    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
    • KrisidiousK
      Krisidious
      I had to resave each of the leaves as a new sketchup file with the original name. I also saved them using png textures that I saved into the same textures folder so I could have transparency.
      this fixed the issue of the vine not producing leaves or branches.
      here are the default settings if you mess them up and can't find your way back.
      By: Kristoff Rand
        jellybean2012
        I hope you can help because your render looks awesome - I've installed it and followed your instructions which all seem to work perfectly - however, when I try and render it in vRay it's not visible -- it's like it doesn't exist...
        am i just being thick?
          Can v-ray render 'images' inside a SKP ?
          Some renderers can't.
          Perhaps they need exploding ??
          • KrisidiousK
            Krisidious
            I have no idea about that... sorry.
            By: Kristoff Rand
            • KrisidiousK
              Krisidious
              love this plugin... still trying to get the hang of it. I don't seem to get consistent results. like adhesion doesn't seem to really make the vine adhere as it does make it grow shorter distances with each click.
              By: Kristoff Rand
              • T
                tomot
                This Ivy generator is a got attempt at copying Thomas Luft's Ivy generator , but still has some minor problems such as collision detection which the SketchUp API may not not contain. 😞
                my plugins
                tomot
                • T
                  the.pjt
                  is it possible to change the SKP files located in the Plugins\LiveIvy\Textures and replace its JPEG textures with PNGs ?
                  so this plugin could results transparent textured leafs ...
                  because now we should change textures every time
                  can I do it ? ...or ... will the plugin make bad results ?? longer time ??
                  thanks ... πŸ˜‰
                  • rodrigonotorR
                    rodrigonotor
                    Hi Pj, is not problem change the files, only make shure you put the same names for components.
                    http://img215.imageshack.us/img215/3357/20052011070953pm.jpg
                    http://img803.imageshack.us/img803/6654/20052011075532pm.jpg
                    You can use the *.png file inside the leaf component.
                    Here are the leaf component I use.
                    ivy_leaf_enavas.rar
                    β€’ Sketchando.net β€’ www.arqcad.net β€’
                    • KrisidiousK
                      Krisidious
                      thanks ... πŸ˜‰
                      yes you can... that's what I did to allow transparency.
                      By: Kristoff Rand
                      • T
                        the.pjt
                        thanks ..
                        so I have another question .. why Pierreden (author) have used JPG textures in Plugins\LiveIvy\Textures ? he could use PNGs ... couldn't he ? ...
                        I'm going to change components in the directory (Plugins\LiveIvy\Textures) .. πŸ˜„
                        • bigstickB
                          bigstick
                          This still doesn't work on the Mac. In case anyone is tempted to try the updated version in the hope that it will work on the Mac, nope. Not for me, and after all the posts so far, I'm not the only one having trouble with this. This updated version doesn't actually fix anything as far as I can see.
                          To summarise:-
                          The dialog works. This latest version has the default values as krisidious shows in his post. I'm grateful for this, it was one of the things I thought that might be the cause of the plugin not working. However, the ivy will still not 'grow'.
                          Also the problem where this plugin inserts the leaf components into every single model still persists. This is a bug in my opinion.
                          I'm guessing that it's bad etiquette to modify someone else's plugin, but I really wish someone would fix these issues. It's one I have been itching to use for a long time, and it's still frustrating that it almost works.
                          I haven't seen anything from Pierreden for some time, but surely he wouldn't mind someone else fixing this...
                          • T
                            the.pjt
                            Hi Dear Sketchucators πŸ˜„ ..
                            I have Updated This Nice plugin
                            all I have done is Making a Toolbar and an Icon For this little Nice Ivy Plugin ..
                            And I also made it an Extension .. So You can temporary disable it ...and then enable it
                            I have NOT changed Its codes so it's still vr 1.6.3
                            but you will see 1.6.3.1 version in SU's preferences panel because of these little changes ...
                            Have a nice day πŸ˜› .. and a nice toolbar πŸ˜„
                            πŸ‘Ž DOWNLOAD IT NOW
                            LiveIvy.zip
                            important : it's not an a stand alone plugin because it doesn't cautions TEXTURE folder .. you should extract it to your plugins folder and replace its files with existing rubies
                            • OxerO
                              Oxer
                              Thanks for the toolbar!! πŸ‘
                              • Gus RG
                                Gus R
                                Noticed something the other day. When I open a new instance of SU8 it loads all of the "ivyleaf" components into the new model. It also loads these same components if I open a drawing from Windows Explorer or using the File -> Open command. It won't load if I open a drawing from the pull down menu withing SU or if I start a second new drawing.
                                This is using the latest version of Sketchup Ivy from the first page. Not really a critical issue for me but I thought you might want to be aware of this. Didn't see if this was brought up in the previous discussion.
                                www.instagram.com/gusrobatto/
                                www.facebook.com/gusrobatto
                                • P
                                  pololo
                                  [attachment=0:7h5c99gs]<!-- ia0 -->LiveIvy.zip<!-- ia0 -->[/attachment:7h5c99gs]
                                  Hello Friend, I have problems with your toolbar, I can't see your toolbar or icons ,Could you show me step by step how to make it work?
                                  I have downloaded your file, but doesnt work. What should I do to fix this? πŸ˜•
                                  I have Sketchup 8 on win7 64 bits. Thanks!!
                                    jacimta1
                                    I have problema installing this. I have attempted to install it both in windows and mac, could you please explain me the installing process on both? Thank you in advance πŸ˜„
                                    • B
                                      bulbangs
                                      i am experiencing an error installing this:
                                      Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_Base.rb
                                      can't convert nil into StringError Loading File LiveIvy.rb
                                      • rodrigonotorR
                                        rodrigonotor
                                        Hi PJT, still not working. Do it in clean install.
                                        Thanks anyway.
                                        Regards
                                        • KrisidiousK
                                          Krisidious
                                          SketchupIvy.0.6.4.beta.zip
                                          repacked with working leaf skp files and transparent png textures also included default setting jpg's.
                                          By: Kristoff Rand
                                            This telling you that it can't find a file to load...
                                            ../Plugins/LiveIvy/LiveIvy_Base.rb
                                            This almost certainly means that the tool's subfolder of files in not in the 'Plugins' folder where it must be!
                                            Can you post a screen-shot of your 'Plugins' folder showing what you have actually installed...
                                            Also check your security permissions - these should be FULL for all Sketchup's subfolders, like 'Plugins'.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 36
                                            • 37
                                            • 20 / 37
