    [plugin] Clip or Trim Terrain Mesh (Update)
    38 Posts 18 Posters 59.6k Views 18 Watching
      No prob! Always good to see more people writing plugins. πŸ˜„
        driven
        Sam,
        re: 'Clip or Trim' on MAC,
        I just went over it all again and on the mac using if key ==16 || 131072 #shift PC || MAC,
        makes it work as I believe you intended. [ is it?]
        To start in 'Trim' mode:
        'grab' grid/s >> select the 'Clip or Trim' from plugins >> press shift key once to activate 'Trim' >> click on 'Terrain' to 'Trim' grid/s in turn.
        To start in 'Clip' mode:
        'grab' grid/s >> select the 'Clip or Trim' from plugins >>click on 'Terrain' to 'Clip' grid/s in turn.
        To switch between modes from either mode, press shift key once >> click on next 'Terrain'
        To exit 'Clip or Trim' click outside of all 'Terrain' groups.
        This is how it work with that change, I edited my above posts avoid to blind copying of my erroneous prior comments.
        I believe this tweak is cross platform, due to the none applicable keycode being ignored, but I don't have a PC easily at hand.
        Sorry if any confusion [other than my own] was caused by earlier comments, but I was in and out today without the time to plod through it properly.
          driven
          Sam,
          doesn't toggle on a mac, I should have pointed that out. EDIT INCORRECT you DON'T need to keep it held down
          that's what was doing my head in I checked your code and couldn't see why it wouldn't work, so I guess it's a Mac thing...
            driven
            removed
              driven
              Love the combo tool,
              once I got my head around it EDIT removed potentially misleading comment...
              and I found a use for it for me as well. 3D cycle route maps...
              anyone got an easy way of using Google Maps as the terrain texture,
              this ones manually scaled and aligned with the 'Google Earth Snapshot' then applied as a projected texture onto the Terrain Grid.
              Maps on Terrain
              Google if your reading, can we have a map option? please...
              good work Sam
                driven
                No, me neither, I had a search for mac key-codes etc,,, but I might try searching mac 'toggle' as keycode 16 seems to work.
                EDIT 16 on it's own dosen't work on mac [I'd left the other in, but opened a copy when checking, what I'd done... sorry]
                • mitcorbM Offline
                  mitcorb
                  Hi, sdmitch:
                  Thank you for your generousity in sharing this tool.
                  • utilerU Offline
                    utiler
                    Hi Sam, On your blog you have added an impressive list of plugins including these two however there is also a 'terrain tool's plugin that doesn't have a tutorial video. How does this differ from these two listed here?
                    cheers, thanks for your fantastic work!! πŸ‘
                    Just Curious...
                    • sdmitchS Offline
                      sdmitch
                      Terrain Tools is just the collection of all my plugins that pertain to GE Terrain's. Clip or Trim being one of them plus two others. There are no other differences. I just put them all into one to help minimize the entries in the Plugins menu.
                      http://sdmitch.blogspot.com/
                      • utilerU Offline
                        utiler
                        Ok, thanks Sam.Just on GE:
                        I noticed in your Clip or Trim tutorial you merge two terrains of differing proxy. Does GE determine the resolution of your export into SU by your current eye high as well as the maximum resolution you end up with?
                        I have a situation at the moment where I want to obtain the maximum resolution of of GE however my site covers about 3 hectares and I need to cover it with a GE image.
                        I wonder if there is a way recall you last selection when exporting GE imagery or even replicate your selection left and right multiplied by how far you want? [See image below...]
                        Cheers,
                        Just Curious...
                        • sdmitchS Offline
                          sdmitch
                          Thers is no way to "automate" that that I am aware of.
                            dinkdesign
                            You guys are absolute legends. You take modeling to a whole new level.
                            I was hesitant to join SketchUcation because i hate useless info, but honestly: you guys rock!
                            Special thanx to Gaieus and ThomThom for their constant useful contributions.
                              Well, I really had to approve this post (even though I have not contributed with anything in this topic). πŸ˜‰
                                Ben Ritter
                                Sam, thank you for sharing your efforts.
                                • utilerU Offline
                                  utiler
                                  Hi Sam, during your tutorial video at about 1:20 you say, 'If its only zoomed out 3 or 4 clicks....'
                                  What are you referring too here?
                                  πŸ‘
                                  Just Curious...
                                  • sdmitchS Offline
                                    sdmitch
                                    I viewed the tutorial and I don't hear what you heard but I would assume that I am referring to zooming out from the smallest possible patch 3 or 4 clicks.
                                    • utilerU Offline
                                      utiler
                                      Thanks for the reply, Sam.
                                      At about 1min 20sec you refer to 'if its only zoomed out 3 or 4 clicks [no more than that] the grid of the two patches match....'
                                      Are you referring to zooming in Google Earth:
                                      πŸ‘
                                      Just Curious...
                                      • sdmitchS Offline
                                        sdmitch
                                        Yes, the Google Earth get location zoom. I thought you were talking about the clip and trim plugin not the add skirt.
                                        • utilerU Offline
                                          utiler
                                          My bad, Sam. I can see how you would have been ill informed.... 😳
                                          Thank you. πŸ‘
                                          Just Curious...
                                            greatcurve
                                            Is there a way to make these plugins work with SU 8?
