    [plugin] Rotated Box [updated 30-Mar-2014]
    69 Posts 21 Posters 40.4k Views 21 Watching
    • gillesG
      gilles
      Very useful, I would love a rotated circle for years 😞
      Thanks a lot πŸ‘
        Tricky the guides lines! πŸ˜‰
        And yes for cylinder that will solve the little problem of this πŸ˜‰
        http://forums.sketchucation.com/download/file.php?id=68678
        • EarthMoverE
          EarthMover
          Thanks Sam. πŸ‘ This is a great tool. Would be a super effective technique to create a more comprehensive (& interactive) set of primitive tools similar to in 3ds Max http://heartlessg.com/node/20 Something long overdue in Sketchup.
          Content Creator at Skapeup
          • sdmitchS
            sdmitch
            Thanks a lot πŸ‘
            OK, just how would you design this plugin, a circle through 3 points or maybe center, a point to define the radius, and a point to define the plane, or maybe the ends of the diameter and a point to define the plane. Please don't say "all of the above", pick one.
            http://sdmitch.blogspot.com/
            • kenK
              ken
              My vote, 3 point.
              Ken
                jorge2011
                thank you very much, excellent plugin.
                just a query, you can use the "Ctrl" key to switch between geometry and geometry grouped ungrouped?
                thank you very much
                • sdmitchS
                  sdmitch
                  thank you very much
                  Do you mean toggle the grouping of the box on and off with the "Ctrl" key?
                    jorge2011
                    yes
                    • gillesG
                      gilles
                      The best for my needs should be
                      first point center second point axis third point radius.
                      • jeff hammondJ
                        thats a good one
                        • gillesG
                          gilles
                          I don't think so, but I may be wrong.
                          In fact I think something similar to the rotate tool.
                          • urgenU
                            urgen
                            ....old post http://forums.sketchucation.com/viewtopic.php?f=323&t=9556&start=15
                            ...Guys,I use this for a long time... πŸ˜‰ thanks once again CPhillips,Sahi and Macs! πŸ‘
                            ...it should be useful.
                            --pupil forever...------
                            • sdmitchS
                              sdmitch
                              Defining a axis other than standard red, green, or blue can be difficult without something to inference to. So, unless you are not interested in defining an arbitrary axis, I guess it would work
                              • gillesG
                                gilles
                                I think about a snapping point, edge vertice etc..
                                • T
                                  the.pjt
                                  thanks dear Sam ...
                                  I posted this massage in me question topc .. but I think you haven't seen it ..... :
                                  this plugin is exactly what every body wants : a time saver ... draw .. rotate .. select .. make group .. push pull ... all in one ! well done .. tanks dear sam .. tanks πŸŽ‰
                                  and I have a question .. why do these display problems happen ??!? I'm not a pro developer but I can understand if you tell me the reasons ... ?!??
                                  and another thing : if you add a "make cylinder" feature , it's gonna to be perfect ... because SU's default cylinder is not a time saver .. it makes the cylinder in 0,0,0 ... thanks
                                  this is a snapshot from shetchyphisics > sketchy solids ..
                                  pictures describes it Sam ... so don't need to make codes from my wrong described requests .. πŸ˜„ 😳
                                  [xxl-img:2l4cslic]http://forums.sketchucation.com/download/file.php?mode=view&id=89033[/xxl-img:2l4cslic]
                                  • sdmitchS
                                    sdmitch
                                    I don't know exactly why either. You might post this question on the developers forum and get an answer but basically it has to do with the way Sketchup displays things on the screen. There is a certain field of view and if you get to close to an object it disappears. Zooming out usually makes it reappear.
                                    • utilerU
                                      utiler
                                      Well done, Sam! A great little tool...... πŸ‘
                                      The efforts in responding to plugin requests often goes un-noticed so thank you for all that you do mate!!
                                      Just Curious...
                                      • sdmitchS
                                        sdmitch
                                        Rotated box has been updated to allow the option turning grouping on and off.
                                          jorge2011
                                          Thank you very much. just one more thing
                                          is possible to align the axes of the group rectangle?
                                          Now, when creating a rotated rectangle, the axes of the group are the same as the axes of the model.
                                          • sdmitchS
                                            sdmitch
                                            No way to define the axes of a group that I'm aware of.
                                            You can temporarily align the axes to the group when in group edit mode.
                                            • 1 / 4
