    Lengthening a series of lines in equal increments
    31 Posts 8 Posters 3.8k Views 8 Watching
    • jeff hammondJ Offline
      another method…
      click pic -> bigger
      curvishear is part of FredoTools..
      http://forums.sketchucation.com/viewtopic.php?t=42089
      curviLoft is here:
      http://forums.sketchucation.com/viewtopic.php?t=28586
        @Jeff
        Shadowline on the ground of the Curvishear is very elegant! ☀ (middle drawing image)
        Not possible to make a curve with it ? (maybe a script is yet existing ? )
          @Jeff
          Shadowline on the ground of the Curvyshear is very elegant! ☀ (middle drawing image)
          hmm.. not that i know of.. would be neat if you could though..
          (actually, you could probably project the geometry somehow?? i think there might even be a plugin that could do it?)
            [off:aznqnqp7]
            @Jeff
            1. set sun directly overhead to be used as a preview..
            2. orient the helix to your liking using the shadow as a guide..
            3. sandbox-> drape…
            project3.jpg[/off:aznqnqp7]
              So that was simple! 😲
              I will try that because seems too simple for to be true! 💚
              About the first problem
              I am waiting the Sdmitch autorization
              for calculate a serie of lines not in equal increment 😄
                @Jeff
                I'm very bored for testing your genious trick! 😲
                Very Curious I can't have the open of the all menu of a Shadow settings box dialog!
                I don't have the same Shadow settings 😞
                From your Shadows settings image
                http://forums.sketchucation.com/download/file.php?id=41868&mode=view
                And this don't open something more! 😮 (V6 or V7)
                Shadow tool is enable on the Toolsbar list menu!
                Seems i had this box dialog in the past 😒
                No more in Style / Edges
                The button Activate Shadow dialog seems makes nothing! 😮
                No more in selecting curve right click
                No more Entity Info, Model info... Cast Shadows, Receive Shadows are enable
                Maybe I miss something 😕 or a plug squize this function ?
                  So for the lines in not equal alignement 😄
                  make each lines as component (see follow how do make that)
                  (there are the Target)
                  redraw the same number of lines in equal alignement
                  use any method above for modify them
                  make each these new lines as a components (there are the Source)
                  use this tricky new plugin of Sdmitch who permit now replace components Source--> Target
                  Randomly or Not ! So choose No ☀
                  See this post for precision of the normal use of the Replace Components
                  And maybe a plug(s) for make each (original lines / new lines) a component 😉
                  Select a familly of lines
                  Loose geometry to groups by Chris Fullmer
                  Then Groups to components TT by Thomthom
                  That all! 😄
                  ComponentReplacement.rb
                    hmm.. i don't know what to tell you.. it's not a plugin.. just standard sketchup settings.
                    does someone with windows know about this?
                    once you get that part figure out, you'll also want to go Model Info -> Geo Location -> Set Manual Location
                    then set the latitude to 0º
                    this will make it possible to have the sun directly over head.. then adjust the time of day settings to fine tune it..
                    (use Top View when lining it up)
                      it's not a plugin.
                      Of course that is not a plugin, it's just a dialog box 😄
                      But I have tested that is not a plugin who blocks this Menu function!
                      Maybe a file has desapeared 😐
                      Or maybe that is a "Pro version" function ?
                      Docs
                      From the Doc
                      http://sketchup.google.com/crimages/sketchup-114934-ShadowSettings-win-en.png
                      Activate the Shadow Settings dialog box from the Window menu.
                      Made but no Box dialog appears!
                      I will try on V8 tomorrow
                        another approach:
                        click pic -> bigger
                        (Jim) DrawHelix:
                        http://forums.sketchucation.com/viewtopic.php?t=33139
                        (TIG) Extrude Edges by Object to Vector to Object:
                        http://forums.sketchucation.com/viewtopic.php?t=37515
                        download the ExtrudeEdges suite here:
                        http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          @Jeff
                          on an other computer with V 6,7,8 free your tricky tip works like a charm! 😎
                          So I believe problem should maybe about open "Shadows dialog box" for mysterious reasons! 😄
                          • sdmitchS Offline
                            sdmitch
                            @davecon said:
                            Thanks for the help so far everyone 😄
                            I have got the hang of doing this on a straight line, now the complex bit is trying to do it on a spiral. Currently I am trying to turn the model on the left (spiral with even length lines) in the model on the right (spiral with lines increasing by XX per length)
                            [attachment=1:2ramdbm4]<!-- ia1 -->spiral lines.jpg<!-- ia1 -->[/attachment:2ramdbm4]
                            Ideally what I would like to be able to do is select the first line (red) and then the last line (green) and be able to input something like "starting the with the first line make all the others increase in XXmm increments"
                            Here is the file itself so far.
                            [attachment=0:2ramdbm4]<!-- ia0 -->spiral lines.skp<!-- ia0 -->[/attachment:2ramdbm4]
                            Instead of going to the trouble of creating the equal length lines then extending them incrementally, I would make the "baseline", be it a flat spiral or a straight line divided into the desired number of segments, into a curve using weld and then you can create the lines originating from the curve's vertices.
                            The code to do this is as simple as this
                            mod = Sketchup.active_model
                            ent = mod.entities
                            sel = mod.selection
                            if !sel.empty? && sel.first.curve
                             vers=sel.first.curve.vertices
                            # d is initial length, i is the increment, and a is the direction vector
                             d=875.0.mm;i=87.5.mm;a=[0,0,-1]
                             for v in vers
                              p=v.position;pp=p.offset(a,d)
                              ent.add_line(p,pp)
                              d += i
                            else
                             UI.messagebox "select a curve"
                            It would be a monumental task to try to figure out the order of the equal length lines. When you select a group of anything, there is no guaranty that Sketchup will add them to the selection in the proper order. At least that has been my experience.
                            http://sdmitch.blogspot.com/
                            • 2 / 2
