[Plugin] FredoTools - v4.5a - 02 Apr 24
Thanks Fredo Nice Work
Need Help Can not Save my new german translation ??
and in 000_AdditionalPluginFolders i got the message:2ERRORS The Following plugins had errors and may not be fully loaded
Plugin: LMapExt.so
Folder:C/ProgramFiles(x86)Google/GoogleSketchup8/Plugins
ERROR: (eval):1: uninitialized constant
AdditionalPluginFolder6;;LMap
(I Have Not createt an extra Plugin Folder)
and
Plugin: win 32api.so
ERRER: 127
Init_win32api
C/ProgramFiles(x86)Google/GoogleSketchup8/Plugin/win 32api.soThanks for help
SU8 on win7
Plugin: LMapExt.so
and
ERRER: 127
Init_win32api
SU8 on win7
This does not seem related to my scripts.
Maybe some users could tell what is this LmapExt.so fileFredo
It's associated with LightUp and it should be in the Tools folder
I downloaded last FredoTools 1.1 and LibFredo 44, all tools works good except ThruPaint. When i paint by texture(not by colour!) ScetchUp8 crushes! What is a reson of it?
Could "Reverse Faces" be available in the context menu of Thru Paint?
I think this is possible, but the Auto-flip option was there precisely to flip faces on the same side.
Is it reproducible and systematic?
Are you sure this is only with texture, never with color?Thanks
Fredo why don't you incorporate 'LibFredo' files with 'Fredo tools' pack?
Simply because LibFredo6 is used by many of my other plugins and that you usually need to have the latest version installed.
So incorporate all your stuff (which ~90% is a 'must have') in ONE megapack (with ability to selectively install\uninstall)
Just like another guru does:
http://www.neilblevins.com/cg_tools/soulburnscripts/soulburnscripts.htm -
Yes, Fredo. This is systematic and this is with textures only. As i put brush with texture to an object, it stay panted by texture,red clocks of waiting appears and program fly out immediately! All other plugins and programmes works properly.
Thanks. -
Hi Fredo,
Apart from all my congatulations for this marvelous plugin, just one wish: would it be possible to set the font size used in the dialog boxes and palettes ? (See below)
Best regards, -
@didier bur said:
Hi Fredo,
[attachment=0:1c1a4qq2]<!-- ia0 -->fredoToolsFontSize.jpg<!-- ia0 -->[/attachment:1c1a4qq2]
Best regards,Didier,
I have no control over the font size of text displayed within a Tool (i.e. view.draw_text).
Do you know how to do it?Thanks
help me plz.....when i start sketch up 7, i vizit this massage (undefined method `register_plug' for FredoTools:ModuleError ) any many of this plugin dosent work....whats my solve?
Have you downloaded the supporting folder [LibFredo...]?
It is linked from the main download page.
If you do not have that folder installed most of the Fredo tools will not work!
If you have installed it then make sure that it is installed properly - as explained on its own download page...
NEW RELEASE: FredoTools v1.2a - 08 May 12
This update is dedicated to ThurPaint 1.2. It fixes some bugs and introduces Painting of Components, groups, text labels and Dimensions. See this post for details.
See main post of this thread for download of FredoTools.
fredo, is possible add other tool?
a tool that with one click an item or unlocking hidden + hide.
and another for displaying the items hidden.is it possible? thanks
Can't you do most of this from the context-menu [lock/unlock & hide/unhide] and/or a simple shortcut-key to hide/unhide geometry [view-menu], combined with shortcut-keys to 'hide-rest of model' and 'hide similar components' [view>component-edit]... and the Entity-Info or Layer-drop-down list to give objects an 'off' layer etc... these add up to a powerful set of tools - without the need for an extra tool... -
I just noticed strange behavior of "Remove lonely vertices" tool. It wants to remove not lonely vertices on a circle - look at the screenshot.
Is this due to the new version of SU 8.0.15158?
I can't get that problem to repeat.... unless I make extreme segmentation of an arc - to unreasonable extents.
To check if a vertex with two edges is 'unneeded' the tool checks if those two edges are parallel and if they are then the vertex is removed. The accuracy of Sketchup's vector checks for them to be considered parallel, is to a tiny fraction of a degree.
A curve with very small segments might appear to have its adjacent edge segments that are then effectively 'parallel'. However, you will need to have very tiny segment lengths relative to the curve's radius; e.g. ~1mm segments for a 500mm radius... which is then running into hundreds of segments...
So for me it only gets confused if you have 'extreme segmentation'.
