    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 128.6k Views 42 Watching
      Also make sure that you turn off ground and sky in your styles settings and set background colour to pure white (255,255,255)
      • N Offline
        nomeradona
        never realized that this was a year old posting and yet this is my first time to see this excellent script. Thanks Thomas.
          AlainBo
          Very nice.
          Could you just remember the settings we choosed, at least per session?
          Could you have alook at the fields's parsing orde via tab key?
          And why not a "respect aspect ratio checkbox?
          And why not automatically add the .png extension which not seems to be the case. In fact if we don't specify extension, the image is not generated.
          Wow, will be perfect.... lol
          Thanks,
          Alain
            shahkoorosh
            thank you very much thomthom for this plugin, but unfortunately I couldn't use this.
            when I try to open SU this error will appears.
            could u help me? thanks πŸ˜„
            Error
              If you go back to the first page - where you downloaded the .rb file from you will see it says you require a support 'library' of files.
              Use the link to get it, extract it and place its folder into the Plugins folder.
              After Sketchup restarts it ought to find the required files in that folder and so your errors should stop...Capture.PNG
                I'm going to change my template so that plugins will display a more Plain English message that TT_Lib is missing.
                  shahkoorosh
                  After Sketchup restarts it ought to find the required files in that folder and so your errors should stop...[attachment=0:3vcl16zk]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:3vcl16zk]
                  Thanks dude, It's worked
                    seen
                    Thank you very much πŸ‘
                    • O Offline
                      optimaforever
                      Hello Thom,
                      This script is very useful.
                      Now when you export a batch of cameras from SU it resets the output resolution to your default 800x600.
                      Is it possible to keep the last output resolution by default? (I mean, if I saved a PNG in 2000x1000, the next output will keep 2000x1000 instead of 800x600)...
                      Thanks anyway.
                      Ryo
                        I have an update coming up soon. Not ready yet though.
                          You can change the code using a text editor.
                          I've mine setup to my resolution. πŸ‘
                            raineysky
                            Add mindreader to your list of skills. I just did a two hour search of the forums regarding transparent backgrounds and came across this. THANK YOU!!!
                              RichardU
                              I'm looking forward to it. Thanks.
                                RichardU
                                Cookieware donation sent. I don't know how you plan to update this, but it is very useful as is.
                                Thanks,
                                Richard
                                  Thank you! πŸ˜„
                                  I have an update in development - more of a merge, transformation with V-Ray Tools (Don't worry, no V-Ray needed.)
                                  Important new feature is that it tries to make up for the camera shifting that occurs when you set the aspect ratio.
                                    GIphil
                                    Excellent Plugin! The export values are a bit strange but I am just being picky! Thanks for your hard work!
                                      Strange values?
                                      • FrederikF Offline
                                        Frederik
                                        Lately I've experienced that when I export a scene with transparency, in a resolution 4000x3000, I can see the transparency using the standard Windows Image viewer, however, I'm unable to open the png-file in PhotoShop...
                                        It's just saying that it's unable to parse the file... πŸ˜•
                                        Also... I can't see the image if I try to use XnView...
                                        Cheers
                                        Kim Frederik
                                          Sample file?
                                          • FrederikF Offline
                                            Frederik
                                            Here you go... πŸ˜„
                                            (NB! 37.8Mb) https://dl.dropbox.com/u/9887081/Test-for-Thomthom.png
                                            Like I said, I'm able to open and see it with the standard Windows Image browser and I can open it in i.e. Firefox as well, but not in Adobe PhotoShop CS5.1 and XnView also have an issue when trying to see it... 😐
                                            Cheers
                                            Kim Frederik
                                            • 5 / 8
