    [Plugin] Edge Tools
    211 Posts 74 Posters 328.0k Views 74 Watching
      @function said:
      Hi, I updated to ttLib 2.6 and the new edge tool and it no longer gives me thr heads up display or red circles 😞
      Any errors in the Ruby Console?
      Are you sure you installed the updates correctly?
      • F
        function
        Ill have to look when I get home. I installed fredos multi directory at the time, and since it wasnt working I installed it back to root plug folder.. Maybe it is the division of the lib in different directories
          rv1974
          I'm really missing 'divide face' tool working with multiple (connected) edges. πŸ˜’
            Wouldn't Tools on Surface do what you want there?
              rv1974
              doh! I forgot TOS offset works non-curves. thanks!
                rv1974
                I re-found why TOS offset is no good for me. Can one make it to extend the resulted curve to the face border?
                  It is doing what it should do and it it mathematically correct. You can extend those line segments with the Line tool. You could also try using Matt666's ExtendTool.
                    rv1974
                    Yes captain I realize that it's undoubtedly correct behavior. Initially I just asked Thomthom to extend his 'divide tool' (by accepting multiple edges)
                      The key concept of the Divide Tool was that you didn't pre-pick edges. It was to allow you to quickly pick a reference edge and make a split. Multiple edges would be a completely different tool.
                        rv1974
                        ..would be completely different amazingtool πŸ˜‰
                          Put file In V6 πŸ˜‰
                          It's better for everybody! πŸ˜„
                          An image ist sufficient! πŸ€“
                            rumcajs
                            Thanks to great plugin. It is something that i looked for, just it misses something.
                            I have a REQ to update/upgrade.
                            This is what I did:
                            http://i47.tinypic.com/6sqpnd.png
                            (the light red lines are original locations of the diagonals, which I tried to remove. You can see I succeed to removed only two).
                            I had a scull which contains triangles and I wanted to reduce the triangles, so that I want to remove the diagonal of the rectangle shape area. Therefor I select two lines which are nearly parallel and the diagonal. Then I clicked the green colinear icon. It works to flat the edges onto one plane, so I can delete the diagonal. But if I want to correct the next area, then the previous area will generate diagonal... Here I am where I was on the start. Could it be possible to define the area (select faces), which is already fine and I won't be touched? So the edges of that face won't be touched?
                            This is the point what I miss. A possibility to limit the edges to move (=forbid some edges/faces to move) and/or possibility to define angle, in which it can be moved.
                            My original idea, before I found this thread was to have a definition plane, such as it is in the Fredo Scale tools (the Stretching with orientation of scaling box). So if you would have such orientation plane, you could define, where the plane should be moved (angle& position). Purpose of such plane is to define position and angle of the plane. Something like Fredo already did in his great Fredo Scale tools (they are good for control, and that is what I like and therefor mention here as good example). The plane needs only one direction to move, and this would define axis perpendicularly to the plane. I expect that the angle possibilities are defined by the selected tool and the differences between selected edges (so in my case, when I have 3 edges, only two angles are possible to infer - just an assumption).
                            head 17 middle line corrected on eye center .skp
                              rumcajs
                              OK I attached file to previous post of mine. But I think the image is sufficient, and if you think it is not, then install fredo Scale tool, because the Stretching tool + twist tool, is enough to get inspiration.
                              • beginnerB
                                beginner
                                ThomThom,
                                Really good plugin.
                                You can appreciate it if you work with AutoCAD files.
                                Thanks πŸ‘ πŸ‘ πŸ‘
                                Regards, SU 'beginner'
                                  jorge2011
                                  Thom, if I when be able use the new toolbar "architecture"?. πŸ˜„ thanks
                                    Soon my friend, soon! πŸ˜„
                                      jokewalker
                                      @dedmin said:
                                      Hey all,
                                      Just installed 2.0.4 and am seeing this pop up again. Any simple fixes to make this go away?
                                        Did you get-and-install the TT Lib that was linked on the download page ?
                                          jokewalker
                                          TIG,
                                          I did have a version of TT_Lib2 in the Plugins folder already, but went ahead and re-downloaded/installed per your suggestion. Seems to be working now. Thanks!
                                            sarkarshomit
                                            Thanks ...very useful for me....
                                            Shomit,
                                            India
                                            • 11
                                            • 8 / 11
