    Lengthening a series of lines in equal increments
    31 Posts 8 Posters 3.5k Views 8 Watching
    • gillesG Offline
      gilles
      My two cents, no plugin.
      V6 for Pilou's Minitel
        -Thx for my Minitel: every people should make the same! 😄
        http://www.blog-agri.com/ticagri/wp-content/minitel.jpg
          This is how I'd do it...
          There are scripts [by me?] that that will add simple cylinder components, scaling lengths to match selected lines length in Z... Search the Plugins Index...
          spiral lines.skp
          • pbacotP Offline
            Davecon,
            I notice that you are also working on a straight line, so why not use the simple way? You can also curve your array of lines after making the varied line lengths.
            In using the box tapering tool are you grouping the lines first? It doesn't look like it. You would get a rectangle designated by the tool. It appears you are only working on one line. Most, if not all, of the FredOscale tools operate on groups and components. That is a clean way to do it once you know the end length or you set guideline based on the increment. I can't imagine how it would work on a curve either.
            Peter
            • gillesG Offline
              gilles
              Or, make it flat then use Shapebender.
              • jeff hammondJ Offline
                a rough go at doing this with a dynamic component…
                select the line at the origin then Window -> Component Options…. change the "# of vertical lines per turn" option for immediate results..
                i plotted the lines using this..
                x = a(t) cos(t), y = a(t) sin(t)
                which looks like this: (archimedean spiral)
                  another method…
                  click pic -> bigger
                  curvishear is part of FredoTools..
                  http://forums.sketchucation.com/viewtopic.php?t=42089
                  curviLoft is here:
                  http://forums.sketchucation.com/viewtopic.php?t=28586
                    @Jeff
                    Shadowline on the ground of the Curvishear is very elegant! ☀ (middle drawing image)
                    Not possible to make a curve with it ? (maybe a script is yet existing ? )
                      @Jeff
                      Shadowline on the ground of the Curvyshear is very elegant! ☀ (middle drawing image)
                      hmm.. not that i know of.. would be neat if you could though..
                      (actually, you could probably project the geometry somehow?? i think there might even be a plugin that could do it?)
                        [off:aznqnqp7]
                        @Jeff
                        1. set sun directly overhead to be used as a preview..
                        2. orient the helix to your liking using the shadow as a guide..
                        3. sandbox-> drape…
                        project3.jpg[/off:aznqnqp7]
                          So that was simple! 😲
                          I will try that because seems too simple for to be true! 💚
                          About the first problem
                          I am waiting the Sdmitch autorization
                          for calculate a serie of lines not in equal increment 😄
                            @Jeff
                            I'm very bored for testing your genious trick! 😲
                            Very Curious I can't have the open of the all menu of a Shadow settings box dialog!
                            I don't have the same Shadow settings 😞
                            From your Shadows settings image
                            http://forums.sketchucation.com/download/file.php?id=41868&mode=view
                            And this don't open something more! 😮 (V6 or V7)
                            Shadow tool is enable on the Toolsbar list menu!
                            Seems i had this box dialog in the past 😒
                            No more in Style / Edges
                            The button Activate Shadow dialog seems makes nothing! 😮
                            No more in selecting curve right click
                            No more Entity Info, Model info... Cast Shadows, Receive Shadows are enable
                            Maybe I miss something 😕 or a plug squize this function ?
                              So for the lines in not equal alignement 😄
                              make each lines as component (see follow how do make that)
                              (there are the Target)
                              redraw the same number of lines in equal alignement
                              use any method above for modify them
                              make each these new lines as a components (there are the Source)
                              use this tricky new plugin of Sdmitch who permit now replace components Source--> Target
                              Randomly or Not ! So choose No ☀
                              See this post for precision of the normal use of the Replace Components
                              And maybe a plug(s) for make each (original lines / new lines) a component 😉
                              Select a familly of lines
                              Loose geometry to groups by Chris Fullmer
                              Then Groups to components TT by Thomthom
                              That all! 😄
                              ComponentReplacement.rb
                                hmm.. i don't know what to tell you.. it's not a plugin.. just standard sketchup settings.
                                does someone with windows know about this?
                                once you get that part figure out, you'll also want to go Model Info -> Geo Location -> Set Manual Location
                                then set the latitude to 0º
                                this will make it possible to have the sun directly over head.. then adjust the time of day settings to fine tune it..
                                (use Top View when lining it up)
                                  it's not a plugin.
                                  Of course that is not a plugin, it's just a dialog box 😄
                                  But I have tested that is not a plugin who blocks this Menu function!
                                  Maybe a file has desapeared 😐
                                  Or maybe that is a "Pro version" function ?
                                  Docs
                                  From the Doc
                                  http://sketchup.google.com/crimages/sketchup-114934-ShadowSettings-win-en.png
                                  Activate the Shadow Settings dialog box from the Window menu.
                                  Made but no Box dialog appears!
                                  I will try on V8 tomorrow
                                    another approach:
                                    click pic -> bigger
                                    (Jim) DrawHelix:
                                    http://forums.sketchucation.com/viewtopic.php?t=33139
                                    (TIG) Extrude Edges by Object to Vector to Object:
                                    http://forums.sketchucation.com/viewtopic.php?t=37515
                                    download the ExtrudeEdges suite here:
                                    http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                      @Jeff
                                      on an other computer with V 6,7,8 free your tricky tip works like a charm! 😎
                                      So I believe problem should maybe about open "Shadows dialog box" for mysterious reasons! 😄
                                      • sdmitchS Offline
                                        sdmitch
                                        @davecon said:
                                        Thanks for the help so far everyone 😄
                                        I have got the hang of doing this on a straight line, now the complex bit is trying to do it on a spiral. Currently I am trying to turn the model on the left (spiral with even length lines) in the model on the right (spiral with lines increasing by XX per length)
                                        [attachment=1:2ramdbm4]<!-- ia1 -->spiral lines.jpg<!-- ia1 -->[/attachment:2ramdbm4]
                                        Ideally what I would like to be able to do is select the first line (red) and then the last line (green) and be able to input something like "starting the with the first line make all the others increase in XXmm increments"
                                        Here is the file itself so far.
                                        [attachment=0:2ramdbm4]<!-- ia0 -->spiral lines.skp<!-- ia0 -->[/attachment:2ramdbm4]
                                        Instead of going to the trouble of creating the equal length lines then extending them incrementally, I would make the "baseline", be it a flat spiral or a straight line divided into the desired number of segments, into a curve using weld and then you can create the lines originating from the curve's vertices.
                                        The code to do this is as simple as this
                                        mod = Sketchup.active_model
                                        ent = mod.entities
                                        sel = mod.selection
                                        if !sel.empty? && sel.first.curve
                                         vers=sel.first.curve.vertices
                                        # d is initial length, i is the increment, and a is the direction vector
                                         d=875.0.mm;i=87.5.mm;a=[0,0,-1]
                                         for v in vers
                                          p=v.position;pp=p.offset(a,d)
                                          ent.add_line(p,pp)
                                          d += i
                                        else
                                         UI.messagebox "select a curve"
                                        It would be a monumental task to try to figure out the order of the equal length lines. When you select a group of anything, there is no guaranty that Sketchup will add them to the selection in the proper order. At least that has been my experience.
                                        http://sdmitch.blogspot.com/
                                        • 2 / 2
