    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 503.1k Views 108 Watching
      tak2hata
      @d_e_x said:
      Hi Tak,
      I am excited to see that I am not alone in developing a BIM plugin 😄 Great work!
      My plugin (SketchUpBIM) is focused on Building Modeling, and follows a similar methodology as the commercial BIM softwares. I would be very happy if you check it out and provide your feedback and comments: http://forums.sketchucation.com/viewtopic.php?f=323&t=41840
      other BIM gurus on this forum, please feel free to provide feedback as well!
      dex
      Hi,d_e_x.
      Your project is very exciting to me ,too.
      I wish BIM being free and open.
      Sketchup is one of best application for that goal.
      I will check your project out.
      Thanks.
      by TAK2HATA
      • guanjinG Offline
        guanjin
        Hello: I edited the language file, change the language in the environment, selection, or display the original language!
        Please enlighten me
          tak2hata
          I update to v0.5.4 in Dec 18 , 2011.
          Small Improve:Multi wall work on sketchup v6 ,too.
          Hi,XIAOLONG.
          Thanks to your reply.
          I do not consider language setting enough.
          I will improve lang setting after updating this plugin to v1.0.
          Please wait small long time.
          by TAK2HATA
          • guanjinG Offline
            guanjin
            Hi,XIAOLONG.
            Most of the language can not change, 1.0 a long time oh
            • F Offline
              franki3
              Excellent plug in will save me tons of time
                boilingsnow
                Hello,tak2hata. Thanks for your tool.
                I failed to creat new mutiwall. I don't understand your sentence "the rule of the mutiwall is do not exist tha wall that hugo each other"...
                I tried to copy the planking of your existing Multi-wall and want to make it a new one, but by drawing it doesn't connect correctly.
                Can you tell me what I am doing wrong?
                  tak2hata
                  Hi,boilingsnow.
                  "hugo" is like as "tag".
                  This" multi wall tool" judges by "hugo" to combine the wall each other.
                  walls-attributes-in-Mwall
                  judge_combining_each_other
                  If the walls have same "hugo",tool can not judge.
                  So walls in multi wall must have different "hugo" each other.
                  Thanks.
                  queryattributes
                  walltool
                  by TAK2HATA
                    boilingsnow
                    Hi,boilingsnow.
                    [attachment=1:czfqhlvd]<!-- ia1 -->walls-attributes-in-Mwall.jpg<!-- ia1 -->[/attachment:czfqhlvd]
                    [attachment=0:czfqhlvd]<!-- ia0 -->judge_combining_each_other.jpg<!-- ia0 -->[/attachment:czfqhlvd]
                    Thanks.
                    Thank you for your explanation.
                    But how can I define the "hugo" of an entity?
                    Is "Query Attribute" another plugin which I have to install to check and change "hugo" of entities?
                      tak2hata
                      Hi,boilingsnow.
                      "Query Attribute" is display the attributes of entity.
                      It can be download in my homepage.
                      But it can not change attributes.
                      I will create editor for attribute of building structure tool.
                      But this is too early alpha ,yet.
                      Now,you open "default_pflist.csv" and add profiles with attaching attribute".
                      or Use "Add New profile" in menu of building structure tool.
                      And draw wall by using wall tool of building structure tool.
                      Thanks.
                      by TAK2HATA
                        tewakul
                        godd
                        • Y Offline
                          ygcl
                          it looks very good
                          • V Offline
                            vilcoyote57
                            Hi, great plugin.. but I can't understand how EXCHANGE tool works. Can you help me? thanks
                              tak2hata
                              Hi,vilcoyote57.
                              "EXCHANGE" is not work well yet.
                              How to use.
                              1.Select the group / component that is solid.
                              2.Click "EXCHANGE".
                              3.Select "Type" in dialog.
                              It is all.
                              The longest edge of the group/ component is used to length about element of building structure.
                              Thanks.
                              by TAK2HATA
                                SUFractal
                                @millzye71 said:
                                Very good plug in indeed!!! Could this be modified so that you could use these steel sections as rafters, and be able to rotate them at a degree up or down on the axis that you have drawn. This would be great when modelling steel frames.
                                Cheers
                                Millzye
                                Couldn't you draw a 'wire frame' (for lack of a better way of saying it) then use the desired steel section tool to 'trace' along the wireframe line?
                                  SUFractal
                                  tak2hata:
                                  I've been working with your wonderful BuildingStuctureTools plugin recently. Are you planning on creating any additional tools (and icons) for your plugin?
                                  Although it appears relatively easy to add additional profiles to the existing tools you've created, I think it would be even more convenient if there were separate tools for things such as:
                                  "flanged" steel columns the (H-shapes as you've named them)
                                  round steel columns
                                  steel angles (L-shapes)
                                  steel channels ([-shape)
                                  C-shape steel (these appear to be steel studs)
                                  T-shaped steel
                                  flat bars
                                  By adding more tools, the list for each tool would not be quite so long in the window menu that pops up. For example, instead of just one "steel column" tool, having one (with its icon) for each shape "type" (H, round, square) would be easier/faster to find the structural member needed.
                                  Thanks,
                                  SUFractal
                                    tak2hata
                                    @sufractal said:
                                    tak2hata:
                                    round steel columns
                                    T-shaped steel
                                    flat bars
                                    Thanks,
                                    SUFractal
                                    Hi,SUFractal.
                                    I will create new dialog with WEBDIALOG.
                                    It will be more convinient.
                                    Please wait.
                                    Now,Searching with word like "H-100" to use icon "Dialog ALL".
                                    Click the icon ,InputBox"Search" will show.
                                    It will show limiting items in listbox.
                                    Thanks.
                                    by TAK2HATA
                                      SUFractal
                                      @tak2hata said:
                                      @sufractal said:
                                      tak2hata:
                                      round steel columns
                                      T-shaped steel
                                      flat bars
                                      Thanks,
                                      SUFractal
                                      Hi,SUFractal.
                                      Please wait.
                                      Thanks.
                                      Sounds great! Thank you.
                                      • guanjinG Offline
                                        guanjin
                                        The tool is very useful, language translation of documents, can not be displayed correctly
                                        • beginnerB Offline
                                          beginner
                                          Hi There,
                                          The plugin is great.
                                          I have only one problem with the 'default_pflist.csv' file.
                                          The editing of the file doesn't take any effect in SketchUP.
                                          Is anybody successfully added any new 'sizes'?
                                          I would appreciate your comments.
                                          Regards
                                          Regards, SU 'beginner'
                                            SUFractal
                                            @beginner said:
                                            Hi There,
                                            Regards
                                            Did you change the contents (sizes) within that file?
                                            • 16
                                            • 17
                                            • 5 / 17
