    [plugin] Rotated Box [updated 30-Mar-2014]
    69 Posts 21 Posters 39.4k Views 21 Watching
      jorge2011
      yes
      • gillesG Offline
        gilles
        The best for my needs should be
        first point center second point axis third point radius.
        • jeff hammondJ Offline
          thats a good one
          • gillesG Offline
            gilles
            I don't think so, but I may be wrong.
            In fact I think something similar to the rotate tool.
            • urgenU Offline
              urgen
              ....old post http://forums.sketchucation.com/viewtopic.php?f=323&t=9556&start=15
              ...Guys,I use this for a long time... πŸ˜‰ thanks once again CPhillips,Sahi and Macs! πŸ‘
              ...it should be useful.
              --pupil forever...------
              • sdmitchS Offline
                sdmitch
                Defining a axis other than standard red, green, or blue can be difficult without something to inference to. So, unless you are not interested in defining an arbitrary axis, I guess it would work
                http://sdmitch.blogspot.com/
                • gillesG Offline
                  gilles
                  I think about a snapping point, edge vertice etc..
                    the.pjt
                    thanks dear Sam ...
                    I posted this massage in me question topc .. but I think you haven't seen it ..... :
                    this plugin is exactly what every body wants : a time saver ... draw .. rotate .. select .. make group .. push pull ... all in one ! well done .. tanks dear sam .. tanks πŸŽ‰
                    and I have a question .. why do these display problems happen ??!? I'm not a pro developer but I can understand if you tell me the reasons ... ?!??
                    and another thing : if you add a "make cylinder" feature , it's gonna to be perfect ... because SU's default cylinder is not a time saver .. it makes the cylinder in 0,0,0 ... thanks
                    this is a snapshot from shetchyphisics > sketchy solids ..
                    pictures describes it Sam ... so don't need to make codes from my wrong described requests .. πŸ˜„ 😳
                    [xxl-img:2l4cslic]http://forums.sketchucation.com/download/file.php?mode=view&id=89033[/xxl-img:2l4cslic]
                    • sdmitchS Offline
                      sdmitch
                      I don't know exactly why either. You might post this question on the developers forum and get an answer but basically it has to do with the way Sketchup displays things on the screen. There is a certain field of view and if you get to close to an object it disappears. Zooming out usually makes it reappear.
                      • utilerU Offline
                        utiler
                        Well done, Sam! A great little tool...... πŸ‘
                        The efforts in responding to plugin requests often goes un-noticed so thank you for all that you do mate!!
                        Just Curious...
                        • sdmitchS Offline
                          sdmitch
                          Rotated box has been updated to allow the option turning grouping on and off.
                            jorge2011
                            Thank you very much. just one more thing
                            is possible to align the axes of the group rectangle?
                            Now, when creating a rotated rectangle, the axes of the group are the same as the axes of the model.
                            • sdmitchS Offline
                              sdmitch
                              No way to define the axes of a group that I'm aware of.
                              You can temporarily align the axes to the group when in group edit mode.
                                You can [re]set a group's axes...
                                Find each of the desired-axes in turn and its angle from the SKP's axes - do the three axes in turn...
                                Apply a rotation-transformation to the group's geometry in turn:
                                group.entities.transform_entities(transformation, group.entities.to_a)
                                to rotate the geometry back to be 'axial'.
                                Then immediately apply the inverse transformation to the group itself:
                                group.transform!(transformation.inverse)
                                • again this must be done once for each axis in turn - so that could be three transformations in all ?
                                The group is now as if you made it 'axially' and then rotated it in 3d afterwards.......
                                  the.pjt
                                  thanks for new vertion mr. sdmitch .... nice update ... πŸŽ‰
                                  .. waiting for cylinder plugin too πŸ˜‰
                                  • sdmitchS Offline
                                    sdmitch
                                    TIG, thanks for the info. I guess my next question is what is the advantage or need to do this?
                                      jorge2011
                                      sdmitch, when editing a group or component is better to work with the axes perpendicular or parallel to the predominant form (inthis case a square) is simpler drawing
                                      • sdmitchS Offline
                                        sdmitch
                                        I agree so when you get into edit mode, right click on the group and choose Align Axes.
                                          jorge2011
                                          if I agree, but is simpler if this is automatic
                                            Ben Ritter
                                            Sam, thank you.
                                            • 1 / 4
