    A new home for SketchUp
    822 Posts 171 Posters 435.4k Views 171 Watching
    • K
      kwistenbiebel
      Good luck, Sketchup Team .
      Please tell your new boss that it is very important that Sketchup runs faster for bigger projects (64 bit/higher polygon capabilities , faster with sun-shadows on/ faster outliner etc...
      For architecture , especially bigger projects that incorporate photorealistic rendering with external plugins, it has been a dream since the @Last era to have a smoother running Sketchup for that goal.
      In architecture, Sketchup is still the 3D product where everybody has a laugh with.
      Whenever I tell people I use Sketchup mainly as my architecture modeling software , response usually is "are you serious?", expecting the 3DStudio, Maya, Revit, Archicad as the answer.
        roland joseph
        That should be Goodbye Google Earth,
        No it is going to become the focus of their activity...they are in the positioning business.
        Good news for the arch-vis community.
          You are aware that 64bit doesn't mean faster speeds, right? Just more memory.
          http://blogs.sas.com/content/sasdummy/2012/04/19/myths-about-64-bit-computing-on-windows/
          • EscapeArtistE
            EscapeArtist
            .[/size]
            imo, all sketchup free development could cease at this moment and the free users would still be left with a great product..
            years ago, i spent $500 on an app that was far inferior to what sketchup free is today.. and i was hyped when i bought it!
            but they're saying that a free version will remain available and i honestly don't see them down scaling the free version to something unusable.. in fact, i really don't imagine they will downscale it all..
            I believe a free version will remain, but I still have a concern regarding what will be available on that version. Also, plugins are a concern. As SU advances under Trimble, will compatibility exist for the current plugin set or will it be phased out in favor of paid plugins?
            • K
              kwistenbiebel
              Scratch 64 bit, just 'faster' and more responsive in which ever way that would translate technically 😄.
              I suspect it has more to do with how Sketchup was coded than any other reason.
              A very simple example: exploding a large model is not possible in an elegant way, if you're lucky it actually worked after SU being unresponsive for 4 hours.
              Those kind of immensely annoying things 😄
              • cheddaC
                chedda
                Does this apply to mac osx as well as windows ? How is it modo blender and numerous other applications are moving in this direction ? Surely larger memory usage will help performance and support larger poly models ? I am well aware that sketch up would need to be re-written to use multiple cpu's but at sometime we all see beach balls and egg timers right ? (like Kwisten mentioned exploding objects etc is a killer)
                Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                • jbacusJ
                  jbacus
                  These are old arguments, frequently discussed by me and others. CAD software is notoriously resistent to multithreading and 64-bit doesn't make models run faster. What you really want, what all users want, is software that runs whatever model you are working on today faster. Historically, we've delivered 'faster' with every release. 😉
                  "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
                  John Bacus
                  jbacus@sketchup.com
                    roland joseph
                    This is what I hear with ear to the ground. Don't quote me. My hearing is bad
                    At the top of their list is a plan to capture ruby revenue. A panel will choose a select group of rubies and start to negotiate with the owners. This ruby set will be provided with a permanent front end in SU. You can bet they will be in the positioning application vertical.
                    Since they are trying to capture a ruby revenue stream they will create a STK that must be used to develop and install/register. You will have to use their kit.
                    Then look for a complete name change in the new year. Trimble will attempt to raise the profile from blue jeans to shirt and tie. The “sketchy” reputation is something they will quickly position themselves to resolve. As for the name change. No serious Sketchup user will drop the tool because of a name change but new customers will turn their heads. The word Sketchup will disappear forever.
                    Set your browser to http://www.forums.trimble-u-cation.com….....lol
                      +1 Exploding is very slow - it's not exploding itself - but adding geometry to SketchUp. The more geometry in the context you add geometry to - the slower it takes. When you explode you quickly see the effect of this because it can often mean a huge amount of geometry. I can only speculate, but I suspect that part of that might be SketchUp's auto-split feature - where geometry automatically merges - something very few other modelling tools has.
                      They often include render engines - render engines do have advantage of more memory. It also in a great deal the render engines that makes up for the "multi-core" features for these applications. The modelling tools are still using single core - because mostly they cannot be split into multiple cores-
                      No - more memory just means more memory. There is nothing inherit in that it will be faster and perform any other magic action. Remember that 64bit means that the datatypes also consumes twice as much as 32bit - that's double the data!
                      Yes - many features would be very nice with improved performance - though that race will never end. They up the performance and we will still demand more. But being generic about the requests is much better - explaining your ultimate goal "better performance" - instead of demanding a technical implementation (64bit, multicore) assuming it's the holy grail of solutions. They make the software - they know their trade - they know what to do in order to gain performance. Often a new algorithm can bring a massive performance gain. So don't be disillusioned over 64bit, multicore or other buzz-words - emphasize on your abstract goal and communicate that.
