    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.4k Views 172 Watching
      tpskinner
      Hey guys...
      Ive been trying to go through all the posts and I realise that theres been some issues with MAC but some seem to have got it to work...
      Ive got SU8... I unpacked the 0.6.3 RAR file and put the files into my plugins folder. I can open the Ivy window with all the various options... but when I click on the model nothing happens. Ive tried various clicks and alt clicks cmd clicks... but nothing. There are no error messages, just nothing happens.
      Any ideas?
      Tim
      • OxerO Offline
        Oxer
        @tpskinner said:
        Hey guys...
        Any ideas?
        Tim
        Hi Tim, i use Mac too see this http://forums.sketchucation.com/viewtopic.php?f=323&t=36882&start=330 the las post.
          tpskinner
          Hey guys...
          Still can't get this plugin to work... Im on Mac, SU8 and using 0.6.3 Ivy.
          I can successfully open the parameters dialogue box and move sliders etc... However, this is all I can do. Clicking on my model does nothing, CMD clicking does nothing etc.
          any ideas?
          Thanks,
          Tim
            Cyberdactyl
            Been enjoying the plugin a lot. Thank you very much Pierreden.
            I've read through this massive thread and understand why half the leaves have the white background. But I'm curious why some leaves have a transparent square for the textures behind, yet has an edge that sees completely through a copy of the same texture?!
            Is there any more versions of this going to be released? I see it hasn't been worked on in 10 months.
            http://img.photobucket.com/albums/v606/Cyberdactyl/SketchUp/leaves.jpg
              arqmiguelc
              i fkn love you! great work although i had to modify the leaves components in order to have transparency on my leaf backround, but it works really fine!
              One more question, when are you planning to pull up a new version of the plug in? you should spread this worldwide, it is a fantastic idea.
              greetings from mexico.
              • KrisidiousK Offline
                Krisidious
                can we see some people's settings for certain types of results and can we see the default settings?
                By: Kristoff Rand
                  Krisidious
                  I had to resave each of the leaves as a new sketchup file with the original name. I also saved them using png textures that I saved into the same textures folder so I could have transparency.
                  this fixed the issue of the vine not producing leaves or branches.
                  here are the default settings if you mess them up and can't find your way back.
                  By: Kristoff Rand
                    jellybean2012
                    I hope you can help because your render looks awesome - I've installed it and followed your instructions which all seem to work perfectly - however, when I try and render it in vRay it's not visible -- it's like it doesn't exist...
                    am i just being thick?
                      Can v-ray render 'images' inside a SKP ?
                      Some renderers can't.
                      Perhaps they need exploding ??
                        Krisidious
                        I have no idea about that... sorry.
                        By: Kristoff Rand
                          Krisidious
                          love this plugin... still trying to get the hang of it. I don't seem to get consistent results. like adhesion doesn't seem to really make the vine adhere as it does make it grow shorter distances with each click.
                          By: Kristoff Rand
                            tomot
                            This Ivy generator is a got attempt at copying Thomas Luft's Ivy generator , but still has some minor problems such as collision detection which the SketchUp API may not not contain. 😞
                            [my plugins](http://thingsvirtual.blogspot.ca/)
                            tomot
                              the.pjt
                              is it possible to change the SKP files located in the Plugins\LiveIvy\Textures and replace its JPEG textures with PNGs ?
                              so this plugin could results transparent textured leafs ...
                              because now we should change textures every time
                              can I do it ? ...or ... will the plugin make bad results ?? longer time ??
                              thanks ... πŸ˜‰
                              • rodrigonotorR Offline
                                rodrigonotor
                                Hi Pj, is not problem change the files, only make shure you put the same names for components.
                                http://img215.imageshack.us/img215/3357/20052011070953pm.jpg
                                http://img803.imageshack.us/img803/6654/20052011075532pm.jpg
                                You can use the *.png file inside the leaf component.
                                Here are the leaf component I use.
                                ivy_leaf_enavas.rar
                                β€’ [Sketchando.net](http://foro.sketchando.net/portal.php) β€’ www.arqcad.net β€’
                                  Krisidious
                                  thanks ... πŸ˜‰
                                  yes you can... that's what I did to allow transparency.
                                  By: Kristoff Rand
                                    the.pjt
                                    thanks ..
                                    so I have another question .. why Pierreden (author) have used JPG textures in Plugins\LiveIvy\Textures ? he could use PNGs ... couldn't he ? ...
                                    I'm going to change components in the directory (Plugins\LiveIvy\Textures) .. πŸ˜„
                                    • bigstickB Offline
                                      bigstick
                                      This still doesn't work on the Mac. In case anyone is tempted to try the updated version in the hope that it will work on the Mac, nope. Not for me, and after all the posts so far, I'm not the only one having trouble with this. This updated version doesn't actually fix anything as far as I can see.
                                      To summarise:-
                                      The dialog works. This latest version has the default values as krisidious shows in his post. I'm grateful for this, it was one of the things I thought that might be the cause of the plugin not working. However, the ivy will still not 'grow'.
                                      Also the problem where this plugin inserts the leaf components into every single model still persists. This is a bug in my opinion.
                                      I'm guessing that it's bad etiquette to modify someone else's plugin, but I really wish someone would fix these issues. It's one I have been itching to use for a long time, and it's still frustrating that it almost works.
                                      I haven't seen anything from Pierreden for some time, but surely he wouldn't mind someone else fixing this...
                                        the.pjt
                                        Hi Dear Sketchucators πŸ˜„ ..
                                        I have Updated This Nice plugin
                                        all I have done is Making a Toolbar and an Icon For this little Nice Ivy Plugin ..
                                        And I also made it an Extension .. So You can temporary disable it ...and then enable it
                                        I have NOT changed Its codes so it's still vr 1.6.3
                                        but you will see 1.6.3.1 version in SU's preferences panel because of these little changes ...
                                        Have a nice day πŸ˜› .. and a nice toolbar πŸ˜„
                                        πŸ‘Ž DOWNLOAD IT NOW
                                        LiveIvy.zip
                                        important : it's not an a stand alone plugin because it doesn't cautions TEXTURE folder .. you should extract it to your plugins folder and replace its files with existing rubies
                                        • OxerO Offline
                                          Oxer
                                          Thanks for the toolbar!! πŸ‘
                                          • Gus RG Offline
                                            Gus R
                                            Noticed something the other day. When I open a new instance of SU8 it loads all of the "ivyleaf" components into the new model. It also loads these same components if I open a drawing from Windows Explorer or using the File -> Open command. It won't load if I open a drawing from the pull down menu withing SU or if I start a second new drawing.
                                            This is using the latest version of Sketchup Ivy from the first page. Not really a critical issue for me but I thought you might want to be aware of this. Didn't see if this was brought up in the previous discussion.
                                            www.instagram.com/gusrobatto/
                                            www.facebook.com/gusrobatto
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 33 / 37
