    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 131.8k Views 42 Watching
      shahkoorosh
      thank you very much thomthom for this plugin, but unfortunately I couldn't use this.
      when I try to open SU this error will appears.
      could u help me? thanks πŸ˜„
      Error
        If you go back to the first page - where you downloaded the .rb file from you will see it says you require a support 'library' of files.
        Use the link to get it, extract it and place its folder into the Plugins folder.
        After Sketchup restarts it ought to find the required files in that folder and so your errors should stop...Capture.PNG
          I'm going to change my template so that plugins will display a more Plain English message that TT_Lib is missing.
            shahkoorosh
            After Sketchup restarts it ought to find the required files in that folder and so your errors should stop...[attachment=0:3vcl16zk]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:3vcl16zk]
            Thanks dude, It's worked
              seen
              Thank you very much πŸ‘
              • O Offline
                optimaforever
                Hello Thom,
                This script is very useful.
                Now when you export a batch of cameras from SU it resets the output resolution to your default 800x600.
                Is it possible to keep the last output resolution by default? (I mean, if I saved a PNG in 2000x1000, the next output will keep 2000x1000 instead of 800x600)...
                Thanks anyway.
                Ryo
                  I have an update coming up soon. Not ready yet though.
                    You can change the code using a text editor.
                    I've mine setup to my resolution. πŸ‘
                      raineysky
                      Add mindreader to your list of skills. I just did a two hour search of the forums regarding transparent backgrounds and came across this. THANK YOU!!!
                        RichardU
                        I'm looking forward to it. Thanks.
                          RichardU
                          Cookieware donation sent. I don't know how you plan to update this, but it is very useful as is.
                          Thanks,
                          Richard
                            Thank you! πŸ˜„
                            I have an update in development - more of a merge, transformation with V-Ray Tools (Don't worry, no V-Ray needed.)
                            Important new feature is that it tries to make up for the camera shifting that occurs when you set the aspect ratio.
                              GIphil
                              Excellent Plugin! The export values are a bit strange but I am just being picky! Thanks for your hard work!
                                Strange values?
                                • FrederikF Offline
                                  Frederik
                                  Lately I've experienced that when I export a scene with transparency, in a resolution 4000x3000, I can see the transparency using the standard Windows Image viewer, however, I'm unable to open the png-file in PhotoShop...
                                  It's just saying that it's unable to parse the file... πŸ˜•
                                  Also... I can't see the image if I try to use XnView...
                                  Cheers
                                  Kim Frederik
                                    Sample file?
                                    • FrederikF Offline
                                      Frederik
                                      Here you go... πŸ˜„
                                      (NB! 37.8Mb) https://dl.dropbox.com/u/9887081/Test-for-Thomthom.png
                                      Like I said, I'm able to open and see it with the standard Windows Image browser and I can open it in i.e. Firefox as well, but not in Adobe PhotoShop CS5.1 and XnView also have an issue when trying to see it... 😐
                                      Cheers
                                      Kim Frederik
                                      • FrederikF Offline
                                        Frederik
                                        OK...
                                        I found a way to make it work...
                                        Open the file with Microsoft Office Picture Manager and export it to a new png-file...
                                        The size will reduce from 37.8Mb to 1.58Mb and I can't see any quality loss... πŸ˜’
                                        Check this https://dl.dropbox.com/u/9887081/Test4Thomthom2.png
                                        I'm able to open the new file in PhotoShop...
                                        Edit: Well... It seem that I need to do something before it works, like use the crop tool and then export it...
                                        The result is that the file size reduces significantly and then I'm able to open it in PhotoShop without any quality loss...
                                        https://dl.dropbox.com/u/9887081/Test4Thomthom3.png
                                        Strange... πŸ˜•
                                        Cheers
                                        Kim Frederik
                                          37.8MB for a 4400x2250px PNG image??? That ain't right.
                                          Inspecting your file in a hex editor and it's full of NULL bytes. :s
                                          The plugin leaves the writing for the image to SketchUp. And I've never seen this before.
                                          My first thoughts are that this is a issue local to your machine. Are you for instance saving to a network drive etc?
                                            I don't know what it is to be honest.
                                            Does it happen to all models?
                                            Do you have another computer nearby where you can try?
                                            • 5 / 8
