    Mini-challenge
    328 Posts 26 Posters 37.9k Views 26 Watching
      @jason_maranto said:
      This is really easy with the native tools -- here's a short tut file: [attachment=0:3gkxsinp]<!-- ia0 -->challenge.skp<!-- ia0 -->[/attachment:3gkxsinp]
      Best,
      Jason.
      How do you place the horizontal guides such that you get the fixed width of the diagonal board?
        Looking at it, it's just as if you skewed a 0,50m board - which is not correct.
        • jason_marantoJ Offline
          jason_maranto
          This is really easy with the native tools -- here's a short tut file: challenge.skp
          Oh, I see why this might be a challenge -- you want a specific width to the crossboard... give me a sec.
          Best,
          Jason.
          • andybotA Offline
            andybot
            Too funny Jeff. I do this all the time in AutoCAD with a circle guide, but stupid sketchup segmented circles, I really don't see any way. Thanks for the brain melt... ๐Ÿ˜†
              Until today I have never been too bothered about SketchUp's segmented arcs and circles - I've always found a way around it. But this... arrrrhh!!!
              And - I noticed if you have a circle, make a pie segment where one line snaps from centre til vertex and the other from centre to mid-segment - SketchUp will claim the segment is an Arc. But it's not! ๐Ÿ˜ฒ I was thinking that if I adjusted the segments with the Entity Info the arc would readjust the two ends to be true to it's original circle - but instead it result in two different length radius.
              • andybotA Offline
                andybot
                ... thus - for best accuracy, draw it in ACAD and import into sketchup ๐Ÿ˜’
                  Have you the files in V6 ? ๐Ÿ˜‰ (save as V6)
                  • E Offline
                    Ecuadorian
                    Amen. Trimble, if you're reading this, we need actual arcs and curves in SketchUp.
                    -Miguel Lescano
                      Jason, that not quite the same as the original challenge, though. Make it so the diagonal board's ends are mitered with vertical cuts, not horizontal ones.
                        jason_maranto
                        I cleaned it up, streamlined the process a bit (removed a few unnecessary steps) and saved for version 6: challenge_final.skp
                        I was looking at the very first image in the thread, is that not what we are shooting for here?
                        Best,
                        Jason.
                        • fredo6F Offline
                          Jeff,
                          Not sure plugins are allowed in this challenge, and unless I am wrong, this could be done with the but normally Planar Shearing can be performed with FredoScale
                            @Fredo
                            Is your frame changing thickness? It does for me
                              jason_maranto
                              I got it accurate just using basic tools, but you have to do some contorting to get it done:(see this post for the file http://forums.sketchucation.com/viewtopic.php?p=401904#p401904)
                              I misread the beginning of the thread and initially thought the dimensions were not important... which is why the first version did not achieve victory ๐Ÿ‘Š
                              Best,
                              Jason.
                                A little light in my deseperation? ๐Ÿ˜„
                                • pbacotP Offline
                                  [off:19rh2vop]
                                  The thing absolutly crazzy is that the Rotation tool
                                  seems accept just the base alignement as only good alignement! ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ
                                  I am totally depited! ๐Ÿ˜ฎ
                                  I love this word![/off:19rh2vop]
                                  Yes if heights are not a given... Push pull the posts to the diagonal ๐Ÿ’š
                                    Jason, how do you determine the where the diagonals hit the sides of the posts?
                                    Fredo's example does result in a narrower board. It could also be achieved with native tools by selecting one end of the board and moving that end up.
                                      If you measure .5m up and down the verticals, the board is not going to be .5m thick.
                                        jason_maranto
                                        The desired thickness is .5 meters -- so the first guides are each measured out to .5 meters from the main diagonal (the only one that is obvious and never changes).
                                        So the next Diagonal can be found at intersections at .5 m guide up on the left post and .5 m guide down on the right post -- from there you delete the original guides and connect the diagonals with the line tool.
                                        After that you pull off new guides to .5m from the bottom and top -- which again will give the corrected diagonal at the intersections on the left post and right post... the other diagonal has been known since the beginning(doesn't ever change).
                                        All I used was the line tool, tape measure tool, and push pull.
                                        Best,
                                        Jason.
                                        • fredo6F Offline
                                          @Fredo
                                          Ooops. I should have read the thread in details.
                                          Then, it just need a dedicated plugin, this won't be a conform transformation
                                            jason_maranto
                                            It is as I show in the updated file.
                                            Best,
                                            Jason.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
