    [Tutorial > Texturing] Texturing an arch - #2
    87 Posts 18 Posters 37.8k Views 18 Watching
      thor1902
      @gaieus said:
      What TT says. even post your model if that helps us with understanding where it's gone wrong.
      OS version is win7 64 bit
      SU version is pro 8
      now for what's wrong, i have no idea, no error message, nothing in ruby window when im running the plugin.
      oh and im a complete nob it seems when it comes to SU after looking on this site
      arch.skp
        So what's wrong with this arch? (True that it kind of "stretches" the texture but that's inevitable with this kind of mapping) Or you meant to attach something else (this seems to be my own, custom material)?
          thor1902
          @ Gai
          it dosen't seem to matter what texture i use, they dont foolow the curve, im seeing all these terms like quads and subdivide, like i said i am a complete noob, what do these terms mean?
            thor1902
            never mind, i have decided to give up 😞
              Don't give up but post the model you have problems with. This is exactly the place you could/should learn these things. BTW what arch are you trying to texture (and where is it going to be built in)?
                thor1902
                that's part of my "problem", i don't know what it is that i am doing wrong, and my last skp. file i posted was my own
                  And I exported that image above from this file. To me, it seems to be correct (within the possibilities with this kind of mapping). At least try to tell what you do not like in that arch.
                  Is this file that you have problems with? It seems that you may have incidentally shared another file. At least this material in here is what I made for another project (even the name is in Hungarian). I have shared it here somewhere but I can also imagine you somehow uploaded this instead of the one you have problems with?
                  • micioneM Offline
                    micione
                    GAIEUS,
                    can you please explain in detail how to get this? (see photos)
                    I'm trying with tools diFredoScale, but ... I do not get results
                    thanks
                      You need to have slicing off (right click after selected Radial Bend of Fredoscale)
                      or you can enter the "fine tuning" dialog by pressing the TAB key then.
                      • micioneM Offline
                        micione
                        Very good.
                        thanks a lot
                          juanfernandez
                          My first post. Thanks a lot, as new user, SketchUcation is my first learning resource. I have SU 8 pro.
                          I am trying hard to understand how texture archs. My model is a roman villa near Palencia (Spain) I want to model.
                          Until now I cannot get any results. I have downloaded the UV.skp file that Massimo send to Gai. The workflow was:
                          -load UVmassimo.skp
                          -hidden geometry off
                          -select face with textures , one click
                          -remember UV
                          -fredo scale and bend 90º
                          -open the group fredo scale has made, select face with textures, one click (hidden geometry is off)
                          -restore UV
                          Nothing happens...the textures are again horizontal.
                          Another thing I dont understad how to build the vertical column before bending. Reading the thread, it seems that you have to create a bloc, texturing-bricks, stone, whathever-and then copy and add pieces until you have the whole column you want to transform in an arch. I have done so, and my blocks do not macth and after CTLR+delete to smooth the inner lines of separation I cannot select with one click the whole surface to aplicate "remember UV".
                          Please, could anyone tell me what I am doing wrong?
                          UVmassimobeforebend.skp
                            Hm. I am not sure what you are doing wrong. Make sure however to completely turn off slicing in Fredoscale (see the post above). The reason is that UV Toolkit can only remember UV co-ordinates on the exact same faces it remembered them from. This means you cannot introduce any new faces otherwise it will not work. The number of faces must be the same before and after the bending.
                            For this same reason (and to be able to bend the column), I had to copy all your divided edges onto the other three sides as well.
                            You can turn off hidden edges afterwards under the View menu. But you can just select all and do the bending and restoring this way.
                            Here is your (half) arch. You can mirror it to get a whole.
                            Ah, by the way, when we are at Roman villas in Spain... I took part in a EU project that also involved one in Fuente Álamo (Puente Genil):
                            http://www.h2g2.hu/peregrinus/sp/2.1.html
                              You can use QuadFace tools: http://forums.sketchucation.com/viewtopic.php?t=39442
                              Check out the videos for how to UV map.
                                juanfernandez
                                Thanks a lot, Gai and Thom. The slicing off did the job, now I can bend the bricks and builid archs in my La Olmeda model. How could we newbies do anything without you the masters?
                                Gai, if it happens that you come to Spain to see Roman villas or whatever, drop me an email-hope that you, as moderator, can get my email. Please note I am in Palencia, with P (people get confused with Valencia, with V).
                                | Villa Romana La Olmeda
                                La Villa Romana La Olmeda, es una gran mansión rural del Bajo Imperio (s. IV d.C.), cuyo edificio principal o pars urbana, es de planta cuadrada flanqueada por torres en cada esquina y se dispone en torno a un patio central y peristilo al que se abren las distintas dependencias. Esta villa palaciega abarca una extensión en superficie de 4400 m2 con un total de 35 habitaciones repartidas entre la vivienda principal y los baños, 26 de las cuales están decoradas con 1450 m2 de mosaicos polícromos conservados in situ. El conjunto fue declarado Bien de Interés Cultural el 3 de abril de 1996.
                                (www.villaromanalaolmeda.com)
                                Villa romana La Olmeda - Wikipedia, la enciclopedia libre
                                (es.wikipedia.org)
                                (both in Spanish, sorry!)
                                  That's quite a villa indeed! 👍
                                  The first link did not work at all but the wikipedia page also exists in English: http://en.wikipedia.org/wiki/La_Olmeda
                                    juanfernandez
                                    The first link is OK, Gai. The web administrators, I don't know why, shut off their web sites by night, and turn on then early in the morning. It's a provincial institution-Diputación Provincial in spanish- and they have this weird way of publishing their web sites.
                                      Yes, I can see now... "Reconstrucción Virtual > Próximamente". Is this what you are working on?
                                        juanfernandez
                                        No, I am a newbie, and cannot take that job by now. I am a teacher, we plan do educative software and documents related to the Olmeda Villa. My 3D model is may way to learn SU with a motivating subject. Perhaps in the future I will be able of making something worth of the Villa. 😉
                                          Get me to do it then. I am an archaeologist, too. 😉
                                            juanfernandez
                                            Ok, Gai, I'll take your word. ☀
                                            When I became profficient enough in SU to do the job, I'll call you. I have to work hard in SU. Then they have to let me take photographies and measurements of the Villa. I think there will be no problem, because I am in very good relations with the Villa's provincial managers.
                                            • 4 / 5
