vertex tools and it's coming along a lot better, πŸ˜„
                                    • iichiversiiI
                                      iichiversii
                                      Sorry that was meant to say used curviloft πŸ˜„
                                      • sh00ksS
                                        sh00ks
                                        I have the same difficulties with CurviLoft when trying to use it for such models. I too started using vertex tools/Artisan for this. Takes up some more time, but the results are way better, especialy file size/complexity πŸ˜„
                                        Vertex tools FTW πŸ˜„
                                        • iichiversiiI
                                          iichiversii
                                          I agree, vertex tools is the new way of modelling in sketchup and it's very beneficial, with time I found i can model faster now using it and more effectively may I add πŸ˜„
                                          • 2 / 3