                      Another thing to consider when comparing applications - SketchUp do live-render it's sketchy style in the viewport - where many other of the heavy weight applications will degrade the viewport experience. They are relying on the model to be rendered with a render engine - SketchUp has a built in render engine generating presentation graphics on the fly. This takes it toll on performance. In addition it has a smart inference engine rarely featured in other applications - which also consumes it's share of the performance. Then it's the automatic merge and split of faces - it's doing a lot of work constantly which other doesn't.
                        Is this just pure guesswork or do you have something to back this up with?
                        • jbacusJ
                          jbacus
                          I just sat down over my morning cappuchino and read this thread from front to back again, and was left with one overwhelming thought. You guys are awesome. Really.
                          Change is tough for everyone and there's every reason to fear that things could go completely pear-shaped at any moment. There's no way to say for sure what will happen. We're making some sausage here, and that isn't always the most elegant thing to watch.
                          But we've been making SketchUp-style sausage for a long time now and have survived many adversities. We've had a fair measure of success, too. There is absolutely no rational reason why a tiny little startup like ours should have been able to stand up against entrenched industry mega-competitors. The reason it has worked is... you guys— the designers, builders and makers of things. The people who worry about us.
                          If you're worried, then I'm confident. People who could care less if we make it don't 'worry'— they just don't show up at all. And one thing we know for sure is that people actually use SketchUp. They are showing up in droves, as it turns out.
                          Hang in there— this is going to be... fun!
                          John Bacus
                          jbacus@sketchup.com
                            I'm really interested to see how it goes. I have every confidence it'll be good.
                            Glad you are staying with the team as well as the rest who are.
                              No info about price of Pro Version ?
                              Increase / decrease / stable ?
                                It seems kind of early for that sort of info, doesn't it?
                                • F
                                  frv
                                  Good news Sketchup moved away from Google. Google was not in any way a CAD company. I see that Trimble also has Tekla. Tekla has a good reputation here in the Netherlands for Civil engineering software and is the biggest competitor for Revit. That is for the field of construction and engineering. From what I have heard Tekla has better integrated 3D modelling and 2Doutput than Revit.
                                  With 30 millions users things are not going to change overnight. I hope the long term brings us a much better 3D modeller in terms of speed and integration with renderapplications and 2D output. Revit is showing architects are more and more involved in 3D modeling combined with BIM engineering. Sketchup has not evolved at all in that direction yet. With Trimble we might see a more serious attempt to model and engineer with Sketchup.
                                  • P
                                    pixelmonkey380
                                    ummm... wow.
                                    chris<pixelmonkey>:D
                                      MrDentini
                                      I've been told that SU will be greatly simplified.
                                      SketchUp simplified
                                      • T
                                        tald311
                                        I would doubt that the name would change. 10 years of brand recognition. While many companies are re-branding, Comcast to XFinity, QWest to CenturyLink, as examples, usually its because of negative public sentiment with the Brand.
                                        30 million downloads and 2 million active users for a 3D modeling program is great Brand recognition.
                                          roland joseph
                                          ..no not fully guess work but for the name change.
                                          Trimble is about to baptise The 3Dwarehouse and GE.
                                          the SketchUp engine will be integrated into Trimble's current solutions in its Engineering and Construction, Field Solutions and Mobile Solutions segments.
                                          I think it will be all good but the focus is moving with a big step towards engineering. Those that have turned GE and the warehouse into assets (in whatever disipline) are going to win big.
                                          On the tool kit...So far it has been an extravaganza. There will have to be a more unified approach to the new core....Engineers are not going to except that your ruby could damage their infrastucture. This will be good for ruby developers although it will require more scrutiny of the ruby supply chain.
                                          • Alan FraserA
                                            Alan Fraser
                                            Is it just coincidence that some of the more negative and sceptical comments come from people relatively new to this forum...and probably the software. I see that one of them signed up today, presumably to specifically post a downer...4 minutes after joining. Others have devoted almost all their limited number of posts so far to this single topic.
                                            We've heard all this before when Google acquired @Last..."They'll kill it off." "They'll ruin it then dump it." "Better learn Blender/Modo/Hexagon/Wings3D/Rhino/Max/Insert Program of Choice."
                                            Development under Google wasn't always as rapid as I'd have liked, or always in directions that were relevant to me personally...but SU is unquestionably streets ahead now from where it was then.
                                            I fully expect to be using this software for years to come, producing assets for everyone from architecture through interior design and landscaping to movie previz; and I fully expect it to keep improving its capabilities in those areas.
                                            There's nothing in any information currently available that would lead you to think otherwise...unless you deliberately go out of your way to put the worst possible interpretation on everything.
                                            3D Figures
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 41
                                            • 42
                                            • 13 / 42
