    Faces appearing from nowhere while working with .dwg import
    42 Posts 3 Posters 2.4k Views 3 Watching
      IF you have a set of spot-height points in a DWG... then there are several tools to convert these into a terrain mesh - once they have been imported into a SKP; but they don't magically convert when imported - you do need to do some work...
      Also here's a lot of dross in a DWG that you don't need to import into the SKP, that can be deleted/purged first...
      If you explained better what you have and what you want to end up with then we could perhaps help you better... πŸ˜•
        Garuf
        I see.
        Well, I'm a landscape architecture student and I was planning on presenting my site design using sketchup or at least using it as point where I could try and turn it into some "proper" renders, add illumination get some proper textures in there, make it look less video game like etc.
        I was also thinking I could export it through layout to avoid having to redraw things in CAD because I don't know how to use cad properly.
        I've ordered a copy of this: http://www.amazon.co.uk/Google-SketchUp-Site-Design-Architecture/dp/047034525X/ref=lh_ni_t_mi
        But it's taking forever and a day to arrive so I've been trying to do what I can here and there so I'm not dead in the water as the deadlines creep up.
          All right but what we are trying to squeeze out of you is what you have in hand. Without knowing the kind of the data, we keep stabbing in the dark.
            Gareth
            As Gai pointed out the SKP you gave us only contains a 2d site plan imported from a CAD drawing.
            There is no 3d info or 'spot-heights' etc in it...
            Can you provide the original DWG/DXF file [r2004 or earlier]?
            How do you hope to make this into 3d mesh?
            What other information do you have? [that you are keeping to yourself and thereby stopping us helping you to solve this!]
            If your CAD drawing contains 'text' as spot heights without 'points' then the import will not include them as 'text' is ignored. Also if the text is 'flat' you need to relocate it in the Z with a point so that an import into a SKP then includes it [cpoint-clouds can then be made into a mesh using one of several tools]. I have an AutoLisp routine that does this relocation on a DWG [it's not 'for public consumption', but I can probably help you out]...
            However, we need to know what we have to work with here - the longer you keep us in the dark, the nearer the deadline comes; without a solution being at hand...
              Garuf
              Ahhh I see. I'll include my working rough master plan then. I was planning on creating the mesh as I had in the past by working out the lowest point in the model then treating this as the base then drawing an array of verticals where the spot heights on my plan were and then joining them up to create a terrain. I was always certain there was a better way though because it takes forever.
              My .DWG came from Leeds city council originally and when the text is turned on has spot heights for the area.
              stylistically his is my end goal: http://bp1.blogger.com/_Ymx9e66vrGc/SH7SNrCTvGI/AAAAAAAADco/aFMdUZyfWn0/s400/PT_Eastside_city_view_ready.jpg
              http://www.cityfarmer.info/wp-content/uploads/2011/10/harlemfarm.jpg
              http://archiculturefilm.com/director/wp-content/uploads/2009/04/biotopes_1000.jpg
              I was then planning on using layout to produce a master plan that could be overlayed on G.earth to look like this.http://t1.gstatic.com/images?q=tbn:ANd9GcSApdJacS6xlacAc0D-64DMgANB8WCgtiD5iLd2JHm_0ZWUx4bk17pT3hPXAQ
              ED307 - Final Project - Sov Street.zip
                First off, this is made with a more recent version of AutoCAD than I have.
                I can't convert it using the free AutoDesk converter as it says the DWG has an 'Educational Use Only' stamp in it!
                Can you save_as it to a r2004 version and reattach, or PM it...
                This is 2d plan it can't be used to make a 3d mesh without running several processes on its data...
                I do have tools to find its text entities, read their real heights and relocate them in the Z with points; for import into a SKP, where Ruby scripts can take these cpoints and convert them into a surface mesh.
                You seem to be making heavy weather of solving this... πŸ˜’
                  Garuf
                  sorry. 😞 I'm a forum mod myself I know how frustrating it can be dealing with an idiot. πŸ˜†
                  I run and education version of cad which is free but limited in what you can do with it, I'll see what I can do with regards back saving the file.
                    Garuf
                    Here's a version saved in 2004 format. That's the oldest version I can save as.
                    Soverign Street Base Plan.zip
                      Thanks, I'll get back to you [I can go back to r12!]...
                      Why DXF rather than DWG ?
                        Garuf
                        It was the only format it would let me save as that was older that 2010.
                          I've had to extract all of the levels '32.1m' mtext from the rest by filtering, now my tool fails with the trailing 'm' so I'm stripping those off...
                          Watch this space...
                            Garuf
                            Oh, you're a diamond! I'd be forever drawing vertical lines if it was left to me.
                              Here you go...
                              ED307 - Final Project - Sov Street[TIG].zip
                                Garuf
                                Just waiting for CAD to open the two files. Presumable I now take the mesh and drape my existing cad plan over it or snap to a landmark and I can then extrude the buildings and river etc?
                                I'm really sorry to ask so many questions this is the first I've used a grid shell terrain.
                                  You don't need to open the CAD files at all !
                                  I sent you the SKP mesh - ready made !!
                                  I'm unsure how you imported the CAD 'lines', so you might need to realign the two parts...
                                  The 3d mesh is much bigger than the 2d line-work...
                                  The site's pretty flat in the end so it's not that great 😞
                                  If you Drape [or SuperDrape] the 2d line-work down onto the 3d surface that's your first step...
                                    Garuf
                                    Thanks for all the help I'm entirely in your debt. What I did was import the .dwg using "import" then just deleted the areas of the site I didn't need. I'll be adding a lot of topography I should think so it's not time wasted as It all helps with working out drainage and disabled access/site levels. I suppose if I use the same cad file I sent you then crop it once I've draped it.
                                      Garuf
                                      Okay. So I've spent the day tinkering and every time I try and drape my imported cad plan onto the mesh I get a "bug splat" crash. Any suggestions? 😲
                                        Very complex objects [or meshes] can splat.
                                        Have you tried splitting the object to be draped into a few grouped parts with less geometry and then doing them in turn...
                                        Also avoid nested 'containers' inside the draped object.
                                        My SuperDrape tool will also drape faces inside a selected group onto the mesh in another group, using somewhat different methods.
                                        The advantage of it is that the original materials are transferred for each of the newly 'imprinted' outlines...
                                          Garuf
                                          Still no cigar, I split the baseplan into 8 and then tried to drape (I've not had time to try super drape)and every single time I've got a bug splat. 😞 I can copy and paste the drawing in but as soon as I try draping I get bug splatted. Also, this may be a stupid question but which version of my file did you use to create the mesh from, it's noticeably larger than either of my cropped plans is all...
                                          I'll track down super drape now and try and see how that works out for me.
                                          Could it be that my pc isn't powerful enough, I'm only running 2gb of ram with cooking the other 2gb stick of ram.
                                            Someone was recently reporting problems with Drape if Podium was also loading - any connection ??
                                            • 2 / 3
