    Lengthening a series of lines in equal increments
    31 Posts 8 Posters 3.4k Views 8 Watching
    • pbacotP Offline
      I think mine, like TIGs is simplest. Just draw the line and remove excess. It takes less time than making post.
      • jeff hammondJ Offline
        right.. but you'll still have to calculate the height of the final line in order to get the proper angle.. maths or some variation on the third pic i posted..
        but after that point, fredoscale makes quick work of it.. 2 mouse clicks..
          actually.. a quicker way to get the angle would be to have all the lines arrayed โ€” longer than necessary..
          then just draw a line from the start point that goes over one / up one...
          line from the start point to the new point and enter a distance longer than necessary..
          • pbacotP Offline
            no no no mon amis.
            You make the first line the correct starting height. you make a copy at the correct interval and add the 30 mm. You draw a line (just like getting a stair angle) from top of first to second. You array remaining lines very long at the same interval. You draw a line from the angled line using the pink inference. select the top lines and erase.
            You only have to know the givens: first line height, increment of increase, intervals.
            (like you said the second time)
              davecon
              aaargh I feel like such a newbie! ๐Ÿ˜„
              I can manage to do what Tig and Pbacot have suggested and that seems to work ok on a straight line (but not on a curve or spiral), but I cannot seem to make Jeff's suggestion work. I have got the fredoscale plugin but cannot get it to do what I need.
              So I set my line like this
              Then using the tapering tool (tried both by box and target) select the line on the right and click on the bottom right and then to the top left and click
              and all I get is this
              I am obviously doing something wrong but I have no idea where I am making a mistake.
              • Jean LemireJ Offline
                Jean Lemire
                I folks.
                If you know the increment in height, the distance between lines and the number of required lines, there are no calculations involved and no plugins required.
                Click in sequence on the scenes tabs of this SU file for ideas.
                Array of lines of uniformly changing length.skp
                  davecon
                  Thanks for the help so far everyone ๐Ÿ˜„
                  I have got the hang of doing this on a straight line, now the complex bit is trying to do it on a spiral. Currently I am trying to turn the model on the left (spiral with even length lines) in the model on the right (spiral with lines increasing by XX per length)
                  Ideally what I would like to be able to do is select the first line (red) and then the last line (green) and be able to input something like "starting the with the first line make all the others increase in XXmm increments"
                  Here is the file itself so far.
                  spiral lines.skp
                  • gillesG Offline
                    gilles
                    My two cents, no plugin.
                    V6 for Pilou's Minitel
                      -Thx for my Minitel: every people should make the same! ๐Ÿ˜„
                      http://www.blog-agri.com/ticagri/wp-content/minitel.jpg
                      • TIGT Online
                        This is how I'd do it...
                        There are scripts [by me?] that that will add simple cylinder components, scaling lengths to match selected lines length in Z... Search the Plugins Index...
                        spiral lines.skp
                        • pbacotP Offline
                          Davecon,
                          I notice that you are also working on a straight line, so why not use the simple way? You can also curve your array of lines after making the varied line lengths.
                          In using the box tapering tool are you grouping the lines first? It doesn't look like it. You would get a rectangle designated by the tool. It appears you are only working on one line. Most, if not all, of the FredOscale tools operate on groups and components. That is a clean way to do it once you know the end length or you set guideline based on the increment. I can't imagine how it would work on a curve either.
                          Peter
                          • gillesG Offline
                            gilles
                            Or, make it flat then use Shapebender.
                              a rough go at doing this with a dynamic componentโ€ฆ
                              select the line at the origin then Window -> Component Optionsโ€ฆ. change the "# of vertical lines per turn" option for immediate results..
                              i plotted the lines using this..
                              x = a(t) cos(t), y = a(t) sin(t)
                              which looks like this: (archimedean spiral)
                                โ€ข
                                another methodโ€ฆ
                                click pic -> bigger
                                curvishear is part of FredoTools..
                                http://forums.sketchucation.com/viewtopic.php?t=42089
                                curviLoft is here:
                                http://forums.sketchucation.com/viewtopic.php?t=28586
                                  @Jeff
                                  Shadowline on the ground of the Curvishear is very elegant! โ˜€ (middle drawing image)
                                  Not possible to make a curve with it ? (maybe a script is yet existing ? )
                                    @Jeff
                                    Shadowline on the ground of the Curvyshear is very elegant! โ˜€ (middle drawing image)
                                    hmm.. not that i know of.. would be neat if you could though..
                                    (actually, you could probably project the geometry somehow?? i think there might even be a plugin that could do it?)
                                      [off:aznqnqp7]
                                      @Jeff
                                      ๐Ÿ˜† ๐Ÿ˜†
                                      1. set sun directly overhead to be used as a preview..
                                      2. orient the helix to your liking using the shadow as a guide..
                                      3. sandbox-> drapeโ€ฆ
                                      project3.jpg[/off:aznqnqp7]
                                        So that was simple! ๐Ÿ˜ฒ
                                        I will try that because seems too simple for to be true! ๐Ÿ’š
                                        About the first problem
                                        I am waiting the Sdmitch autorization
                                        for calculate a serie of lines not in equal increment ๐Ÿ˜„
                                          @Jeff
                                          I'm very bored for testing your genious trick! ๐Ÿ˜ฒ
                                          Very Curious I can't have the open of the all menu of a Shadow settings box dialog!
                                          I don't have the same Shadow settings ๐Ÿ˜ž
                                          From your Shadows settings image
                                          http://forums.sketchucation.com/download/file.php?id=41868&mode=view
                                          And this don't open something more! ๐Ÿ˜ฎ (V6 or V7)
                                          Shadow tool is enable on the Toolsbar list menu!
                                          Seems i had this box dialog in the past ๐Ÿ˜’
                                          No more in Style / Edges
                                          The button Activate Shadow dialog seems makes nothing! ๐Ÿ˜ฎ
                                          No more in selecting curve right click
                                          No more Entity Info, Model info... Cast Shadows, Receive Shadows are enable
                                          Maybe I miss something ๐Ÿ˜• or a plug squize this function ?
                                            So for the lines in not equal alignement ๐Ÿ˜„
                                            make each lines as component (see follow how do make that)
                                            (there are the Target)
                                            redraw the same number of lines in equal alignement
                                            use any method above for modify them
                                            make each these new lines as a components (there are the Source)
                                            use this tricky new plugin of Sdmitch who permit now replace components Source--> Target
                                            Randomly or Not ! So choose No โ˜€
                                            See this post for precision of the normal use of the Replace Components
                                            And maybe a plug(s) for make each (original lines / new lines) a component ๐Ÿ˜‰
                                            Select a familly of lines
                                            Loose geometry to groups by Chris Fullmer
                                            Then Groups to components TT by Thomthom
                                            That all! ๐Ÿ˜„
                                            ComponentReplacement.rb
