    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • F
      franki3
      Excellent plug in will save me tons of time
      • B
        boilingsnow
        Hello,tak2hata. Thanks for your tool.
        I failed to creat new mutiwall. I don't understand your sentence "the rule of the mutiwall is do not exist tha wall that hugo each other"...
        I tried to copy the planking of your existing Multi-wall and want to make it a new one, but by drawing it doesn't connect correctly.
        Can you tell me what I am doing wrong?
        • T
          tak2hata
          Hi,boilingsnow.
          "hugo" is like as "tag".
          This" multi wall tool" judges by "hugo" to combine the wall each other.
          walls-attributes-in-Mwall
          judge_combining_each_other
          If the walls have same "hugo",tool can not judge.
          So walls in multi wall must have different "hugo" each other.
          Thanks.
          queryattributes
          walltool
          by TAK2HATA
          • B
            boilingsnow
            Hi,boilingsnow.
            [attachment=1:czfqhlvd]<!-- ia1 -->walls-attributes-in-Mwall.jpg<!-- ia1 -->[/attachment:czfqhlvd]
            [attachment=0:czfqhlvd]<!-- ia0 -->judge_combining_each_other.jpg<!-- ia0 -->[/attachment:czfqhlvd]
            Thanks.
            Thank you for your explanation.
            But how can I define the "hugo" of an entity?
            Is "Query Attribute" another plugin which I have to install to check and change "hugo" of entities?
            • T
              tak2hata
              Hi,boilingsnow.
              "Query Attribute" is display the attributes of entity.
              It can be download in my homepage.
              But it can not change attributes.
              I will create editor for attribute of building structure tool.
              But this is too early alpha ,yet.
              Now,you open "default_pflist.csv" and add profiles with attaching attribute".
              or Use "Add New profile" in menu of building structure tool.
              And draw wall by using wall tool of building structure tool.
              Thanks.
              by TAK2HATA
              • T
                tewakul
                godd
                • Y
                  ygcl
                  it looks very good
                  • V
                    vilcoyote57
                    Hi, great plugin.. but I can't understand how EXCHANGE tool works. Can you help me? thanks
                    • T
                      tak2hata
                      Hi,vilcoyote57.
                      "EXCHANGE" is not work well yet.
                      How to use.
                      1.Select the group / component that is solid.
                      2.Click "EXCHANGE".
                      3.Select "Type" in dialog.
                      It is all.
                      The longest edge of the group/ component is used to length about element of building structure.
                      Thanks.
                      by TAK2HATA
                        SUFractal
                        @millzye71 said:
                        Very good plug in indeed!!! Could this be modified so that you could use these steel sections as rafters, and be able to rotate them at a degree up or down on the axis that you have drawn. This would be great when modelling steel frames.
                        Cheers
                        Millzye
                        Couldn't you draw a 'wire frame' (for lack of a better way of saying it) then use the desired steel section tool to 'trace' along the wireframe line?
                          SUFractal
                          tak2hata:
                          I've been working with your wonderful BuildingStuctureTools plugin recently. Are you planning on creating any additional tools (and icons) for your plugin?
                          Although it appears relatively easy to add additional profiles to the existing tools you've created, I think it would be even more convenient if there were separate tools for things such as:
                          "flanged" steel columns the (H-shapes as you've named them)
                          round steel columns
                          steel angles (L-shapes)
                          steel channels ([-shape)
                          C-shape steel (these appear to be steel studs)
                          T-shaped steel
                          flat bars
                          By adding more tools, the list for each tool would not be quite so long in the window menu that pops up. For example, instead of just one "steel column" tool, having one (with its icon) for each shape "type" (H, round, square) would be easier/faster to find the structural member needed.
                          Thanks,
                          SUFractal
                          • T
                            tak2hata
                            @sufractal said:
                            tak2hata:
                            round steel columns
                            T-shaped steel
                            flat bars
                            Thanks,
                            SUFractal
                            Hi,SUFractal.
                            I will create new dialog with WEBDIALOG.
                            It will be more convinient.
                            Please wait.
                            Now,Searching with word like "H-100" to use icon "Dialog ALL".
                            Click the icon ,InputBox"Search" will show.
                            It will show limiting items in listbox.
                            Thanks.
                            by TAK2HATA
                              SUFractal
                              @tak2hata said:
                              @sufractal said:
                              tak2hata:
                              round steel columns
                              T-shaped steel
                              flat bars
                              Thanks,
                              SUFractal
                              Hi,SUFractal.
                              Please wait.
                              Thanks.
                              Sounds great! Thank you.
                              • guanjinG
                                guanjin
                                The tool is very useful, language translation of documents, can not be displayed correctly
                                • beginnerB
                                  beginner
                                  Hi There,
                                  The plugin is great.
                                  I have only one problem with the 'default_pflist.csv' file.
                                  The editing of the file doesn't take any effect in SketchUP.
                                  Is anybody successfully added any new 'sizes'?
                                  I would appreciate your comments.
                                  Regards
                                  Regards, SU 'beginner'
                                    SUFractal
                                    @beginner said:
                                    Hi There,
                                    Regards
                                    Did you change the contents (sizes) within that file?
                                    • beginnerB
                                      beginner
                                      Hi There,
                                      I have seen the tutorial http://www.youtube.com/watch?v=oSVrbJMSSB0&feature=player_embedded and I have noticed that you can change the path to the *.csv file.
                                      I have created a new file, located on My Desktop and changed the path - it works! but... when I change to the plugins path it doesn't.
                                      Never mind, I like the fact that you can link own *.csv file and it can seat in my preferred location.
                                      Thank you
                                      Regards
                                        SUFractal
                                        @beginner said:
                                        Hi There,
                                        Thank you
                                        Regards
                                        I don't know this to be 100% true, but I suspect that file does not belong on your desktop, but probably within the "building_structure_tool" folder located inside your plugins folder. Give it a try and see if that corrects the problem.
                                        • beginnerB
                                          beginner
                                          @sufractal said:
                                          Hi There,
                                          You are right the file does not belong to the Desktop - it is my copy of the file from ...\Plugins\building_structure_tool folder to play with.
                                          As I said - When I edit the file in the plugins folder I don't see any changes in SketchUP but...
                                          When I edit the file on my desktop (outside the plugin folder - you can keep the copy of the file anywhere you like) and change the path in SketchUP I can see the changes (picture attached).
                                          Path to the default_pflist.csv - now I will change to my Desktop copy and I will see my new steel, walls etc. types
                                          • G
                                            go45454
                                            thankkkkkkkk
