    [plugin] Clip or Trim Terrain Mesh (Update)
    38 Posts 18 Posters 62.8k Views 18 Watching
      driven
      removed
        driven
        Love the combo tool,
        once I got my head around it EDIT removed potentially misleading comment...
        and I found a use for it for me as well. 3D cycle route maps...
        anyone got an easy way of using Google Maps as the terrain texture,
        this ones manually scaled and aligned with the 'Google Earth Snapshot' then applied as a projected texture onto the Terrain Grid.
        Maps on Terrain
        Google if your reading, can we have a map option? please...
        good work Sam
          driven
          No, me neither, I had a search for mac key-codes etc,,, but I might try searching mac 'toggle' as keycode 16 seems to work.
          EDIT 16 on it's own dosen't work on mac [I'd left the other in, but opened a copy when checking, what I'd done... sorry]
          • mitcorbM
            mitcorb
            Hi, sdmitch:
            Thank you for your generousity in sharing this tool.
            • utilerU
              utiler
              Hi Sam, On your blog you have added an impressive list of plugins including these two however there is also a 'terrain tool's plugin that doesn't have a tutorial video. How does this differ from these two listed here?
              cheers, thanks for your fantastic work!! ๐Ÿ‘
              Just Curious...
              • sdmitchS
                sdmitch
                Terrain Tools is just the collection of all my plugins that pertain to GE Terrain's. Clip or Trim being one of them plus two others. There are no other differences. I just put them all into one to help minimize the entries in the Plugins menu.
                http://sdmitch.blogspot.com/
                • utilerU
                  utiler
                  Ok, thanks Sam.Just on GE:
                  I noticed in your Clip or Trim tutorial you merge two terrains of differing proxy. Does GE determine the resolution of your export into SU by your current eye high as well as the maximum resolution you end up with?
                  I have a situation at the moment where I want to obtain the maximum resolution of of GE however my site covers about 3 hectares and I need to cover it with a GE image.
                  I wonder if there is a way recall you last selection when exporting GE imagery or even replicate your selection left and right multiplied by how far you want? [See image below...]
                  Cheers,
                  Just Curious...
                  • sdmitchS
                    sdmitch
                    Thers is no way to "automate" that that I am aware of.
                      dinkdesign
                      You guys are absolute legends. You take modeling to a whole new level.
                      I was hesitant to join SketchUcation because i hate useless info, but honestly: you guys rock!
                      Special thanx to Gaieus and ThomThom for their constant useful contributions.
                      • GaieusG
                        Well, I really had to approve this post (even though I have not contributed with anything in this topic). ๐Ÿ˜‰
                        • B
                          Ben Ritter
                          Sam, thank you for sharing your efforts.
                          • utilerU
                            utiler
                            Hi Sam, during your tutorial video at about 1:20 you say, 'If its only zoomed out 3 or 4 clicks....'
                            What are you referring too here?
                            ๐Ÿ‘
                            Just Curious...
                            • sdmitchS
                              sdmitch
                              I viewed the tutorial and I don't hear what you heard but I would assume that I am referring to zooming out from the smallest possible patch 3 or 4 clicks.
                              • utilerU
                                utiler
                                Thanks for the reply, Sam.
                                At about 1min 20sec you refer to 'if its only zoomed out 3 or 4 clicks [no more than that] the grid of the two patches match....'
                                Are you referring to zooming in Google Earth:
                                ๐Ÿ‘
                                Just Curious...
                                • sdmitchS
                                  sdmitch
                                  Yes, the Google Earth get location zoom. I thought you were talking about the clip and trim plugin not the add skirt.
                                  • utilerU
                                    utiler
                                    My bad, Sam. I can see how you would have been ill informed.... ๐Ÿ˜ณ
                                    Thank you. ๐Ÿ‘
                                    Just Curious...
                                    • G
                                      greatcurve
                                      Is there a way to make these plugins work with SU 8?
                                        Are you getting errors?
                                        The author uses SU8 - as his profile says - and usually if a plugin doesn't work with a version it's explicitly stated in the plugin description. I believe this should work with SU8.
                                          Works fine in v8
                                          • G
                                            greatcurve
                                            Sorry. I'm learning to use google/SU terrain tools as they are quite handy for making large terrains as opposed to Max.
                                            Gaieus helped me out on the Lumion forum and I was able to get everything going.
                                            • 2 / 2
