    Faces appearing from nowhere while working with .dwg import
    42 Posts 3 Posters 2.4k Views 3 Watching
      Garuf
      Ahhh I see. I'll include my working rough master plan then. I was planning on creating the mesh as I had in the past by working out the lowest point in the model then treating this as the base then drawing an array of verticals where the spot heights on my plan were and then joining them up to create a terrain. I was always certain there was a better way though because it takes forever.
      My .DWG came from Leeds city council originally and when the text is turned on has spot heights for the area.
      stylistically his is my end goal: http://bp1.blogger.com/_Ymx9e66vrGc/SH7SNrCTvGI/AAAAAAAADco/aFMdUZyfWn0/s400/PT_Eastside_city_view_ready.jpg
      http://www.cityfarmer.info/wp-content/uploads/2011/10/harlemfarm.jpg
      http://archiculturefilm.com/director/wp-content/uploads/2009/04/biotopes_1000.jpg
      I was then planning on using layout to produce a master plan that could be overlayed on G.earth to look like this.http://t1.gstatic.com/images?q=tbn:ANd9GcSApdJacS6xlacAc0D-64DMgANB8WCgtiD5iLd2JHm_0ZWUx4bk17pT3hPXAQ
      ED307 - Final Project - Sov Street.zip
        First off, this is made with a more recent version of AutoCAD than I have.
        I can't convert it using the free AutoDesk converter as it says the DWG has an 'Educational Use Only' stamp in it!
        Can you save_as it to a r2004 version and reattach, or PM it...
        This is 2d plan it can't be used to make a 3d mesh without running several processes on its data...
        I do have tools to find its text entities, read their real heights and relocate them in the Z with points; for import into a SKP, where Ruby scripts can take these cpoints and convert them into a surface mesh.
        You seem to be making heavy weather of solving this... πŸ˜’
          Garuf
          sorry. 😞 I'm a forum mod myself I know how frustrating it can be dealing with an idiot. πŸ˜†
          I run and education version of cad which is free but limited in what you can do with it, I'll see what I can do with regards back saving the file.
            Garuf
            Here's a version saved in 2004 format. That's the oldest version I can save as.
            Soverign Street Base Plan.zip
              Thanks, I'll get back to you [I can go back to r12!]...
              Why DXF rather than DWG ?
                Garuf
                It was the only format it would let me save as that was older that 2010.
                  I've had to extract all of the levels '32.1m' mtext from the rest by filtering, now my tool fails with the trailing 'm' so I'm stripping those off...
                  Watch this space...
                    Garuf
                    Oh, you're a diamond! I'd be forever drawing vertical lines if it was left to me.
                      Here you go...
                      ED307 - Final Project - Sov Street[TIG].zip
                        Garuf
                        Just waiting for CAD to open the two files. Presumable I now take the mesh and drape my existing cad plan over it or snap to a landmark and I can then extrude the buildings and river etc?
                        I'm really sorry to ask so many questions this is the first I've used a grid shell terrain.
                          You don't need to open the CAD files at all !
                          I sent you the SKP mesh - ready made !!
                          I'm unsure how you imported the CAD 'lines', so you might need to realign the two parts...
                          The 3d mesh is much bigger than the 2d line-work...
                          The site's pretty flat in the end so it's not that great 😞
                          If you Drape [or SuperDrape] the 2d line-work down onto the 3d surface that's your first step...
                            Garuf
                            Thanks for all the help I'm entirely in your debt. What I did was import the .dwg using "import" then just deleted the areas of the site I didn't need. I'll be adding a lot of topography I should think so it's not time wasted as It all helps with working out drainage and disabled access/site levels. I suppose if I use the same cad file I sent you then crop it once I've draped it.
                              Garuf
                              Okay. So I've spent the day tinkering and every time I try and drape my imported cad plan onto the mesh I get a "bug splat" crash. Any suggestions? 😲
                                Very complex objects [or meshes] can splat.
                                Have you tried splitting the object to be draped into a few grouped parts with less geometry and then doing them in turn...
                                Also avoid nested 'containers' inside the draped object.
                                My SuperDrape tool will also drape faces inside a selected group onto the mesh in another group, using somewhat different methods.
                                The advantage of it is that the original materials are transferred for each of the newly 'imprinted' outlines...
                                  Garuf
                                  Still no cigar, I split the baseplan into 8 and then tried to drape (I've not had time to try super drape)and every single time I've got a bug splat. 😞 I can copy and paste the drawing in but as soon as I try draping I get bug splatted. Also, this may be a stupid question but which version of my file did you use to create the mesh from, it's noticeably larger than either of my cropped plans is all...
                                  I'll track down super drape now and try and see how that works out for me.
                                  Could it be that my pc isn't powerful enough, I'm only running 2gb of ram with cooking the other 2gb stick of ram.
                                    Someone was recently reporting problems with Drape if Podium was also loading - any connection ??
                                      Garuf
                                      Nope, I've a plug in for kerkythea but I've never really used it.
                                        Garuf
                                        Took all my files into uni, still getting a bug splat even when using their PCs. 😲
                                        Where am I going wrong? 😐
                                          Garuf
                                          CRACKED IT!
                                          Presumably now I have the terrain draped onto the site I now have to extrude the buildings separately and then stamp them onto the terrain where they ought to be extruding now results in the building coming out of the ground at what ever angle the face is at rather than along the blue axis?
                                          Siteterrain.skp
                                            Try my ExtrudeEdgesByVectorToObject - pick points up in the Z [blue].
                                            Select all of the building's perimeter edges [faces+double-click], run the tool.
                                            You now have a grouped set of vertical walls - edit/add to them them as needed [remember to erase internal 'partitions' and then orient them all the same way - blue=in]
                                            • 2 / 3
