    Mini-challenge
    328 Posts 26 Posters 34.2k Views 26 Watching
      Is this "close enough"?
      PinkBoard-BlueBoard.skp
      • jason_marantoJ Offline
        jason_maranto
        Absolute accuracy seems to be something that would be pretty easy since we know all of the measurements, including the first diagonal -- I would just rotate a copy of the diagonal around the midpoint to make the second diagonal, thus giving all 4 ending points for the shape... but I would need to calculate the specific degrees for the rotation, and I'm not well versed in that level of math.
        Definitely seems a plugin to make this is a need after all... if absolute accuracy is required.
        Best,
        Jason.
          Very close - but surely it should be possible for full accuracy..?
            I also noticed that if I crank up the decimals, I get an inaccurate measurement for that thickness (although a different one) ๐Ÿ˜•
            Now the very interesting thing is that I did not do any shearing but only worked with the rotate tool. So there could be inaccuracy but then it's Sketchup's tolerance when it merged two endpoints so close that I could see the electrons spinning. But then yes, I was indeed relying on this "tolerance" (just did not know how it will work).
            • jeff hammondJ Offline
              @thomthom said:
              So how do you calculate it?
              the way i calculate it in the DC :
              you can find all the info of the hypotenuse (green) in a variety of ways .. (for instance, a^2 + b^2 = c^2 to get its length.. you'll know a & b in this caseโ€ฆ then trig for the angles)
              that hypotenuse is also the the hypotenuse of the un-trimmed board (red).. so you know the board width and the length of its hypotenuse which means you can get all other angles and lengths..
              the rotation of the original hypotenuse minus the long angle of the board's hypotenuse give the correct rotation angle..
              here's the DC i use (after i use 'component options' to enter the dimension of height, board width, and the space in between the two poles, i'll then trace the results and copy/paste it into my actual drawing.. not entirely ideal but it works..)
              DC_Xbrace.skp
              for whatever reason, i still think there might be a way to do it in sketchup itself.. maybe jean L can come up with something ๐Ÿ˜‰
              so far, it's looking like true-tangents may be the key.. i haven't tried it yet in this circumstance but i imagine it will work.
                Excellent, Jeff.
                • pbacotP Offline
                  @ecuadorian said:
                  @andybot said:
                  ... thus - for best accuracy, draw it in ACAD and import into sketchup ๐Ÿ˜’
                  Amen. Trimble, if you're reading this, we need actual arcs and curves in SketchUp.
                  i'm not quite sure they could give us true arcs in sketchup without entirely changing the way sketchup works.. (how would a cylinder be drawn if there were no segments in the arcs? a nurbs surface? )
                  what they can give us, i feel, is 'guide arcs' โ€ฆwhich would also allow us to rotate this thing and snap it into place very easily.
                  Someone at Trimble is saying "What? There aren't real circles? Oh crap! What have we done?"
                  • pbacotP Offline
                    OK, what's wrong with Mac 1's version. Can the reference point from the tip to tip dimension be accurately placed on the horizontal guideline to give a marker for snap rotation of the board? I think it is the same problem, requiring math calculating length parallel to board tip to tip.
                      what they can give us, i feel, is 'guide arcs' โ€ฆwhich would also allow us to rotate this thing and snap it into place very easily.. basically, a smarter rotate tool.
                        i'm still working through the thread.. checking mac's version next.. i'll report back ๐Ÿ˜„
                          jason_maranto
                          The DC is not working for me for some reason -- I see it and formulas, but no interactivity.
                          This is a variation on few similar solutions here -- but they all have a minor (or not so minor) variance -- it just does not make sense to me why ๐Ÿ˜•
                          I mean the rotate tool should be accurate since it is not tied to polygons (like arc or circle), right?
                          Best,
                          Jason.
                          • bmikeB Offline
                            bmike
                            maths, gotta love it. nice problem to post jeff!
                            tricky little problem, hitting opposite corners on that board. especially when graphically, you can't quite get there with sketch up.
                            i've been working on a DC to sort of automate hip and valley creation in timber.
                            in order to get this far i've built a dc (both hip and valley) with sub components that are planes that rotate about with in the 'container' component. there are guidelines at the peak where this would potentially miter. the foot condition changes too much - so i usually do some solids work or intersecting with the model down there.
                            here's a snap of the attributes (runs off the bottom of the window):
                            and the component:
                              yeah, that version doesn't work either.. when rotating the guide point downwards, there's no actual snap to the top of the board..
                              many of these methods would work if we could just rotate and snap to a random point along a line.. but we can only snap to a line's endpoints etc.. (in other words, a lot of people see what needs to be done.. it's just that we can't do it ๐Ÿ˜‰ )
                                use 'component options'.. not 'component attributes'..
                                  I was suspecting something like that - but my trigonometry knowledge was all too poor that I dared place bets on it.
                                  I also wonder this - but I also fear it might - due to lack of true arcs.
                                  Where is Simon Le Bon btw..?
                                    SOH CAH TOA ๐Ÿ˜„
                                    that's one of the things that seemed to stick with me after leaving school..
                                    Sine = Opposite/Hypotenuse
                                    Cosine = Adjacent/Hypotenuse
                                    Tangent = Opposite/Adjacent
                                      That stuck with me, too. I can't remember who I took to prom, though.
                                        Trouble is that I don't even remember what to use of this. I'm really annoying - I always have to look up this stuff, reading for a while, whenever I need to do such work with my plugins. ...which, when you place plugins for 3D software... ...I really should be knowing this... ๐Ÿ˜ณ
                                          Well, I figured out some of the accuracy issue on my last approach -- a bit of user error on my part since I was rotating the guidepoint to the wrong place and also the accuracy setting of the rotate tool was not set high enough... actually this still isn't exactly accurate (rotated to 45.6085) but it's pretty close now.
                                          Try with the posts further apart - then you'll catch accuracy issue much easier. When it's close to 45 degrees it's harder to spot.
                                            jason_maranto
                                            @Jeff - I checked every aspect of interacting with a DC, it shows nothing for me.
                                            Edit -- Gotcha, you have to actually open the model instead of bringing it in as a component.
                                            Best,
                                            Jason.
                                            • 16
                                            • 17
                                            • 8 / 17
