    SketchUp 8 M3 - No More Menu Greyout!
    42 Posts 19 Posters 7.3k Views 19 Watching
    • JClementsJ
      JClements
      What is the build number of the M3 download?
      • Dan RathbunD
        Dan Rathbun
        English Windows is: 14346
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          @jhauswirth said:
          How 'bout them working menu items!?!?
          Yes.. and I am quite sure the Mac users (and Developers,) will be happy that you attended to the Entities.add_group() slowdown issue.
          Thanx for jumpin' on that John !!
          • KrisidiousK
            Krisidious
            By: Kristoff Rand
            • john2J
              john2
              any way we get instant email notification the moment a maintenance is released? πŸ˜„
              Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                @krisidious said:
                πŸ˜†
                  Subscribe to their blog - more than just announcement, but you won't be missing out.
                  Then again - the announcement appear very quickly here as well...
                  • sketch3d.deS
                    sketch3d.de
                    OSX is: 14345
                    probably for all languages
                      sonder
                      You should be getting a notification as soon as you open sketchup.
                      • KrisidiousK
                        Krisidious
                        sooo sooo awesome... I'm dancing on the ceiling...
                        By: Kristoff Rand
                        • Chris FullmerC
                          Wait, I haven't followed this very closely. Are you saying that I can add 15,000 groups without massive slowdown now?
                            Adding geometry still slows down depending on how much geometry there is in the context you add to - so the more you add, the slower it gets. But OSX had a bug that made it even worse.
                            • Dan RathbunD
                              Dan Rathbun
                              Both editions of the application, and the SDK, had it. In the last MR cycle, the code was fixed, and the SDK and the Windows app, called the new code,.. but somehow the OSX app source didn't get changed to call the new code.
                              It would be interesting to see the MAC results of new tests.. against the old ones run on 8.0M2
                                @Tom
                                (unless your Pilou and still use v6 )
                                Time to upgrade! And that goes for your IE6 as well! I can see you hiding it!!
                                the funny of the thing is that the "Greyout!" menus on the V6 is not the same at each restart!
                                So I have on the same time a loto game! πŸ’š
                                IE6 as well!
                                You seems to say that the new V8 don't work without IE xxx ? Or only your tricky UI plugs?
                                  danb
                                  Since upgrading to M3 I have blacked out bars in shader light and 1001 bit in the data entry bars and I can't see what Iam typing. Is there anywhere I can redownload M2 or is there a fix
                                  many thanks
                                  Dan
                                  Sketchup Pro 2019/20
                                  OSX 10.15.3
                                  Macbook Pro
                                  • B
                                    beef34t3r
                                    M3 seems to be a bit faster, but it simplifies graphics (shadows, then textures) even more agressive, when it's not able to render huge scenes fast enough.
                                    Is there the ability to disable such graphics speculations in SU? I need full graphics in native render even with 1 FPS: AVI export is awful in SU, and if i export frames with smooth animation plugin, I also get some artifacts in styles (lines, watermarks). So, i'd like to set scene transitions times to very low, grab video from screen and speed up result in video editor, but SU kills graphics and my nerves even with scene transitions times = 30 sec 😑
                                      many thanks
                                      Dan
                                      Can you post screenshots? "data entry bars"?
                                        @thomthom said:
                                        many thanks
                                        Dan
                                        Ah, you are on OSX - that is not an M3 thing - it's and update to Safari to did that.
                                        http://forums.sketchucation.com/viewtopic.php?f=11&t=45382&start=0
                                          danb
                                          Enclosed are screen grabs of the blacked out bars, I looked on the sketch up official forum as well and somebody has posted a similar problem on there. I am running OSX 10.7.4 and using Sketchup Pro M3 release Version 8.0.14345
                                          thanks
                                          Dan
                                          Blacked out bars in Shaderlight
                                          OSX 10.15.3
                                          Macbook Pro
                                            danb
                                            Thom Thom
                                            Thankyou for pointing me in the right direction, I will send a support note to apple and try and reinstall an older version of Safari
                                            Dan
                                            OSX 10.15.3
                                            Macbook Pro
                                            • 2 / 3
