    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.3k Views 107 Watching
      tak2hata
      @boilingsnow said:
      Hello,tak2hata. Thanks for your tool.
      I failed to creat new mutiwall. I don't understand your sentence "the rule of the mutiwall is do not exist tha wall that hugo each other"...
      I tried to copy the planking of your existing Multi-wall and want to make it a new one, but by drawing it doesn't connect correctly.
      Can you tell me what I am doing wrong?
      Hi,boilingsnow.
      "hugo" is like as "tag".
      This" multi wall tool" judges by "hugo" to combine the wall each other.
      walls-attributes-in-Mwall
      judge_combining_each_other
      If the walls have same "hugo",tool can not judge.
      So walls in multi wall must have different "hugo" each other.
      Thanks.
      queryattributes
      walltool
      by TAK2HATA
        boilingsnow
        Hi,boilingsnow.
        [attachment=1:czfqhlvd]<!-- ia1 -->walls-attributes-in-Mwall.jpg<!-- ia1 -->[/attachment:czfqhlvd]
        [attachment=0:czfqhlvd]<!-- ia0 -->judge_combining_each_other.jpg<!-- ia0 -->[/attachment:czfqhlvd]
        Thanks.
        Thank you for your explanation.
        But how can I define the "hugo" of an entity?
        Is "Query Attribute" another plugin which I have to install to check and change "hugo" of entities?
          tak2hata
          Hi,boilingsnow.
          "Query Attribute" is display the attributes of entity.
          It can be download in my homepage.
          But it can not change attributes.
          I will create editor for attribute of building structure tool.
          But this is too early alpha ,yet.
          Now,you open "default_pflist.csv" and add profiles with attaching attribute".
          or Use "Add New profile" in menu of building structure tool.
          And draw wall by using wall tool of building structure tool.
          Thanks.
          by TAK2HATA
            tewakul
            godd
            • Y Offline
              ygcl
              it looks very good
              • V Offline
                vilcoyote57
                Hi, great plugin.. but I can't understand how EXCHANGE tool works. Can you help me? thanks
                  tak2hata
                  Hi,vilcoyote57.
                  "EXCHANGE" is not work well yet.
                  How to use.
                  1.Select the group / component that is solid.
                  2.Click "EXCHANGE".
                  3.Select "Type" in dialog.
                  It is all.
                  The longest edge of the group/ component is used to length about element of building structure.
                  Thanks.
                  by TAK2HATA
                    SUFractal
                    @millzye71 said:
                    Very good plug in indeed!!! Could this be modified so that you could use these steel sections as rafters, and be able to rotate them at a degree up or down on the axis that you have drawn. This would be great when modelling steel frames.
                    Cheers
                    Millzye
                    Couldn't you draw a 'wire frame' (for lack of a better way of saying it) then use the desired steel section tool to 'trace' along the wireframe line?
                      SUFractal
                      tak2hata:
                      I've been working with your wonderful BuildingStuctureTools plugin recently. Are you planning on creating any additional tools (and icons) for your plugin?
                      Although it appears relatively easy to add additional profiles to the existing tools you've created, I think it would be even more convenient if there were separate tools for things such as:
                      "flanged" steel columns the (H-shapes as you've named them)
                      round steel columns
                      steel angles (L-shapes)
                      steel channels ([-shape)
                      C-shape steel (these appear to be steel studs)
                      T-shaped steel
                      flat bars
                      By adding more tools, the list for each tool would not be quite so long in the window menu that pops up. For example, instead of just one "steel column" tool, having one (with its icon) for each shape "type" (H, round, square) would be easier/faster to find the structural member needed.
                      Thanks,
                      SUFractal
                        tak2hata
                        @sufractal said:
                        tak2hata:
                        round steel columns
                        T-shaped steel
                        flat bars
                        Thanks,
                        SUFractal
                        Hi,SUFractal.
                        I will create new dialog with WEBDIALOG.
                        It will be more convinient.
                        Please wait.
                        Now,Searching with word like "H-100" to use icon "Dialog ALL".
                        Click the icon ,InputBox"Search" will show.
                        It will show limiting items in listbox.
                        Thanks.
                        by TAK2HATA
                          SUFractal
                          @tak2hata said:
                          @sufractal said:
                          tak2hata:
                          round steel columns
                          T-shaped steel
                          flat bars
                          Thanks,
                          SUFractal
                          Hi,SUFractal.
                          Please wait.
                          Thanks.
                          Sounds great! Thank you.
                          • guanjinG Offline
                            guanjin
                            The tool is very useful, language translation of documents, can not be displayed correctly
                            • beginnerB Offline
                              beginner
                              Hi There,
                              The plugin is great.
                              I have only one problem with the 'default_pflist.csv' file.
                              The editing of the file doesn't take any effect in SketchUP.
                              Is anybody successfully added any new 'sizes'?
                              I would appreciate your comments.
                              Regards
                              Regards, SU 'beginner'
                                SUFractal
                                @beginner said:
                                Hi There,
                                Regards
                                Did you change the contents (sizes) within that file?
                                • beginnerB Offline
                                  beginner
                                  Hi There,
                                  I have seen the tutorial http://www.youtube.com/watch?v=oSVrbJMSSB0&feature=player_embedded and I have noticed that you can change the path to the *.csv file.
                                  I have created a new file, located on My Desktop and changed the path - it works! but... when I change to the plugins path it doesn't.
                                  Never mind, I like the fact that you can link own *.csv file and it can seat in my preferred location.
                                  Thank you
                                  Regards
                                    SUFractal
                                    @beginner said:
                                    Hi There,
                                    Thank you
                                    Regards
                                    I don't know this to be 100% true, but I suspect that file does not belong on your desktop, but probably within the "building_structure_tool" folder located inside your plugins folder. Give it a try and see if that corrects the problem.
                                    • beginnerB Offline
                                      beginner
                                      @sufractal said:
                                      Hi There,
                                      You are right the file does not belong to the Desktop - it is my copy of the file from ...\Plugins\building_structure_tool folder to play with.
                                      As I said - When I edit the file in the plugins folder I don't see any changes in SketchUP but...
                                      When I edit the file on my desktop (outside the plugin folder - you can keep the copy of the file anywhere you like) and change the path in SketchUP I can see the changes (picture attached).
                                      Path to the default_pflist.csv - now I will change to my Desktop copy and I will see my new steel, walls etc. types
                                        go45454
                                        thankkkkkkkk
                                        • brookefoxB Offline
                                          brookefox
                                          tak2hata, Thanks very much for this promising set of tools. I hope you find the time to make the videos larger and maybe more complete.
                                          I tried copying and slightly altering the wall to have a baseboard on both sides but this seems to 'break' the proper corner corrections you have made the program perform. I see all your multi-walls are one sided; do they have to be? Could the standard application methods be adapted to trimming around window or door openings?
                                          ~ Brooke
                                            sags
                                            thanks... 👍
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
