    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • T
      tak2hata
      @boilingsnow said:
      Thank you for your explanation.
      But how can I define the "hugo" of an entity?
      Is "Query Attribute" another plugin which I have to install to check and change "hugo" of entities?
      Hi,boilingsnow.
      "Query Attribute" is display the attributes of entity.
      It can be download in my homepage.
      But it can not change attributes.
      I will create editor for attribute of building structure tool.
      But this is too early alpha ,yet.
      Now,you open "default_pflist.csv" and add profiles with attaching attribute".
      or Use "Add New profile" in menu of building structure tool.
      And draw wall by using wall tool of building structure tool.
      Thanks.
      by TAK2HATA
      • T
        tewakul
        godd
        • Y
          ygcl
          it looks very good
          • V
            vilcoyote57
            Hi, great plugin.. but I can't understand how EXCHANGE tool works. Can you help me? thanks
            • T
              tak2hata
              Hi,vilcoyote57.
              "EXCHANGE" is not work well yet.
              How to use.
              1.Select the group / component that is solid.
              2.Click "EXCHANGE".
              3.Select "Type" in dialog.
              It is all.
              The longest edge of the group/ component is used to length about element of building structure.
              Thanks.
              by TAK2HATA
                SUFractal
                @millzye71 said:
                Very good plug in indeed!!! Could this be modified so that you could use these steel sections as rafters, and be able to rotate them at a degree up or down on the axis that you have drawn. This would be great when modelling steel frames.
                Cheers
                Millzye
                Couldn't you draw a 'wire frame' (for lack of a better way of saying it) then use the desired steel section tool to 'trace' along the wireframe line?
                  SUFractal
                  tak2hata:
                  I've been working with your wonderful BuildingStuctureTools plugin recently. Are you planning on creating any additional tools (and icons) for your plugin?
                  Although it appears relatively easy to add additional profiles to the existing tools you've created, I think it would be even more convenient if there were separate tools for things such as:
                  "flanged" steel columns the (H-shapes as you've named them)
                  round steel columns
                  steel angles (L-shapes)
                  steel channels ([-shape)
                  C-shape steel (these appear to be steel studs)
                  T-shaped steel
                  flat bars
                  By adding more tools, the list for each tool would not be quite so long in the window menu that pops up. For example, instead of just one "steel column" tool, having one (with its icon) for each shape "type" (H, round, square) would be easier/faster to find the structural member needed.
                  Thanks,
                  SUFractal
                  • T
                    tak2hata
                    @sufractal said:
                    tak2hata:
                    round steel columns
                    T-shaped steel
                    flat bars
                    Thanks,
                    SUFractal
                    Hi,SUFractal.
                    I will create new dialog with WEBDIALOG.
                    It will be more convinient.
                    Please wait.
                    Now,Searching with word like "H-100" to use icon "Dialog ALL".
                    Click the icon ,InputBox"Search" will show.
                    It will show limiting items in listbox.
                    Thanks.
                    by TAK2HATA
                      SUFractal
                      @tak2hata said:
                      @sufractal said:
                      tak2hata:
                      round steel columns
                      T-shaped steel
                      flat bars
                      Thanks,
                      SUFractal
                      Hi,SUFractal.
                      Please wait.
                      Thanks.
                      Sounds great! Thank you.
                      • guanjinG
                        guanjin
                        The tool is very useful, language translation of documents, can not be displayed correctly
                        • beginnerB
                          beginner
                          Hi There,
                          The plugin is great.
                          I have only one problem with the 'default_pflist.csv' file.
                          The editing of the file doesn't take any effect in SketchUP.
                          Is anybody successfully added any new 'sizes'?
                          I would appreciate your comments.
                          Regards
                          Regards, SU 'beginner'
                            SUFractal
                            @beginner said:
                            Hi There,
                            Regards
                            Did you change the contents (sizes) within that file?
                            • beginnerB
                              beginner
                              Hi There,
                              I have seen the tutorial http://www.youtube.com/watch?v=oSVrbJMSSB0&feature=player_embedded and I have noticed that you can change the path to the *.csv file.
                              I have created a new file, located on My Desktop and changed the path - it works! but... when I change to the plugins path it doesn't.
                              Never mind, I like the fact that you can link own *.csv file and it can seat in my preferred location.
                              Thank you
                              Regards
                                SUFractal
                                @beginner said:
                                Hi There,
                                Thank you
                                Regards
                                I don't know this to be 100% true, but I suspect that file does not belong on your desktop, but probably within the "building_structure_tool" folder located inside your plugins folder. Give it a try and see if that corrects the problem.
                                • beginnerB
                                  beginner
                                  @sufractal said:
                                  Hi There,
                                  You are right the file does not belong to the Desktop - it is my copy of the file from ...\Plugins\building_structure_tool folder to play with.
                                  As I said - When I edit the file in the plugins folder I don't see any changes in SketchUP but...
                                  When I edit the file on my desktop (outside the plugin folder - you can keep the copy of the file anywhere you like) and change the path in SketchUP I can see the changes (picture attached).
                                  Path to the default_pflist.csv - now I will change to my Desktop copy and I will see my new steel, walls etc. types
                                  • G
                                    go45454
                                    thankkkkkkkk
                                    • brookefoxB
                                      brookefox
                                      tak2hata, Thanks very much for this promising set of tools. I hope you find the time to make the videos larger and maybe more complete.
                                      I tried copying and slightly altering the wall to have a baseboard on both sides but this seems to 'break' the proper corner corrections you have made the program perform. I see all your multi-walls are one sided; do they have to be? Could the standard application methods be adapted to trimming around window or door openings?
                                      ~ Brooke
                                        sags
                                        thanks... 👍
                                          josephcase
                                          I apologize if this is not correct area,
                                          I need help.. I'm tasked to create two different
                                          size CORRUGATED MULTI-PLATE pipes. The first has dia
                                          of 9'6" IS using total 6 plates @5 gage to complete 1 ring. The
                                          second is 16' IS using 8 plates @5 gage. It appears that your
                                          toolkit allows making FLAT roofing products EXCELLENT! Can
                                          it make the sections I need for circular multi plate corrugated pipe?
                                          The holes and length/width are no issue but curved as opposed to
                                          flat is. Please advise or point to tutorial for topic. Thanks Joe
                                          • T
                                            tak2hata
                                            Hi,Joe.
                                            I think that your proposal is difficult in this plugin.
                                            I think Chris Fullmer's Shape Bender is help you.
                                            http://forums.sketchucation.com/viewtopic.php?t=18210#p147395
                                            Hi,SU Fractal and Beginer.
                                            The File System of ruby in sketchup(windows) can not work well with path include the original characters of the language.
                                            I tried the many method ,but I could not find good solution.
                                            So the csv file about profile list locate the suitable folder whitch do not include the special characters.
                                            This is as hard as possible.
                                            Thanks.
                                            by TAK2HATA
                                            • 16
                                            • 17
                                            • 6 / 17
