    SketchUp 8 M3 - No More Menu Greyout!
    42 Posts 19 Posters 7.3k Views 19 Watching
    • KrisidiousK
      Krisidious
      By: Kristoff Rand
      • john2J
        john2
        any way we get instant email notification the moment a maintenance is released? πŸ˜„
        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
          @krisidious said:
          πŸ˜†
            Subscribe to their blog - more than just announcement, but you won't be missing out.
            Then again - the announcement appear very quickly here as well...
            • sketch3d.deS
              sketch3d.de
              @dan rathbun said:
              English Windows is: 14346
              OSX is: 14345
              probably for all languages
                sonder
                You should be getting a notification as soon as you open sketchup.
                • KrisidiousK
                  Krisidious
                  sooo sooo awesome... I'm dancing on the ceiling...
                  By: Kristoff Rand
                  • Chris FullmerC
                    @dan rathbun said:
                    @jhauswirth said:
                    How 'bout them working menu items!?!?
                    Yes.. and I am quite sure the Mac users (and Developers,) will be happy that you attended to the Entities.add_group() slowdown issue.
                    Thanx for jumpin' on that John !!
                    Wait, I haven't followed this very closely. Are you saying that I can add 15,000 groups without massive slowdown now?
                      Adding geometry still slows down depending on how much geometry there is in the context you add to - so the more you add, the slower it gets. But OSX had a bug that made it even worse.
                      • Dan RathbunD
                        Dan Rathbun
                        Both editions of the application, and the SDK, had it. In the last MR cycle, the code was fixed, and the SDK and the Windows app, called the new code,.. but somehow the OSX app source didn't get changed to call the new code.
                        It would be interesting to see the MAC results of new tests.. against the old ones run on 8.0M2
                        I'm not here much anymore.
                          @Tom
                          (unless your Pilou and still use v6 )
                          Time to upgrade! And that goes for your IE6 as well! I can see you hiding it!!
                          the funny of the thing is that the "Greyout!" menus on the V6 is not the same at each restart!
                          So I have on the same time a loto game! πŸ’š
                          IE6 as well!
                          You seems to say that the new V8 don't work without IE xxx ? Or only your tricky UI plugs?
                            danb
                            Since upgrading to M3 I have blacked out bars in shader light and 1001 bit in the data entry bars and I can't see what Iam typing. Is there anywhere I can redownload M2 or is there a fix
                            many thanks
                            Dan
                            Sketchup Pro 2019/20
                            OSX 10.15.3
                            Macbook Pro
                            • B
                              beef34t3r
                              M3 seems to be a bit faster, but it simplifies graphics (shadows, then textures) even more agressive, when it's not able to render huge scenes fast enough.
                              Is there the ability to disable such graphics speculations in SU? I need full graphics in native render even with 1 FPS: AVI export is awful in SU, and if i export frames with smooth animation plugin, I also get some artifacts in styles (lines, watermarks). So, i'd like to set scene transitions times to very low, grab video from screen and speed up result in video editor, but SU kills graphics and my nerves even with scene transitions times = 30 sec 😑
                                many thanks
                                Dan
                                Can you post screenshots? "data entry bars"?
                                  @thomthom said:
                                  many thanks
                                  Dan
                                  Ah, you are on OSX - that is not an M3 thing - it's and update to Safari to did that.
                                  http://forums.sketchucation.com/viewtopic.php?f=11&t=45382&start=0
                                    danb
                                    Enclosed are screen grabs of the blacked out bars, I looked on the sketch up official forum as well and somebody has posted a similar problem on there. I am running OSX 10.7.4 and using Sketchup Pro M3 release Version 8.0.14345
                                    thanks
                                    Dan
                                    Blacked out bars in Shaderlight
                                    OSX 10.15.3
                                    Macbook Pro
                                      danb
                                      Thom Thom
                                      Thankyou for pointing me in the right direction, I will send a support note to apple and try and reinstall an older version of Safari
                                      Dan
                                      OSX 10.15.3
                                      Macbook Pro
                                      • opalO
                                        opal
                                        I'm a little late updating .. but now I have no working sketchup on my computer. The installer hunted down and killed all my old versions (back to 5) and when I open the program I have an instant bug splat.
                                        Does anyone know what the runtime error R6025 - pure virtual function call means and how to fix it?
                                          The installer only installs or reinstalls/repairs v8, so if you are installing v8M3 you loose v8M2 etc BUT all earlier versions of Sketchup should be unaffected...
                                          As you are on new[ish] OS presumably you have the earlier versions to reinstall.
                                          How to fix a runtime error R6025.
                                          The recommended procedure is:-
                                          If you have received the message that reads "Runtime error R6025 Pure Virtual Function Call," then the program you are using has been corrupted in some way and will need to be deleted and then re-installed.
                                          Repeated runtime errors of this nature may indicate a problem with the Registry.
                                          You could try using the app's REPAIR option and see if that works, before resorting to uninstalling and reinstalling the app.
                                          Appearing to affect all of the separate Sketchup Registry entries is odd...
                                          It might be advisable to revert to an earlier OS set, saved when you last installed Windows updates etc... Alternatively do you have any Registry repair tools ?
                                          • opalO
                                            opal
                                            I did go ahead an uninstall M3. I use cCleaner for both the uninstall and registry cleanup.. then go back and do the manual empty folder housekeeping.
                                            Thankfully, I had the installer for version 8.0.11752 handy, which is installed and running.
                                            Vertex tools, one of my purchased plugin's is freshly installed but still not showing up so I'll be hunting down version 8.0.3(something) which I am fairly sure is backed up on one of my external drives.
                                            And I agree.. strange that my previous versions were gone. All but the plug in folders from versions 6 onward had the whole folders emptied. SU5 is in tact.
                                            Thanks for the reply. πŸ˜„
                                            • 2 / 3
