    SketchUp 8 M3 - No More Menu Greyout!
    42 Posts 19 Posters 6.2k Views 19 Watching
    • brodieB Offline
      brodie
      What's this gray out issue? I'd never heard of or ran into that.
      -Brodie
        It's where having too many plugins caused certain elements in the right click menu to become greyed-out(unusable)
        Well, maybe not too many plugins but there was some issue within SU that meant if too many plugins were called to use the context menu then other items got greyed out.
        Anyway it's fixed now so those who have a need to install everything no longer suffer this issue (unless your Pilou and still use v6 πŸ˜‰ )
        There's also some fixes for the ruby devs that mean less workarounds and bugsplats related to things called observers.
          sonder
          @thomthom said:
          Little glitch for us Wacom Tablet users - eraser no longer works.
          hmm... haven't noticed that...
          Will check tomorrow when I'm back at office.
          I should clarify - eraser no longer works by simply flipping the pen.
            Time to upgrade! πŸ˜„ And that goes for your IE6 as well! I can see you hiding it!!
            • JClementsJ Offline
              JClements
              What is the build number of the M3 download?
              • Dan RathbunD Offline
                Dan Rathbun
                English Windows is: 14346
                I'm not here much anymore.
                  Dan Rathbun
                  @jhauswirth said:
                  How 'bout them working menu items!?!?
                  Yes.. and I am quite sure the Mac users (and Developers,) will be happy that you attended to the Entities.add_group() slowdown issue.
                  Thanx for jumpin' on that John !!
                  • KrisidiousK Offline
                    Krisidious
                    By: Kristoff Rand
                    • john2J Offline
                      john2
                      any way we get instant email notification the moment a maintenance is released? πŸ˜„
                      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                        @krisidious said:
                        πŸ˜†
                          Subscribe to their blog - more than just announcement, but you won't be missing out.
                          Then again - the announcement appear very quickly here as well...
                          • sketch3d.deS Offline
                            sketch3d.de
                            OSX is: 14345
                            probably for all languages
                              sonder
                              You should be getting a notification as soon as you open sketchup.
                                Krisidious
                                sooo sooo awesome... I'm dancing on the ceiling...
                                By: Kristoff Rand
                                • Chris FullmerC Offline
                                  Wait, I haven't followed this very closely. Are you saying that I can add 15,000 groups without massive slowdown now?
                                    Adding geometry still slows down depending on how much geometry there is in the context you add to - so the more you add, the slower it gets. But OSX had a bug that made it even worse.
                                      Dan Rathbun
                                      Both editions of the application, and the SDK, had it. In the last MR cycle, the code was fixed, and the SDK and the Windows app, called the new code,.. but somehow the OSX app source didn't get changed to call the new code.
                                      It would be interesting to see the MAC results of new tests.. against the old ones run on 8.0M2
                                        @Tom
                                        (unless your Pilou and still use v6 )
                                        Time to upgrade! And that goes for your IE6 as well! I can see you hiding it!!
                                        the funny of the thing is that the "Greyout!" menus on the V6 is not the same at each restart!
                                        So I have on the same time a loto game! πŸ’š
                                        IE6 as well!
                                        You seems to say that the new V8 don't work without IE xxx ? Or only your tricky UI plugs?
                                          danb
                                          Since upgrading to M3 I have blacked out bars in shader light and 1001 bit in the data entry bars and I can't see what Iam typing. Is there anywhere I can redownload M2 or is there a fix
                                          many thanks
                                          Dan
                                          Sketchup Pro 2019/20
                                          OSX 10.15.3
                                          Macbook Pro
                                            beef34t3r
                                            M3 seems to be a bit faster, but it simplifies graphics (shadows, then textures) even more agressive, when it's not able to render huge scenes fast enough.
                                            Is there the ability to disable such graphics speculations in SU? I need full graphics in native render even with 1 FPS: AVI export is awful in SU, and if i export frames with smooth animation plugin, I also get some artifacts in styles (lines, watermarks). So, i'd like to set scene transitions times to very low, grab video from screen and speed up result in video editor, but SU kills graphics and my nerves even with scene transitions times = 30 sec 😑
                                            • 1 / 3
