    Select edges - select or grow loop on edges
    12 Posts 7 Posters 986 Views 7 Watching
      smicha
      I am looking for a plugin that works like "QuadfaceTools" by thomthom http://forums.sketchucation.com/viewtopic.php?t=39442 and its function "grow loop" or "select loop". I'd like to select entire loop as shown below - "select loop" from "QuadFeceTools" doesn't work in my example. If there is any plugin that solves my problem please help.
      https://lh6.googleusercontent.com/-AY2aree-sp4/T9bu9l4EajI/AAAAAAAACLU/9qgd1d5l49A/s1031/s1.gif
      The desired effect is:
      https://lh4.googleusercontent.com/-IMyjZklZZMM/T9bu9o7OF1I/AAAAAAAACLQ/aqDbK0ONj0w/s939/s2.gif
      smicha
        hmm... when I get time I'll look into the function and see if I can improve it for scenarios like this.
        • gillesG
          gilles
          You could try Recurve.rb, I don't remember where to find it.
            Tgi3D Amorph has a loop select feature
            • cottyC
              cotty
              With the (commercial) "path select tool" you can double click one of the lines and the path will be selected...
              my SketchUp gallery
                smicha
                Thank you so much. Recurve (http://forums.sketchucation.com/viewtopic.php?t=36822) works fine. But how can I combine all selected edges into one curve? I tried weld tool without success.
                • gillesG
                  gilles
                  Instructions:
                  • Quickly select edges to be recurved
                    Select a single edge from the edges to be made into a curve and choose "Recurve -> Select Curve" or "Recurve -> Select Curve (Planar)" from the context menu. If the curve exists in a single plane, "Select Curve (Planar)" is more likely to find the correct sequence of edges. The command works by following a sequence of edges which don't change direction sharply.
                  • Recurve a sequence of edges
                    Select all the edges which make up the curve and choose "Recurve -> Recurve Edges" from the context menu. The edges should be instantly replaced with a curve.
                  • Filter the current selection
                    From the context menu choose "Select Only -> " followed by your filter choice. The selection will be updated to only include those entities matching the filter.
                  • Reverse a curve
                    Select the curves you want to be reversed and choose "Recurve -> Reverse Curve" from the context menu. There will be no visible change, but the curves will be reversed.
                    smicha
                    Gilles,
                    It's not working. I still cannot transform connected edges into a curve. I've used Recurve Edges - it's not working in my example. I attached the file.
                    recurve.skp
                      Capture.PNGIf you first select the vertical faces/edges and smooth them, and then select the 'loops' Weld [or Recurve] will make the selected edges into a curve and then it won't be 'split' into pieces by the now-smoothed edges joining at the nodes...Capture1.PNG
                      • gillesG
                        gilles
                        If you soft coplanar it does work.
                        recurve.skp
                          smicha
                          TIG, gilles
                          Thank you so much!!!
                          Your first solution is exactly what I did πŸ˜„ But the second with smoothing edges is simple and works perfect.
                          • F
                            fartchitect
                            I've been looking for it for years too. Its called Quadface tools.
