    [plugin] Clip or Trim Terrain Mesh (Update)
    38 Posts 18 Posters 60.2k Views 18 Watching
    • utilerU Offline
      utiler
      Hi Sam, On your blog you have added an impressive list of plugins including these two however there is also a 'terrain tool's plugin that doesn't have a tutorial video. How does this differ from these two listed here?
      cheers, thanks for your fantastic work!! πŸ‘
      Just Curious...
      • sdmitchS Offline
        sdmitch
        Terrain Tools is just the collection of all my plugins that pertain to GE Terrain's. Clip or Trim being one of them plus two others. There are no other differences. I just put them all into one to help minimize the entries in the Plugins menu.
        http://sdmitch.blogspot.com/
        • utilerU Offline
          utiler
          Ok, thanks Sam.Just on GE:
          I noticed in your Clip or Trim tutorial you merge two terrains of differing proxy. Does GE determine the resolution of your export into SU by your current eye high as well as the maximum resolution you end up with?
          I have a situation at the moment where I want to obtain the maximum resolution of of GE however my site covers about 3 hectares and I need to cover it with a GE image.
          I wonder if there is a way recall you last selection when exporting GE imagery or even replicate your selection left and right multiplied by how far you want? [See image below...]
          Cheers,
          Just Curious...
          • sdmitchS Offline
            sdmitch
            Thers is no way to "automate" that that I am aware of.
              dinkdesign
              You guys are absolute legends. You take modeling to a whole new level.
              I was hesitant to join SketchUcation because i hate useless info, but honestly: you guys rock!
              Special thanx to Gaieus and ThomThom for their constant useful contributions.
                Well, I really had to approve this post (even though I have not contributed with anything in this topic). πŸ˜‰
                  Ben Ritter
                  Sam, thank you for sharing your efforts.
                  • utilerU Offline
                    utiler
                    Hi Sam, during your tutorial video at about 1:20 you say, 'If its only zoomed out 3 or 4 clicks....'
                    What are you referring too here?
                    πŸ‘
                    Just Curious...
                    • sdmitchS Offline
                      sdmitch
                      I viewed the tutorial and I don't hear what you heard but I would assume that I am referring to zooming out from the smallest possible patch 3 or 4 clicks.
                      • utilerU Offline
                        utiler
                        Thanks for the reply, Sam.
                        At about 1min 20sec you refer to 'if its only zoomed out 3 or 4 clicks [no more than that] the grid of the two patches match....'
                        Are you referring to zooming in Google Earth:
                        πŸ‘
                        Just Curious...
                        • sdmitchS Offline
                          sdmitch
                          Yes, the Google Earth get location zoom. I thought you were talking about the clip and trim plugin not the add skirt.
                          • utilerU Offline
                            utiler
                            My bad, Sam. I can see how you would have been ill informed.... 😳
                            Thank you. πŸ‘
                            Just Curious...
                              greatcurve
                              Is there a way to make these plugins work with SU 8?
                                Are you getting errors?
                                The author uses SU8 - as his profile says - and usually if a plugin doesn't work with a version it's explicitly stated in the plugin description. I believe this should work with SU8.
                                  Works fine in v8
                                    greatcurve
                                    Sorry. I'm learning to use google/SU terrain tools as they are quite handy for making large terrains as opposed to Max.
                                    Gaieus helped me out on the Lumion forum and I was able to get everything going.
                                      Gammafield
                                      This is amazingly fantastic - biiig thanx.
                                        JGA
                                        sdmitch,
                                        Thanks for sharing the terrain skirt plugin.
                                        Regards,
                                        JGA
                                          MLUY
                                          Hello Experts,
                                          When I use this plugin it tells me to select a Google Terrain patch
                                          I have a trianglar mesh terrain file which is very big
                                          How can I add a skirt and also add a bottom make it into a solid?
                                          I have tried TIG's jointpush and pull tool, but I only manage to do the skirt and
                                          cannot manage to get a solid. (Unless manually....but thats too much work)
                                          Michiel
                                          • sdmitchS Offline
                                            sdmitch
                                            @mluy said:
                                            Hello Experts,
                                            Michiel
                                            The Add Terrain Skirt plugin on my blog page does not require the mesh to be a Google Earth Terrain.
                                            • 2 / 2
