    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 535.3k Views 108 Watching
    • guanjinG Offline
      guanjin
      The tool is very useful, language translation of documents, can not be displayed correctly
      • beginnerB Offline
        beginner
        Hi There,
        The plugin is great.
        I have only one problem with the 'default_pflist.csv' file.
        The editing of the file doesn't take any effect in SketchUP.
        Is anybody successfully added any new 'sizes'?
        I would appreciate your comments.
        Regards
        Regards, SU 'beginner'
          SUFractal
          @beginner said:
          Hi There,
          Regards
          Did you change the contents (sizes) within that file?
          • beginnerB Offline
            beginner
            Hi There,
            I have seen the tutorial http://www.youtube.com/watch?v=oSVrbJMSSB0&feature=player_embedded and I have noticed that you can change the path to the *.csv file.
            I have created a new file, located on My Desktop and changed the path - it works! but... when I change to the plugins path it doesn't.
            Never mind, I like the fact that you can link own *.csv file and it can seat in my preferred location.
            Thank you
            Regards
              SUFractal
              @beginner said:
              Hi There,
              Thank you
              Regards
              I don't know this to be 100% true, but I suspect that file does not belong on your desktop, but probably within the "building_structure_tool" folder located inside your plugins folder. Give it a try and see if that corrects the problem.
              • beginnerB Offline
                beginner
                @sufractal said:
                Hi There,
                You are right the file does not belong to the Desktop - it is my copy of the file from ...\Plugins\building_structure_tool folder to play with.
                As I said - When I edit the file in the plugins folder I don't see any changes in SketchUP but...
                When I edit the file on my desktop (outside the plugin folder - you can keep the copy of the file anywhere you like) and change the path in SketchUP I can see the changes (picture attached).
                Path to the default_pflist.csv - now I will change to my Desktop copy and I will see my new steel, walls etc. types
                  go45454
                  thankkkkkkkk
                  • brookefoxB Offline
                    brookefox
                    tak2hata, Thanks very much for this promising set of tools. I hope you find the time to make the videos larger and maybe more complete.
                    I tried copying and slightly altering the wall to have a baseboard on both sides but this seems to 'break' the proper corner corrections you have made the program perform. I see all your multi-walls are one sided; do they have to be? Could the standard application methods be adapted to trimming around window or door openings?
                    ~ Brooke
                      sags
                      thanks... 👍
                        josephcase
                        I apologize if this is not correct area,
                        I need help.. I'm tasked to create two different
                        size CORRUGATED MULTI-PLATE pipes. The first has dia
                        of 9'6" IS using total 6 plates @5 gage to complete 1 ring. The
                        second is 16' IS using 8 plates @5 gage. It appears that your
                        toolkit allows making FLAT roofing products EXCELLENT! Can
                        it make the sections I need for circular multi plate corrugated pipe?
                        The holes and length/width are no issue but curved as opposed to
                        flat is. Please advise or point to tutorial for topic. Thanks Joe
                          tak2hata
                          Hi,Joe.
                          I think that your proposal is difficult in this plugin.
                          I think Chris Fullmer's Shape Bender is help you.
                          http://forums.sketchucation.com/viewtopic.php?t=18210#p147395
                          Hi,SU Fractal and Beginer.
                          The File System of ruby in sketchup(windows) can not work well with path include the original characters of the language.
                          I tried the many method ,but I could not find good solution.
                          So the csv file about profile list locate the suitable folder whitch do not include the special characters.
                          This is as hard as possible.
                          Thanks.
                          by TAK2HATA
                            SUFractal
                            tak2hata:
                            Today (all of a sudden) the "steel column" tool stopped working. All of the other tools appear to be working fine. I have not changed any of the scripts or files associated with this plugin for quite a while.
                            When I click on the steel column icon, a window for selecting member sizes does not appear.
                              tak2hata
                              @sufractal said:
                              tak2hata:
                              Hi,SUFractal.
                              well,I do not have a point to which it occurs.
                              So I want to see the ruby console on your sketchup.
                              Show "Ruby console" from "Window" menu.
                              Start Building structure tool"Steel Column".
                              Copy the message shown in ruby console.
                              And post it.
                              I will see and consider the problem.
                              by TAK2HATA
                              • kenK Offline
                                ken
                                @sufractal said:
                                tak2hata:
                                This has happen to me also. I found that if you go to the plugin menu and clear defaults it will start working again. At least on my computer that works.
                                Ken
                                  SUFractal
                                  @sufractal said:
                                  tak2hata:
                                  Ken
                                  Genius! Thank you Ken, it worked.
                                    kob42823
                                    Excellent 👍
                                      andyomis
                                      I am working with Sketchup 8 pro on a mac. The .rb file and the folder are in the right place and the tool bar is there. However when I open to select a tool the tool window is blank. All the appropriate file paperer to be in the folder. Any suggestions?
                                        andyomis
                                        Further to my earlier post today I now have toolbar icons etc. However I cannot select next point. Help!
                                          tak2hata
                                          Hi,Everybody.
                                          I update this "Building structure tool" to version 1.0a.
                                          Many improves added.
                                          Hi,andyomis.
                                          I want to know ruby console error message in your problem.
                                          So you open ruby console window and use Building structure tool.
                                          There will be messages.
                                          Copy the massge and reply here.
                                          I will see.
                                          Or,Install new version with RBZ file.
                                          In SKetchup Preferences menu.Click "Install Extention".
                                          And select RBZ file.
                                          That need profile list file ,too.
                                          Download each files.
                                          Thanks.
                                          by TAK2HATA
                                          • Z Offline
                                            ZFRPS
                                            Dear tak2hata:
                                            Your this plugin very very useful for **BIM**,I will always support you!
                                            But...Why to remove will general model transformation into your unique model functions?
                                            you now allow the section type is not very rich![q01.jpg](/uploads/imported_attachments/rGQI_q01.jpg)
                                            Or if you can tell how we can increase the section type!
                                            Undeniable, you are doing now is a profound things for **BIM**.
                                            THANKS AGAIN!
                                            sketchup is bim
                                            • 16
                                            • 17
                                            • 6 / 17
