    Reducing size of model
    12 Posts 9 Posters 1.3k Views 9 Watching
      jrm1
      I'm a landscape designer. My SU models use a lot of 3D plants, which slows the Mac down after a while. I was wondering if there were any tips for keeping the size down.
      For instance, does grouping reduce the 'load' on the computer?
        Place them on a layer on turn the layer off while navigating
          jrm1
          What slows down the performance of Sketchup most of all? Plants are a killer, as is Shadows On. I need both unfortunately!
          If I go to V Ray, that causes a crash on my MacBook Pro i5 machine with just a moderate number of plants on the model.
          Any Mac users out there who can recommend a MacPro desktop configuration for models with up to say 4 million edges and 2 million faces?
            jrm1
            Hi Rich, I do that, but turning them on again takes a while when you have as many plants as I have.
              That's the nature of the beast I'm afraid.
              There are plugins that help like GhostComp
              • jo-keJ
                jo-ke
                deleting unused components and texutres is usefull too.
                http://www.zz7.de
                  Edge Styles kill performance at least as bad as Shadows.
                  • jeff hammondJ
                    check out jean's post about using 'work' and 'render' scenes..
                    404 Not Found
                    (forums.sketchucation.com)
                    basically, you're maxing out the app.. there's no button to push to make the issues you're facing go away.. you pretty much have to figure out the limits.. then find a way to stretch those limits out a little further..
                      mrossk
                      how about the trick of replacing poly heavy objects like plants with a temporary spacer, like a stick, and then replacing those components at the end when needed?
                      https://www.mkaplanfinefurniture.com/
                      • jgbJ
                        jgb
                        If you have a lot of 3D plants that are just used as cover, and are not "models" in of themselves, replace them with 2D "always face camera" equivalent components.
                        Placing the existing 3D plants on a layer (on/off as needed) will only help the pan and zoom performance of SU, not the model size, which affects everything.
                        jgb
                        • Alan FraserA
                          Alan Fraser
                          Avoid 3D plants wherever possible, use 2D Face Camera components. Even there...if you are presenting your visuals as V-ray renders...use 2D plants with the minimum number of edges. In V-Ray this could mean simply having the images on their original rectangular billboard (as with the stuff from Imagecels).
                          If you are also using native SU output, then use billboarded plants with the bare minimum of edges to the cutout...just enough to throw a reasonable looking shadow. The vignette doesn't need to follow every in and out of every branch. Edge-count can degrade performance just as much as face-count.
                          Where you absolutely do need o have 3D, then use purpose-built SU trees and shrubs. It's possible to build a decent looking SU tree with anything between 50 and 5000 faces, depending on usage. This Ginko...which is fully 3D and casts a decent shadow...has only 614 faces. X-Frog and Onyx content is a SU killer...as are the pirated, imported versions of it that appear in the 3D Warehouse.
                          http://www.formfonts.com/files/1/5087/20ft-ginko-biloba-various-foliage_FF_Model_ID5087_2_ginko01_au.jpg
                          There is some good, purpose-built stuff in the 3DW...like these below by a guy calling himself pepe...but they are few and far between.
                          http://doc-0k-8g-3dwarehouse.googleusercontent.com/3dwarehouse/secure/hhulr73hmmak89paul31eote4ben7ngk/j9c5ukoo9aqh7a1nfk61rhvaeovaq23u/1335852000000/lt/*/b39c21c07e8ccb012a7dbb39776cdf0c?ts=1202487865000&ctyp=other
                          3D Figures
                          • ToboboT
                            Tobobo
                            Hey, do all the modelling in the landscape arch team. what i do is combine the VRay render wit photoshop. I avoid 3d trees like the plague. My pc (at work) and macbook pro (at home) both struggle with 3d plants at all.
                            If I were you i would forget the 3d plants and buy a good image pack.
                            This is the one we bought, obviously it is Β£300 but they do smaller packs. http://www.3drender.co.uk/products-page-2/bundles/all-in-one-bundle-complete-1000/#
                            Toby
                            Philippians 4:13
